I came home to a puddle of gas...
Discussion in 'General Automotive' started by acmair, Feb 7, 2011.
  1. Feb 7, 2011 at 7:04 PM
    acmair
    acmair [OP] Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    under my 94 corolla. I just filled up the tank full of gas the night before, and decided not to drive it today, luckily. When I got home the smell was overwhelming and there was gas dripping on the ground. I jacked it up and tried to wipe it dry to see exactly where the leak was. My mistake, now its gushing out lol. Has anyone ever replaced a fuel tank before? Is it a do it yourself job, or should I send it to a mechanic?
    Thanks!
  2. Feb 7, 2011 at 7:05 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    shouldnt be that hard...Unless everything is rusted and bound to break just by looking at it. Are you planning on doing it on your back, or do you have access to a lift?
  3. Feb 7, 2011 at 7:07 PM
    acmair
    Andrew
    I just have a normal hydraulic jack, so I'm looking to do it on my back. No, the car seems to be in perfect condition underneath, I'm just worried about the fuel gauge and all of those components.
  4. Feb 7, 2011 at 7:13 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Probably wouldn't smoke in your driveway. Might end up in your hot neighbor's house, after your car blows up, so maybe on second thought, maybe you should.
  5. Feb 7, 2011 at 7:15 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    just empty the tank out prior to removing it. Not sure on how its held in, but more then likely one or two rubber or metal straps holding it up. The sender should be 3-4 bolts on the top of the tank, plus filler,vent and whatever else is up there. If all goes well, it should be done in a day.
  6. Feb 7, 2011 at 7:41 PM
    acmair
    Andrew
    Lol, i dont smoke so its all good, and none of my neighbors are hot :(
  7. Feb 7, 2011 at 7:43 PM
    acmair
    Andrew
    It has 2 straps, that I saw at least. They seemed like rubber,but I'm not sure. I watched some videos and they said that its best to replace the sending unit too. Would you recommend that? Also, is it easy to do if I only jack up the car on the hydraulic jack and lie on my back?
  8. Feb 7, 2011 at 7:47 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    never trust a jack of any kind. Always use a jack stand.
  9. Feb 7, 2011 at 7:53 PM
    acmair
    Andrew
    Thanks! I have one jack stand, I should probably buy a few more for this, I'm guessing.
