I can help with questions about doors and windows.
Discussion in 'Garage / Workshop' started by ndoldman59, Apr 25, 2021.
  1. Apr 25, 2021 at 1:01 PM
    ndoldman59
    ndoldman59 [OP] Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Any questions about doors and windows I can give ideas on replacement or repair. Worked in the wholesale and production building trades along with repair. 37 yrs.
    Worked with Marvin, Anderson, Windsor, Lindsay and Philip's industries windows.
    Thematru, Peachtree, benchmark, stanley, and other exterior door systems.
    Interior doors.
    Steves104x4 and Fargo Taco like this.
  2. Apr 26, 2021 at 4:38 AM
    ndoldman59
    Murray
    West Fargo, ND
    I have an opinion about vinyl windows, most are not going to like . First they have no structure to them, because most are hollow framed. They have to be, basically they are ice cube trays with glass and hardware screwed in them. Being hollow they have built in air leaks the weatherstripping isn't designed to keep water out from driving wind and rain, also remember being hollow in cold north regions frost forms inside the frame. Water freezes with 3000 lbs per square inch. The moisture has to get out so they have weep systems, some are better than others. Since they are hollow and without structure the install has to be good or they will not perform as designed. Some direct set windows have no weeps because they are sealed and frost / moisture build up would be nil.
    Steves104x4 likes this.
