I don't understand how shocks lift the truck...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XGR50.2, Jan 23, 2010.
  1. Jan 23, 2010 at 12:41 PM
    XGR50.2
    XGR50.2 [OP] Active Member
    David
    West Texas
    05 TRD
    I understand people install 5100s for the purpose of leveling the truck or lifting it. How would a shock do that if its only there to absorb shocks aren't the springs what hold up the weight ? Wouldn't it make sense to install a bigger or stiffer spring to lift it ?
    Sorry if this is an ignorant question...:confused:
  2. Jan 23, 2010 at 12:42 PM
    Brunes
    Brunes abides.
    Rotorhead
    Gotta understand how the 5100s work. There is an adjustable collar that can be put in the "stock" position or slid up the shock tube for lift. That collar is where the spring sits...so moving the collar up puts the spring higher on the shock and preloads it more than stock to provide the complete lift.
  3. Jan 23, 2010 at 12:43 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    The 5100's for the front have an adjustable bottom spring plate allowing you to compress the coil for added lift.
    Marc M
  4. Jan 23, 2010 at 12:46 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    They don't with the 5100 you get the lift from lifting the position of the bottom of the spring higher, preloading the spring, therefore pulling the shock rod out of the shock body. For example using the eibach 1.6" lift springs, the springs are longer which provides the lift. With the additional spring length you have to have the rod come from the body a certain amont to accommodate the longer spring.
    Allin all its the postition of the spring or the length of the spring, or stiffness that lifts the truck not the shock. Shocks only job is to damper
  5. Jan 23, 2010 at 12:46 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    ^^^ What they said. Also, you are correct. You can install a longer spring such as 885 or the eibachs to gain lift.
  6. Jan 23, 2010 at 12:47 PM
    XGR50.2
    David
    West Texas
    05 TRD
    Ohh okay that makes sense
    I read in the sticky that you shouldn't use an aftermarket spring with the 5100s...why not?
  7. Jan 23, 2010 at 12:50 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    first off the shock absorbers (ironically) dont absorb the shock... the springs do... the shocks make it so the spring doesnt bounce back hard...
    and theres a collar on the shock that you can set it to the height you want
  8. Jan 23, 2010 at 12:51 PM
    08pretaco
    Oliver
    az
    Ya no problem man. It was amazing to me when I changed out the rear shocks to 5100 that you don't need to do anything to the back to change them. You can have the truck sitting on the ground, unbolt the stock shocks and then just install the new ones, mind boggled me haha
  9. Jan 23, 2010 at 12:54 PM
    08pretaco
    Oliver
    az
    Think of it this way. If you go one way with something you wanna stick with products that are made to work with each other. So you get ome lift springs then to get the most out of the suspension you will want to run the shocks that were designed for that specific spring
  10. Jan 23, 2010 at 12:56 PM
    08pretaco
    Oliver
    az
    Shocks dampen not absorb, I think haha correct me if I'm wrong
  11. Jan 23, 2010 at 12:59 PM
    Brunes
    Brunes abides.
    Rotorhead
    The "no aftermarket springs with the 5100s" is more don't use the springs with the adjustable collar higher than stock.
    The most aftermarket springs have different spring rates and lengths than the stock springs. If you pre-load them with the adjustable collar, you will make the springs overly stiff and can damage your suspension/driveline components. Use the aftermarket springs with the collar at the "stock" location- Good to go.
  12. Jan 23, 2010 at 1:03 PM
    XGR50.2
    David
    West Texas
    05 TRD
    That's what I had in mind, dampen, just some poor word choices
