I have a "cylinder one misfire" on OBD-II
Discussion in '4 Cylinder' started by odonned22, Mar 21, 2011.
  1. Mar 21, 2011 at 3:57 PM
    odonned22
    odonned22 [OP] Member
    Its a 95, 4 cylinder, 2.7 liter. I'm assuming #1 cylinder is the one in front (closest to me when I look under hood). Any advice?
  2. Mar 21, 2011 at 3:57 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    start with the basics, pull the plugs and see what condition they are in.
  3. Mar 21, 2011 at 4:00 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    This^^ and yes number one is the cylinder closest to the radiator.
  4. Mar 21, 2011 at 4:06 PM
    odonned22
    Hey, thanks for both replies! That is my plan of attack. Knowing "Cylinder #1" is up front, now, should short-cut the process.
  5. Mar 24, 2011 at 10:39 AM
    odonned22
    Okay, thanks for the previous help, folks. Replaced #1 cylinder wire and plug (will replace all four - thinking it can't hurt). Reset computer with OBD-II; engine light came back on within a few miles. Thinking I will replace distributor cap and rotor next. Any thoughts?
  6. Mar 24, 2011 at 11:01 AM
    98tacoma27
    Ben
    Beech Creek
    That's a good plan. If it does it still, I would suggest a leak down and compression test on the cylinder.
    It could also be an injector issue. You could swap the injector with another cylinder and see if the misfire code changes to that cylinder.
  7. Mar 24, 2011 at 11:08 AM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    It would be wise to do this before you throw any more money at it.
  8. Mar 25, 2011 at 10:00 AM
    odonned22
    Both sources of advice sound wise, thank you! I checked out the distributor cap, and my novice eyes don't seem to detect much - little bit of white and burn marks on posts. I'm supposing #1 post could be worn enough to cause misfire! I'm also thinking that, if it was the rotor, the misfire would be on more than one cylinder? Throwing a new cap on doesn't seem too ominous to me, but beyond that...
  9. Apr 1, 2011 at 8:48 AM
    odonned22
    Okay, it has been two weeks. Replaced #1 wire and #1 plug. Deleted OBD code, but engine light came back on. Replaced remaining plugs and wires, distributor cap and rotor. Deleted OBD code, but engine light came on again. Filled gas tank, adding Seafoam, but didn't reset OBD codes. And this morning, engine light was off!! Any help in understanding how this happened?
  10. Apr 2, 2011 at 1:52 PM
    billwot
    billwot Well-Known Member
    Eastern NC
    '11 Access 4 cyl auto SR5
    Although I personally think Seafoam is snake oil, a dirty injector can give you a misfire code. Maybe the Seafoam cleared the injector.
    I had the same problem (actually P0302) with my '02 Frontier. Completely refreshed the ignition, did a compression and leakdown test (both OK) and replaced the #2 injector. Still had the problem, so I sold the truck to local used car dealer, and he sold it at auction. Then I bought the new Tacoma.
    FYI, after I sold the Frontier, a tech posted on one of the Nissan message boards that the lines that carry the EGR gasses to each intake port can become clogged, and cause either a lean condition (one line clogged) or a rich condition (3 lines clogged) either of which can cause a misfire.
  11. Apr 4, 2011 at 9:20 AM
    odonned22
  12. Apr 4, 2011 at 6:45 PM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    i had this problem when i was driving through water up to my hood all day and i sucked up alot of water and fried some very important wires, mine was a 99 tacoma v6 tho. good luck!
