I feel a lot of vibration in my floorboard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JDMrolla, Dec 30, 2010.
  1. Dec 30, 2010 at 8:21 AM
    JDMrolla
    JDMrolla [OP] Well-Known Member
    Chesapeake, VA
    06 Black DCab TRD off road 4x4
    this was noticable after i got my truck lifted (spacers, aal, diff drop). i can feel it most under accleration and breaking. is this something thats normal from the lift? or anybody else hear or know about this problem?
  2. Dec 30, 2010 at 8:49 AM
    DirtDriven
    DirtDriven Active Member
    IMHO you are going to get some vibration whenever you install a lift because it changes the drive line geometry from what the truck was originally designed for.
    Of course, their is what I consider a acceptable amount of vibration and you want to get it to a minimum as it will be harder on your bearings,u joints, etc.
    How much lift did you lift it?
  3. Dec 30, 2010 at 10:17 AM
    JDMrolla
    Chesapeake, VA
    its a 3" lift, what would you recommend to get it to a minimum?
  4. Dec 30, 2010 at 10:48 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Congrats. You are the new recipient of front diff bearing replacement therapy. Throw your truck in 4x4 on a straight stretch and see if the vib goes away. If it does, your (Mostly likely drivers side) front diff bearing is toast and needs replacing.
  5. Dec 30, 2010 at 11:13 AM
    spamy
    spamy Truck guy
    NorCal
    07 4X4 Tacoma Sport SR5 Access Cab
    X2
  6. Dec 30, 2010 at 12:09 PM
    fitryders2
    fitryders2 Well-Known Member
    shawn
    virginia
    07 trd sport
    How hard is that to do?
  7. Dec 30, 2010 at 12:18 PM
    spamy
    spamy Truck guy
    NorCal
  8. Dec 30, 2010 at 12:47 PM
    JDMrolla
    Chesapeake, VA
    thanks the first link helped, im not the only one with the pulsing vibration, will have to save up for a month before im able to take it in for service though
  9. Mar 21, 2011 at 7:09 PM
    ywen
    ywen Well-Known Member
