I f**ked up!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachie, May 19, 2010.
  1. May 19, 2010 at 11:20 AM
    Chachie
    Chachie [OP] Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    So i installed an NMO antenna the other day and made one huge mistake. I didnt clean up all of the metal shavings. So the other day it rained and i was excited to see that the antenna was not leaking, therefore it was a successful install...wrong. I just looked on my roof this morning and there are little rusted metal shavings all over my roof. F**K!!!! So now what? What should i do to clean it? I was pondering the idea of just wiping them off and then wet sanding the roof and reapplying clear coat to it. GAH!!!
  2. May 19, 2010 at 11:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    Clay bar it
  3. May 19, 2010 at 11:24 AM
    Chachie
    Justin
    Nor Cal
    and what about removing all the rust spots stuck to the paint?
  4. May 19, 2010 at 11:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Wipe off any shavings left first. The bar should get rid of the rust spots
  5. May 19, 2010 at 11:25 AM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    X2
    Don't panic a clay bar will fix that, no problem.
  6. May 19, 2010 at 11:26 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
  7. May 19, 2010 at 11:26 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    if the clay bar does not take care of that, a good polishing or rubbing compound should do the trick
  8. May 19, 2010 at 11:30 AM
    Chachie
    Justin
    Nor Cal
    brb ill take some. lol but on the bright side, the antenna looks great.
  9. May 19, 2010 at 11:32 AM
    ScubaCougr
    ScubaCougr Active Member
    Pacific NW
    '08 PreRrunner
    nerf bars
    Before wet sanding / clear coating, ask a detailer or body shop that does paint correction for help...with the right pad and compound the spots might come out.
    If not, it's the roof...only an NBA player will see it. Nobody else will notice
  10. May 19, 2010 at 11:37 AM
    Chachie
    Justin
    Nor Cal
    It also helps that im on a 6" fabtech with 35's. But its more the fact that i know that if i just leave it, the rust will chew through the paint and hit the metal of the roof.
  11. May 19, 2010 at 11:39 AM
    Chachie
    Justin
    Nor Cal
  12. May 19, 2010 at 11:41 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    go to a self serve car wash and spray it down real good. From roof down to make sure you have all that washed off the truck. Then use the clay bar. That should correct that.
  13. May 19, 2010 at 11:56 AM
    Jreays
    Jreays Member
    Jeremy
    Ohio
    09 4x4 Sport Double
    I installed an NMO mount using the hole for the Sat Radio. Worked pretty well. The factory Sat antenna had two holes so I had to fill one. I was thinking about drilling but I would have been sad. Sorry you had a problem like this!
