I got a Problem.....
Discussion in '1st Gen. Tacomas (1995-2004)' started by ETaco23, May 21, 2010.
  1. May 21, 2010 at 5:27 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I will try both MAF and cleaning the IAC hopefully soon. Does anyone know if the MAF has a gasket? If so, where can I find the part?
    It use to have a rubber ring on it, but it broke/ripped off. And Ive tryed weather stripping and others but it just doesnt hold up to the heat.....
  2. May 21, 2010 at 5:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no gasket for the maf...but u should get the o-ring for it.
  3. May 21, 2010 at 5:57 PM
    ETaco23
    Evan
    PNW
    I think thats what broke off. Were can i get one?
  4. May 21, 2010 at 6:31 PM
    ETaco23
    Evan
    PNW
    Que????
  5. May 21, 2010 at 7:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think maybe fftbrat is blaming the issue on the fact that you have a 1st gen by only showing a pic of a 2nd gen. I hope I'm wrong.
  6. May 21, 2010 at 7:58 PM
    ETaco23
    Evan
    PNW
    Haha... that better not be what he means! bc 2nd gen's have there share of problems too.
  7. May 21, 2010 at 8:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What!!!! :eek: You don't think getting a 2010 TRD would fix all your worries??? I am truly shocked by that.
  8. May 21, 2010 at 8:09 PM
    ETaco23
    Evan
    PNW
    No... I was saying 2nd gens have there share of problems. I would never get rid of my truck, for a new truck. :)
  9. May 21, 2010 at 8:10 PM
    ETaco23
    Evan
    PNW
    atleast not yet....;)
  10. May 21, 2010 at 8:14 PM
    ETaco23
    Evan
    PNW
    So... Would a leak in my MAF housing be causing this? bc I dont have that o-ring anymore...
  11. May 21, 2010 at 8:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Sorry man, I wish I could give you solid answers. I've had my truck do exactly as you described (stumble after starting when already warmed up) but its only been a one time only thing. It doesn't continue after that.
    Could it be bad gas? Maybe a little water in the fuel in this fill up?
  12. May 21, 2010 at 8:39 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    This might be a long shot but is your air filter oiled or dry. My dad had the same problem with his chevy and traced it back to a drop of airfilter oil on the MAF senor. It took months to figure it out. He has been a mechanic for 40+ years.
  13. May 21, 2010 at 8:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    could be reading wrong. get an o-ring kit from harbor freight or northern tool...and fit it to the sensor.
  14. May 21, 2010 at 10:29 PM
    ETaco23
    Evan
    PNW
    will do! thanks a bunch guys!
    And to Matt, I have a dry filter. Got rid of that gay K&N after a couple months.
  15. May 22, 2010 at 8:32 AM
    #35
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    A.) Maybe the fuels not reaching the fuel injectors...vapor lock caused by clogged fuel tank vents lines...
    B.) Bad engine ground connection...
    C.) Fuel injection or something with the engine management sytem...
    Just throwing stuff out there :cool:
  16. May 22, 2010 at 9:25 AM
    #36
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    Maybe I'm wrong but what about bad fuel injectors with water in the tank? Could you have picked up a bad tank of fuel somewhere? I'd prolly start off with pouring something in the gas tank that would absorb the moisture and see what that would do for you then proceed to the fuel injector side....
  17. May 22, 2010 at 10:46 AM
    #37
    ETaco23
    Evan
    PNW
    You might be right about the Injectors.... I just read that its a good idea to have them replaced after 100k miles or so. I will try some fuel Injector cleaner. See If that helps any. But I did just put some in it last month some time.... Its really just too hard to tell what it could be right now, bc it just started happenning. And it doesnt even happen all the time. Maybe twice in the last month or so.
  18. May 22, 2010 at 3:05 PM
    #38
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    How does the truck run when you get on it?
  19. May 22, 2010 at 4:26 PM
    #39
    rme
    Savannah
    Green TACOMA
    If your truck just started with these episodes I'm betting you got some bad fuel. Not sure how to draw a fuel sample but I think I would try and get a sample from the lowest part of the tank...draw it out then look at it in a bottle of good fuel. That would tell you if it was water.....you might even pull some crap out of the tank along with the sample...that would tell you vandalism....
  20. May 22, 2010 at 4:39 PM
    #40
    ETaco23
    Evan
    PNW
    It runs ok, feels a little slow, like I lost some power lately....
    But I just cleaned my MAF and shot some TB cleaner down in the IAC valve. Hoping to clean it up some what. And I also added some Lucas fuel cleaner. Took it for a spin, and WOW! it drives alot better! No more hesitation and I feel like I got my power back. The MAF wasn't that dirty. but I still gave it a few shots of cleaner. So I hope I fixed my problem! Knock on wood...:D
