I installed my Curt receiver hitch today.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by snefo, Dec 19, 2015.
  1. Dec 19, 2015 at 5:12 PM
    snefo
    snefo [OP] Well-Known Member
    Was pretty simple. Fishing the bolts through the existing bumper tube was a little tricky as there are some small bolts that stick down into the tube and get in the way. I had to loosen the 6 bolts that hold the stock bumper so every thing would mate up. The bolts started to get tight before the mating surfaces met. I loosened all the bolts, tightened the new receiver bolts and then tightened the factory bumper bolts. 86 ft. lbs is a hell of a lot of torque when you are laying on your back. I was going to post some photos but my computer is being contrary. I the hitch from etrailer for $167. Still waiting for wiring to become available.
    chealy86 likes this.
  2. Dec 19, 2015 at 6:35 PM
    jeepinoutwest
    jeepinoutwest Well-Known Member
    Please update when the wiring becomes available. I will be adding the same hitch.
  3. Dec 19, 2015 at 10:18 PM
    snefo
    Will do.
  4. Dec 20, 2015 at 5:22 AM
    chealy86
    chealy86 Well-Known Member
    South Carolina
    2016 SR 2.7L 6spd
    So etrailer has them in stock and shipping now? Sweet!
  5. Dec 20, 2015 at 5:32 AM
    Clearwater Bill
    Billy
    Largo Florida
  6. Dec 20, 2015 at 6:08 AM
    chealy86
    South Carolina
    2016 SR 2.7L 6spd
    E trailer has a used one for a 2016 listed for $122......weird
  7. Dec 20, 2015 at 3:05 PM
    BritInTX
    BritInTX New Member
    Had my Curt receiver hitch installed on my 2016 Taco Friday, together with wiring and a brake controller. Hitch company couldn't get power to the 7-pin (or 3). Really frustrating. They're going to call Curt in the morning but I plan to call both Curt and Toyota first thing to see if they can help. The mechanic mentioned it could be a fuse issue or something. If anyone has any suggestions I'd be grateful....
  8. Dec 21, 2015 at 10:23 AM
    beenjammin
    beenjammin Well-Known Member
    Auburn, AL
    2016 TRD 4x4 ORDCSB
    Yes same here. Thanks for the thread.
  9. Dec 23, 2015 at 7:32 AM
    wareagle6
    wareagle6 New Member
    Robert
    2016 SR5 Access Cab
    Glad to hear the Curt hitch fits up OK as I just rec'd my hitch as well. I called Curt on availability of the T connector wire harness and was told it is designed, parts ordered and should be available in January. If you are in hurry, etrailer sells the "splicable" 4 pin flat wire harness but I personally would rather not splice into the factory wire harness......besides it is too cold and rainy to fish right now anyway.
  10. Dec 23, 2015 at 8:03 AM
    BritInTX
    BritInTX New Member
    Went back to the hitch shop and it turns out it was a grounding issue. they fixed it in 30 mins after they spoke to Curt tech support. My 2016 Tacoma now has a hitch and electrics!
  11. Apr 4, 2016 at 7:52 AM
    sundogbrew
    sundogbrew Well-Known Member
    Joe
    2016 Blue TRD OR Double Cab
    I added this hitch to my truck, it was pretty easy. The fishing wire for the bolts in ingenious! I say that now because I am done. There were a few tense moments where new words were made up and new ways to use old ones were figured out but all and all not that bad a job and it looks good.
