Hyluxtek HID kit with CNLight ball bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scooby24, Oct 25, 2016.
  1. Jan 11, 2022 at 4:38 AM
    #541
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same exact harness I have, if I'm not mistaken. Yeah the harness will unplug for m the bottom of the relay, just press one tab. Also, consider replacing the fuse that came with that harness, with a name brand one. Those Chinese ones will pop at much higher amps, putting the wiring at risk.
  2. Jan 11, 2022 at 6:35 AM
    #542
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Yes, you should definitely start with checking the relays. And yes, they are replaceable.
    I didn't have good experience with my Morimoto harness. Besides for both relays going bad within two years ( which is still considerably longer than your experience), I also has issues with grounding, crimp-on the ground connector became loose on the wire and didn't always work. And to make matters even more confusing, the harness is using two separate ground points. Actual ground wire that I mentioned previously is powering only the relays. Ground for the ballasts is being supplied from your vehicle's male plug (the one you unplugged from the bulb).
    My apologies for possibly making it a bit confusing, but unfortunately there are a few failure points the need to be checked/ ruled out on the harness, before moving on to the ballasts.
  3. Jan 11, 2022 at 5:51 PM
    #543
    jewboi
    jewboi Well-Known Member
    Did you end up replacing the relays or getting a whole new harness?
    I checked the relays on my harness this evening and they seem OK, no sign of corrosion or a bad connection. So with my symptoms of a random side failing to work, im thinking i have 1 or both of my relays are bad.
    Replacement relays would be ~$30, but wondering now if I should just replace the whole harness? Since the DD harness for example only uses 1 relay, it would be cheaper to replace in the future if I had the same issue.
    Bastek[QUOTED] likes this.
  4. Jan 11, 2022 at 5:58 PM
    #544
    Skydvrr
    Nick
    YMH
    Black '17 OR
    You can get a 5 pack of relays for 12 bux. Test the harness. Shouldn't be too difficult. Or tap on the relays, when one light fails to fire up.
  5. Jan 11, 2022 at 6:48 PM
    #545
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Replaced relays first. Rewired whole harness while looking for the faulty (what turned out to be) ground. Then ended up replacing the harness for a single relay one.
  6. Jan 13, 2022 at 11:46 AM
    #546
    jewboi
    Got a link to that 5 pack? Having trouble finding something I’m sure is compatible
  7. Jan 13, 2022 at 12:00 PM
    #547
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Maybe yours is different, aren't they just normal 12v relays?
  8. Jan 13, 2022 at 7:47 PM
    #548
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Yes, kinda. They're encased in waterproof covers
  9. Jan 14, 2022 at 4:36 AM
    #549
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Ahhh that's right. Good call.
  10. Jan 18, 2022 at 6:30 PM
    #550
    jewboi
    Just wanted to follow up to you and the thread for future readers. I inspected the relays the other night to see if the prongs appeared corroded or something, and they looked brand new. So I figured it must just be the relays itself with the symptoms I was having. Purchased a 5 pack of relays on Amazon for $20 and replaced them tonight and all issues seem to be solved.
    I relocated the metal bracket from the Morimoto relays to the new ones, so I could still mount them with the single bolt at the battery ground, and that was kinda a PITA but overall it was super easy.
    Thanks for the help.
    Skydvrr[QUOTED] likes this.
  11. Jan 18, 2022 at 6:47 PM
    #551
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Glad u figured out the mounting situation. I struggled with removing the tabs as well. :thumbsup:
  12. Jan 19, 2022 at 5:56 AM
    #552
    jewboi
    well...i spoke too soon. after replacing the relays i fired the truck up 3 times last night and both lights came on every time so i thought i was good.
    this morning just 1 fired on though, so looks like im SOL on the relays being the issue.
    From here, how do i determine if the wiring harness is bad or the ballasts?
  13. Jan 19, 2022 at 6:45 AM
    #553
    Skydvrr
    Nick
    YMH
    Black '17 OR
    When one doesn't fire up, check input TO the ballast, make sure you're getting 12v? Be careful w those ballasts though. Theres some funky voltage goin through that thing lol.
  14. Jan 23, 2022 at 4:39 PM
    #554
    jewboi
    hate to be a burden on this thread but im becoming very frustrated. still having the same issue of either none, or only 1 light firing up up. if i flick them on and off repeatedly for 20-30x i can eventually get both to fire but damn driving with only 1 is getting old. again, its different each time on which light decides to fire up (its not consistent).
    so far ive tried replacing the relays, put dielectric grease on the prongs of the new relays. today i cut off all the heat shrink near the relay connection to see if the crimp on ground connection was loose, or the splice from the ground going to each relay and they are all rock solid.
    since both lights have the capability of working, im convinced its not the ballasts but some weird wiring issue? but im not sure what. probbaly would be best to just get a new harness at this point. however im not seeing that the original Diode Dynamics one is still available? or am i wrong?
  15. Jan 23, 2022 at 4:44 PM
    #555
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Whenever u find one that's not firing, track it down. Does the plug going into the ballast have power? Etc.
  16. Jan 23, 2022 at 5:33 PM
    #556
    jewboi
    okay your post inspired me to get out there and just start trying stuff. focused on the signal wire since that seems to be the issue im having, as in it doesnt know when to fire the lights, so i made sure the polarity was correct and unseated each connector (1 on each side of adapter) and applied dielectric grease. seated them back together real well, and that seems to have fixed it (for now...)
    @Skydvrr thanks for moral support lol
  17. Jan 23, 2022 at 6:01 PM
    #557
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I've been there man. It's fuckin annoying. Early in the morning, fire up the truck to go to work and one bulb won't fire. Last thing u wanna deal with half asleep haha.
    The relays ended up fixing my issue. But eventually I got tired of morimotto and ended up going to denso slim ballasts and D2s bulbs. Haven't had an issue since.
  18. Feb 1, 2022 at 4:39 PM
    #558
    jewboi
    Does anyone know other than Diode Dynamics, who makes a single relay harness to replace my Morimoto one? Still having some issues and at this point I just want to replace it, but ideally want one that uses a single relay.
    The Diode Dynamics one doesnt seem to be listed on their website anymore
  19. Feb 1, 2022 at 4:42 PM
    #559
    Skydvrr
    Nick
    YMH
    Black '17 OR
    @no vtec 4me might have some beta.
  20. Feb 2, 2022 at 5:41 AM
    #560
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    You have all the parts already. Cut up the harness(es) you have and make your own.
