I hate the "Fresh Air" for defrost...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MyBBPYota, Feb 10, 2018.
  1. Feb 10, 2018 at 10:43 PM
    MyBBPYota
    MyBBPYota [OP] Well-Known Member
    Carey
    Colorado
    2017 BBP SR5 DCSB
    Yes, I know why it automatically switches to fresh when you put it on defrost. I get migraines and one of my triggers is exhaust fumes. Does anyone know of a way to disable the fresh air function? I really need to be able to turn it off and on while on defrost. This is really the only thing I really hate about my truck.
    MarvinL likes this.
  2. Feb 10, 2018 at 10:53 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    On the second gen putting the vent on floor position allowed a little air go through the defrost vents. Try that with ac and heat on to defrost
  3. Feb 10, 2018 at 11:37 PM
    MyBBPYota
    Carey
    Colorado
    2017 BBP SR5 DCSB
    I needed full Defrost today. It was 18-20 degrees and snowing. I miss the lever on my 89...
    Key-Rei, Kilokato and DaveInDenver like this.
  4. Feb 11, 2018 at 12:08 AM
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Yeah, it's annoying. What annoys me is when you switch it BACK to whatever position you had it in before, it does not re-enable recirculate.
    Pulling in outside air doesn't bother me TOO much... I've got some allergies, but not that bad. I just don't like the SMELLS that come in from outside sometimes.
    MyBBPYota[OP] likes this.
  5. Feb 11, 2018 at 5:58 AM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Cant you turn on AC max and set the temp where you want it. Instead of the defrost button, use the blower setting that blows feet and windshield.
    over60 likes this.
  6. Feb 11, 2018 at 6:00 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Crack your window open a bit! Oops, that's the opposite of what you want!!!:D
    Taconator87 likes this.
  7. Feb 11, 2018 at 6:01 AM
    Markcal
    Markcal Well-Known Member
    X2 = best cheapest option.
  8. Feb 11, 2018 at 6:07 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Being able to be in total control of the climate system is one thing I miss, too. My '91 didn't even have A/C in it so you'd think if there was ever an excuse for forcing you to select fresh would have made a lot of sense, but Toyota trusted the driver to make his own decision.
    In this case I thought there was a way to get the climate control to let you pick, but perhaps I'm thinking of not making the A/C come on with defrost automatically. Which is what really annoys me personally.
  9. Feb 11, 2018 at 6:15 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
  10. Feb 11, 2018 at 6:18 AM
    Devil Dog
    Devil Dog Tacos, Tacos, Tacos, come and get your Tacos
    Philly Burbs
    2017 Tacoma TRD OFF ROAD 4x4 Double Cab / Inferno
    5% Tint, cargo tray and organizer, 1.25” Spidertrax spacers, TuffSkinz raised tailgate letters, Air compressor, Bed Extender.
    Only having like 4 speed settings on the fan pisses me off. It’s odd. Low is too much sometimes...There should be 6 settings at least or an infinite knob where you pick the speed like many cars..
    The whole recirculate and fresh air thing is odd. I think it has something to do with the compressor and how and when it is supposed to work.
  11. Feb 11, 2018 at 6:20 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    You should have exactly ZERO exhaust fumes in the passenger compartment regardless of what your climate control is doing.
    Rowdymoon and Stocklocker like this.
  12. Feb 11, 2018 at 6:37 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    That makes no sense.
    I have exact same issue OP. Exhaust fumes trigger my migraines also. I can smell every vehicle on the road if recirculation is off.
    For defrost I must use the defrost/floor setting. This allows recirculation to be active and defrost.
    jerzsubbie and over60 like this.
  13. Feb 11, 2018 at 6:41 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Did you look at the link in post #9? It’s the mod directions for a 2nd gen truck to give complete manual control over the recirc feature.
  14. Feb 11, 2018 at 6:44 AM
    Hobbs
    Yep…
    Wheather or not it makes sense to you, vehicle exhaust contains carbon monoxide, hydrocarbons, sulfur dioxide, particulates, and other poisons. These poisons can cause brain damage and other health issues.
    Exhaust fumes are not good for people. You ever wonder why exhaust fumes trigger your migraines?? :notsure:
  15. Feb 11, 2018 at 6:47 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    hmmm mines got at least 7 speeds on it.
    over60 likes this.
  16. Feb 11, 2018 at 6:48 AM
    JayRolla
    Colorado Springs
    Yes and if a vehicle in front of you sitting with exhaust coming out is then sucked into your cab from not recirculating it causes issues. It can and does happen.
  17. Feb 11, 2018 at 6:49 AM
    Hobbs
    Yep…
    Certainly does.
  18. Feb 11, 2018 at 6:55 AM
    EdgeCrusher
    Chicagoland
    Can't you just press the recir button?
  19. Feb 11, 2018 at 7:02 AM
    Markcal
    Defrost goes to fresh air by default and can only recirculate if you chose the defrost/floor option.
  20. Feb 11, 2018 at 7:04 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
