Hyluxtek HID kit with CNLight ball bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scooby24, Oct 25, 2016.
  1. Jan 16, 2017 at 10:17 AM
    #101
    Edmontontaco
    Edmontontaco Well-Known Member
    Alberta, Canada
    2016 Black TRD Sport
    I cant find the posting anywhere, is someone able to post a link to the exact bulbs and ballasts i need to buy? i dont really trust buying from aliexpress. Also do i really need a relay? Or can i just put in a 20 amp fuse?
  2. Jan 16, 2017 at 10:27 AM
    #102
    su.b.rat
    su.b.rat broken truck
    the relay is just $30, is waterproof, and fits right up in a few minutes. do it for peace of mind. there's nothing to it.
  3. Jan 16, 2017 at 10:37 AM
    #103
    Edmontontaco
    Alberta, Canada
    Are these the right ones? Theres no where to select specific bulb and temp.
  4. Jan 16, 2017 at 10:38 AM
    #104
    Scooby24
    Scooby24 [OP] Well-Known Member
    Greg
    2017 DCSB OR 4X4
    http://www.ebay.com/itm/2016-HYLUX-...ash=item41bbdef91e:g:EZwAAOSwF1dUR6-4&vxp=mtr
    They are still offering the Ball Bulb but it look like they are back to making you specify with them additional changes. At this point, not really knowing what benefit the ball bulb provides over others, the straight CNLight bulbs are still great, I'm sure.
    And do the relay for peace of mind. I'm sure it would work fine with the 20 amp fuse alone, but are you going to be paranoid about the stock wiring?
  5. Jan 16, 2017 at 10:45 AM
    #105
    Edmontontaco
    Alberta, Canada
    Okay, i just bought the ones that I linked in my above comment. ill pick up a relay from diode dynamics as well.
  6. Jan 20, 2017 at 12:49 PM
    #106
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Gravex3400 likes this.
  7. Jan 23, 2017 at 7:37 AM
    #107
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Hey scooby, did you have LEDs before doing the HIDs?
  8. Jan 23, 2017 at 7:51 AM
    #108
    Scooby24
    Greg
    2017 DCSB OR 4X4
    No, not on this truck.
  9. Jan 23, 2017 at 7:55 AM
    #109
    JoeCOVA
    Joe
    Colorado Springs
    Gotcha I was hoping you might have had a good comparison, I currently have the LEDs.
  10. Jan 23, 2017 at 8:27 AM
    #110
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Yeah, no real great comparison, but here's an observation in photos between LED and HID.
    The LED (OPT7) on the left has no significant hot spots at this exposure. While the light is spread nicely, it won't throw as far as the light is not as concentrated in the center of the beam as the halogens are. While the light towards the edges of the pattern is probably providing a benefit over Halogens, I suspect they aren't able to throw even as far as the Halogens. The Halogens actually look over exposed compared to the LEDs, which is surprising.
    Compare this to the HIDs and the light is much, much more concentrated and significantly brighter than the halogens and at the same exposure, way blown out.
    rlx02 and JoeCOVA like this.
  11. Jan 23, 2017 at 4:07 PM
    #111
    Jbeiker
    Jbeiker Well-Known Member
    2016 Trd Sport
    Awesome install! How nice n the same hell did you get those ballasts so far down there? Did you end up taking your washer fluid container out and battery so you could install them?
  12. Jan 23, 2017 at 5:21 PM
    #112
    su.b.rat
    i had to remove the washer reservoir. removing it detached the pump and i got washer fluid everywhere before i realized what happened, so plan ahead. the pump just pops back in easily, and the reservoir removes with just 2 bolts iirc.
  13. Jan 30, 2017 at 1:33 PM
    #113
    Edmontontaco
    Alberta, Canada
    Okay so I hooked up everything, I used the relay from diode dynamics and where it connects to the drivers side plug it fits snug but the lights wont turn on. Was i supposed to buy some sort of adapter as well? I just tried it without the relay and the lights wont come on either...
  14. Jan 30, 2017 at 1:54 PM
    #114
    su.b.rat
    on the pass. side take a look at your wires. you should see something like this, where you see the polarity matching up. red to red, white to white. if you see red to white your polarity is swapped, and simply insert the adapter between the bulb and ballast and it'll match.
    my lights came on no problem before i inserted the adapter. but my leads connected, so it sounds like maybe your leads aren't meeting. i believe the adapter helps with that. this is earlier in this thread iirc.
  15. Jan 30, 2017 at 1:58 PM
    #115
    Edmontontaco
    Alberta, Canada
    Okay, it looked like the pins lined up from the relay to drivers side plug. How can i make the leads meet up?
  16. Jan 30, 2017 at 2:13 PM
    #116
    su.b.rat
    i'm working right now, but pretty sure there's a mention of it early in the thread.
  17. Jan 30, 2017 at 2:15 PM
    #117
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Did you install the H11 to 9006 adapter to the relay harness from the OEM plug?
  18. Jan 30, 2017 at 2:29 PM
    #118
    Edmontontaco
    Alberta, Canada
    yeah haha oops. its working now! Im stoked to go driving tonight!!!
    su.b.rat likes this.
  19. Feb 8, 2017 at 3:58 PM
    #119
    Scooby24
    Greg
    2017 DCSB OR 4X4
    I bought some 6000k bulbs from the seller for 30 shipped so I could compare...for science!
    I'll let you all decide for yourselves.
    6000k vs. 4300k
    6000k in both
    I'm going to go driving here in a bit, soon as it gets dark so I can see if there's a difference in visibility.
    smikels, tuftster and Gravex3400 like this.
  20. Feb 8, 2017 at 5:00 PM
    #120
    Gravex3400
    Gravex3400 Well-Known Member
    Jose
    Oceanside, CA
    2017 MGM Tacoma TRD Sport
    Very interested in your thoughts of the light output and how you like the color opposed to the 4300k. I tried purchasing the 4300k bulbs but they're currently out of stock and the seller was trying to push the 6000k on me. I declined as I thought they'd be too blue and light output would suck.
