Hybrid Heat Pump Water Heater
Discussion in 'Garage / Workshop' started by Evil Monkey, Jan 17, 2013.
  1. Jan 17, 2013 at 10:35 AM
    Evil Monkey
    Evil Monkey [OP] There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Does anyone use a Hybrid Heat Pump water heater? They work on the same principle as a heat pump air conditioner. I've just learned about them and it seems like it would be a good option for Southern California/Arizona since we don't get that much cold weather (heat pumps don't work well below 40 degrees). They're expensive but they also cool the space in the summer. Supposedly, they'll cut your energy use for water heating by 60% and have an efficiency rating of 2.5 vs ~0.98 for a standard water heater.
    My current water heater is an 80 gallon AO Smith from 1999 (runs on 220) (5200kwh per year). It's working fine now but in the event it fails, the hybrid might be a good option for me.
    One question I have is the space requirements. My current water heater is in a closet but it's inside the house (in the middle of the floor plan). They recommend at least a 10x10 space. I was wondering if it would still work okay in the closet since it's indoors.
  2. Jan 17, 2013 at 10:37 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    My brother's house I just built has a air to water heat pump to supply hot water for the hydronic slab heat and domestic preheat tank
  3. Jan 17, 2013 at 1:51 PM
    Evil Monkey
    Robert
    Escondido, CA
    So it works okay in the cold? For the preheat tank, is it heating up water that then goes to another hot water heater?
  4. Jan 17, 2013 at 6:00 PM
    OZ-T
    Peter North
    British Columbia
    It works down to a certain temperature which escapes me now , I can find out for you , below that cut off temperature there is a back up electric heating element .
    Yes , the domestic hot water goes into a 40gal pre heat tank that then feeds the regular water heater with warm rather than cold water
