I have an air bubble in my heater core.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Mar 25, 2016.
  1. Mar 25, 2016 at 2:23 PM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I've been dealing with this since the frame was replaced. I hear it if I am starting off slowly. I do not hear it on the highway. It has been a couple of weeks and I was hoping use would push it through the system and out. It has not, any suggestions on what I can do to remove it?
    Thanks
  2. Mar 25, 2016 at 2:43 PM
    NM Lance
    NM Lance Well-Known Member
    Are you having any issues with overheating? Park your truck slightly uphill, pull your radiator cap and run the engine until your thermostat opens, then top off as needed. This should solve it.
  3. Mar 25, 2016 at 2:46 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Park uphill slightly. With coolant cold, add coolant, replace cap, go for drive.
    Repeat until air gone. Easy.
  4. Mar 25, 2016 at 2:51 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I thought the same thing. Do you hear it on the passenger side or general dash? Mine was an a/c line that "was leaking", I assume they pulled it and it started leaking.. Replaced, Evac, and refill and my noises are gone.
  5. Mar 25, 2016 at 3:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    How did you diagnose that was what the noise you hear was?
    I'm not saying it's not. But I will say it's more likely to be something else.
  6. Mar 25, 2016 at 4:06 PM
    Larzzzz
    Larry
    MA
    I say it's in the heater core due to the fact I hear it when parked. The trucks 3 weeks out from a frame swap and I heard it later after I picked it up. And, I've already dealt with the A/C drain hose issue. Different sound all together.
    What do you think it is?
  7. Mar 25, 2016 at 4:17 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  8. Mar 25, 2016 at 6:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    Dunno. If it's a bubble, it should be very easy to solve in the fashion others have mentioned. And since it's free, certainly worth a try. I've always heard of air pockets in cooling systems, just never have had one.
    Any chance when you hear this the vehicle is running and the AC is on? Expansion valves make odd noises when they operate sometimes.
    Is the AC working ok? Since it had to be opened for the frame swap, it's another area subject post swap issues if not handled well.
  9. Mar 25, 2016 at 6:37 PM
    Crom
    Nick
    San Diego, CA
    Millions
    My air bubble was the result of flushing the coolant at 50K miles. Zerex Asian went in. Easy fix.
  10. Mar 25, 2016 at 7:23 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Honestly air bubble should be gone pretty quickly, what year is your truck? Early 05-06 are prone to head gasket which would do the bubble in core.
    Weissenheimer likes this.
  11. Mar 26, 2016 at 6:10 AM
    Larzzzz
    Larry
    MA
    It's an 06 dclb 4wd 4.0. At present, 225162 on the odo. No steam other than condensation when it's cold. After an hour of stop and go traffic, the scan gauge still reads 180°, and the pod gauge doesn't move once it gets to temp.
    I would have thought the bubble would be gone by now myself but I still hear the water running through the pipe. Driven a few hills, haven't parked on one. The coolant reservoir was over full when I picked it up from the frame swap. Makes me think they know it was in there.
  12. Mar 26, 2016 at 11:08 AM
    Larzzzz
    Larry
    MA
    Haha, you a funny guy. It's still, kinda, winter here in the Northeast.
    I want the warmer weather now with the mild winter we had here. I wanna be on the boat. Not quite speedo weather here though.
  13. Mar 26, 2016 at 11:18 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
  14. Mar 26, 2016 at 1:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    I get it. It's why I'm grateful my parents moved to Florida over 60 years ago.
    So, doesn't the AC engage in the defrost setting? Again, not saying that's what it is, just exploring possibilities.
  15. Mar 26, 2016 at 3:56 PM
    Larzzzz
    Larry
    MA
    I have no idea if it does other than everything(fan on hi, max heat, and defrost) maxed out. I rarely ruin max heat. Pointed to 2-3 o'clock and it's more than enough.
  16. Mar 28, 2016 at 7:45 AM
    BlueT
    NorthEast
    I hope this is not head gasket, but I would consider this a possibility. It could be super early stage. You need to do leak down test when engine is cold and when engine is warm.
    Bubbles from core would escape pretty quickly, but persistent bubbles usually means engine is spewing something into coolant line.
  17. Mar 28, 2016 at 9:29 AM
    UltraE05
    UltraE05 Well-Known Member
    2010 Tacoma Crew Cab
    Thats signs of a head gasket, heater core is highest point in the cooling system. It making the bubbling noise is a huge indicator.
  18. Mar 28, 2016 at 3:20 PM
    Larzzzz
    Larry
    MA
    I hope it's not a head gasket either. Not losing any antifreeze though. It's not mis-firing, spewing steam out the exhaust. Maybe it's time to pull the plugs and put a radiator cap tester on...
    It's not a bubbling noise I hear. Sounds more like a forced hot water boiler system with air in the radiator. You can hear the water flowing. I only hear it when starting off or parked and giving it a little throttle
  19. Mar 28, 2016 at 6:11 PM
    UltraE05
    Unfortunately that is a symptom of a head gasket. My ranger did the exact same thing, so i know exactly what you mean unfortunately. Head gaskets are common on the earlier tacomas. Sorty dude but start planning on pulling the heads off
    BlueT likes this.
  20. Mar 28, 2016 at 6:25 PM
    Larzzzz
    Larry
    MA
    Shush you. Lol
    Wouldn't I be losing antifreeze? My temp is steady at 181° and the over flow bottle is still over full from the dealer with the frame replacement.
    I drove around with a loose radiator cap and found the steepest hill near me and sat for a few. Several sustained revs above 3k and about 10 minutes sitting... Tightened the cap and went home. I'll find out in the morning if that did anything to purge the air.
