Hyper Flash Issue - SR5 Amber DRL
Discussion in 'Lighting' started by Xabiss, Oct 6, 2018.
  1. Oct 6, 2018 at 11:51 PM
    Xabiss
    Xabiss [OP] Member
    Okay I working on getting most of my bulbs converted to LED on my 2018 SR5. I converted my front blinkers/DRL to these JDM ASTAR LED lights:
    https://www.amazon.com/gp/product/B00PHVUWR8/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    The issue is when I have my headlights on I get hyper flash. If my lights are off and DRL are on they work great even with the blinkers. I know I need to purchase some of these to fix the issue:
    https://www.amazon.com/4Pcs-Aaron-6...38894966&sr=8-3&keywords=hyper+flash+resistor
    But I know each light has three wires and I am not sure which ones to hook them up to. Do any of you know which line is for the DRL and which one is for the blinkers. I just want to make sure I hook them up correctly. Thanks for any help on this matter!
  2. Oct 7, 2018 at 3:38 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Oct 18, 2018 at 5:34 PM
    LeSueur1
    LeSueur1 Well-Known Member
    Chandler
    James City Co VA
    2016 Silver Tacoma SR5
    Bilstein 2.5”, ToyTec 1” Taco lean spacers, 33” Gladiator X Comp MT’s, Method NV305 18x9 -12 offset
    So I'm having the same issue, recently got a 2016 SR5, but my hyperflash doesn't go away. On the drivers side I get the resistor goes to the beige color wire, what about on the passenger side. Maybe I'm reading this wrong, but white is the turn signal on both sides or ?? stumped.
    Nvm: got it now. After my 2 halogen bulbs blew
  4. Oct 19, 2018 at 10:22 AM
    Taco-Man18
    Taco-Man18 Well-Known Member
    2018 MGM Tacoma V6 SR5
    Here's what I got, from testing with my test light the other day.
    Driver's side:
    Light brown - On when switched DRLs on - DRL High
    Red - On when switched to Fogs or Headlights - DRL Lo
    White/Black - Ground
    Passenger's side:
    Light blue - On when switched DRLs on - DRL High
    Blue - On when switched to Fogs or Headlights - DRL Lo
