Hyluxtek HID kit with CNLight ball bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scooby24, Oct 25, 2016.
  1. Feb 1, 2021 at 10:28 AM
    #521
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    So after almost 4 years, I think my relay might have died? No power at all going to the ballasts I believe. They don't attempt to turn on. Anyone ever have this issue and just replace the relay?
  2. Feb 5, 2021 at 2:13 PM
    #522
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I already replaced both relays on my HD relay harness, looks like one is starting to go yet again (have spares, just have to find them)
    rlx02[QUOTED] likes this.
  3. Feb 7, 2021 at 10:08 PM
    #523
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    It turned out that it was a bad connection with the relay in the harness. @Vbpiper was gracious enough to meet up and help me troubleshoot it; we switched to a new ballast and it was fine. I popped out the relay and it was pretty dirty and had some corrosion, wiped it off, seated it back in and it fired up nicely.
    I went home bought some dielectric grease like he suggested and coated the prongs after scrubbing them off with a metal brush. So far they're working just fine.
    Thanks again @Vbpiper!
    Vbpiper and Bastek[QUOTED] like this.
  4. Feb 8, 2021 at 6:34 AM
    #524
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    No issues with my setup but I bought a second for the parents and the Diode Dynamics relay started struggling. Diode Dynamics doesn’t sell a replacement relay for their HD harness so we sourced a USA made product on Amazon. Easy and inexpensive fix.
    Vbpiper likes this.
  5. Feb 8, 2021 at 10:42 AM
    #525
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Link to the harness? Might be good to have a spare.
    Vbpiper likes this.
  6. Feb 8, 2021 at 11:12 AM
    #526
    JoeCOVA
    Joe
    Colorado Springs
  7. Jun 17, 2021 at 8:00 PM
    #527
    jewboi
    jewboi Well-Known Member
    To anyone trying to do this in mid-2021– I wasn’t able to find the Diode Dynamics harness in stock so I purchased this and it worked great:
    https://www.ebay.com/itm/202467399229
    other than the relay being a little bigger making the negative terminal ground bolt a pain to get back in, it worked perfect.
    I had no idea what I was doing when I started but after laying all my stuff out and looking at the pics posted by @Scooby24 it started to make sense.
    all in all it took me two hours start to finish and in extremely happy with the result. Could’ve taken half the time if you were experienced.
    ian2016, JoeCOVA and Bastek like this.
  8. Jun 19, 2021 at 7:42 AM
    #528
    jewboi
    Just curious, the driver vs passenger side bulbs have a slightly different output (not color but like size and direction when looking at the output on my garage door) and I’m wondering if maybe I installed one bulb upside down from the other or didn’t fully seat one? Or is it common for them to not be exactly the same
  9. Jun 19, 2021 at 7:50 AM
    #529
    JoeCOVA
    Joe
    Colorado Springs
    would need a pic I think to understand. I havent a noticed a difference with mine
  10. Jun 19, 2021 at 8:52 AM
    #530
    su.b.rat
    su.b.rat broken truck
    no difference with mine, either. 4 years and going strong, btw. good luck sorting it.
  11. Oct 21, 2021 at 6:09 PM
    #531
    jewboi
    Would it be a good idea to go ahead and purchase a replacement set of these in case they go out ? Being that they take like 4-6weeks to arrive after ordering.
    Not sure if that’s smart or dumb, if the have a shelf life, etc. just curious everyone’s thoughts.
    Bastek likes this.
  12. Oct 21, 2021 at 6:22 PM
    #532
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Little PSA for you guys with the relay harness.
    TLDW: knock off fuses may not be protecting your circuits as they should be. Use name brand.
    https://youtu.be/nELwmfAOz_I
  13. Nov 9, 2021 at 8:55 AM
    #533
    jewboi
    Just noticed today that one of my CN bulbs is out and its been less than 4 months since install. i suppose something could have worked its way loose but i doubt it.
    pretty disappointed tbh but i did love the throw and brightness while it lasted.
    anyone know any bulbs that will last longer and utilize the same wiring harness etc?
  14. Nov 9, 2021 at 9:02 AM
    #534
    ib134866
    ib134866 Active Member
    Ian
    2019 Grey TRD Sport M/T
    If you purchased the bulbs from "manufactory88" on Ebay, they are supposed to have a 2 year warranty. Contact the seller for a replacement.
  15. Nov 9, 2021 at 9:10 AM
    #535
    su.b.rat
    that's disappointing. i'm in year 5 i think, all is still fully functional. let us know what replacements you get.
  16. Jan 10, 2022 at 3:52 PM
    #536
    jewboi
    So I need some advice. Since installing these lights with the wiring harness I used (linked to in a previous post) I’ve noticed that the majority of the time only one headlight is operational. It varies as to which light decides to work (as in it’s not always the passenger or driver). However if I turn the headlight switch on and off multiple times I can get the opposite light to engage and then go on my way. Sometimes I also have to turn the truck on and off again.
    obviously it’s some sort of wiring issue. At one point in the past I noticed a loose barrel connector on the harness and re seated it. But since I’m able to get whichever light that’s off working again just by fiddling with the switch it makes me doubt it’s just another loose connector.
    to anyone with electrical experience, any ideas? Bad ground or something like that?
  17. Jan 10, 2022 at 4:20 PM
    #537
    Skydvrr
    Nick
    YMH
    Black '17 OR
    How old is your kit / harness? I had this issue recently, ended up being a bad relay.
  18. Jan 10, 2022 at 7:43 PM
    #538
    jewboi
    Thanks for the reply. It’s not even 6 months old and I’ve had this issue for at least a month.
  19. Jan 10, 2022 at 7:45 PM
    #539
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I had the same symptoms. Flick the stalk an eventually it would fire up. Problem would move sides depending on what I did.
  20. Jan 10, 2022 at 7:48 PM
    #540
    jewboi
    Damn okay that’s good to know. The wiring harness everyone else was using I couldn’t find anywhere, so I found this which seemed like good quality and met all the requirements:
    Maybe it is decent quality and I just got a bad relay or maybe it’s crap. I’m assuming it’s possible to replace just the relay on a harness? Might be a dumb question.
