hvac light mod... kinda
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yota243, Nov 28, 2012.
  1. Nov 28, 2012 at 7:35 PM
    yota243
    yota243 [OP] Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Both bulbs.went out in my hvac controlled panel and I had so LED strips left over from some other projects. I soldered some wires to.them cutthem the length of.the panel, popped the back off and stuck it in there. Grounded to to one of tje 10 mm bolts behind it and tied it into the solid green wire on the wiring harness on the passenger side and boom, it works just the same. I'll post some.pics.when I.get to.a.computer
  2. Nov 29, 2012 at 12:36 AM
    Bhwang
    Bhwang Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    Very interested how you did this, post some pics and explain a little more of where you piggy backed into.
  3. Nov 29, 2012 at 5:16 AM
    yota243
    E.J.
    north Alabama
    i didnt take any pictures while i was doing it, but u just pop it out from the dash and disconnect the 2 wiring harnesses from the back. they're are 7 screws, (not the 4 out side screws, they hold the face plate on) 5 of the 7 are visible, the other are below the piece that is behind the fan speed switch. it also has a few clips holding it in but comes out pretty easy, be sure to take the knobs off before u start. it will come loose easier. and ill get a vid of the wire i used this afternoon.
  4. Nov 29, 2012 at 10:28 AM
    yota243
    E.J.
    north Alabama
