I have a problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Juddy1986, Apr 30, 2018.
  1. Apr 30, 2018 at 4:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Your better off with a fabtech 6” lift then a rough country lift....
  2. Apr 30, 2018 at 4:15 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  3. Apr 30, 2018 at 4:18 PM
    Juddy1986
    Juddy1986 [OP] Member
    Justin
    2000 Tacoma
    Lifted
    ok sounds great but will factor control arms work cuz I know where some are at a junk yard right now
  4. Apr 30, 2018 at 4:19 PM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    Just make sure the bushings are good and make sure you take the bolts and the nuts.
    Juddy1986[QUOTED][OP] likes this.
  5. Apr 30, 2018 at 4:21 PM
    spinyard
    spinyard Well-Known Member
    you mean trail disaster?
    Juddy1986[OP] likes this.
  6. Apr 30, 2018 at 4:22 PM
    Juddy1986
    Justin
    2000 Tacoma
    Lifted
    ya I just found the thread where the guy used VW struts to fix his. I would really like to just put I back to stock I wonder how hard that would be. P.S. thanks everyone I really would have never figured this out with yall
  7. Apr 30, 2018 at 4:24 PM
    anthony250f
    Anthony
    San Diego, CA
    You can’t unless you cut out a factory crossmember from another frame and weld it on your frame
    Drop brackets you have to cut the frame crossmember for install
  8. Apr 30, 2018 at 4:31 PM
    Juddy1986
    Justin
    2000 Tacoma
    Lifted
    ok so now that I know more about that what about the fact that the truck is all over the road while driving. it isn't terrible but I have to continuously make adjustments to stay straight.
  9. Apr 30, 2018 at 4:32 PM
    Juddy1986
    Justin
    2000 Tacoma
    Lifted
    im thinking that the steering box is worn
  10. Apr 30, 2018 at 5:03 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
  11. Apr 30, 2018 at 5:08 PM
    jmaack
    Justin
    Helena Alabama
  12. Apr 30, 2018 at 5:13 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    What in the 2 teeth having, shake and bake meth making, trailer park double wide living, mullet and overall wearing, my dad is my cousin, kind of cluster is this?
    jmaack likes this.
  13. Apr 30, 2018 at 5:49 PM
    tony2018
    tony2018 Well-Known Member
    Man, you'll need to source the original top mounts if you plan to put it back to stock.
  14. Apr 30, 2018 at 6:53 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  15. Jan 28, 2019 at 9:48 PM
    #35
    kohle20
    kohle20 Member
    jk
    96 tacoma
    before you remove lift can you please post pics of how your front diff is mounted please!!!
  16. Jan 28, 2019 at 9:49 PM
    #36
    kohle20
    kohle20 Member
    jk
    96 tacoma
    and ive been able to source the secondary struts and top mounts to a 89-91 vw jetta passat and corado
  17. Jan 28, 2019 at 11:26 PM
    #37
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    You are going to fight an uphill battle to find parts that will work.
    Two options, well three as I see it.
    1. Replace the lift kit with some other more classical 6 inch drop bracket lift, They cut a cross member to put this lift on, therefor there is no going back to stock unless, as was mentioned before you cut the missing segment out of another frame.
    2. Throw parts and try to shimmy this terrible lift back together
    3. Straight axle. Which not only is a huge jump in skillset and technically ability, it will be very costly.
    My opinion is that option one is your best bet, start trying to find a 6 inch fabtech lift kit, and because you are going to need to spend money on UCAs, might as well go aftermarket and get adjustable.
