I just got a code P2445
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chueflee, Sep 30, 2019.
  1. Sep 30, 2019 at 9:48 PM
    chueflee
    chueflee [OP] Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    I just got a check engine light on my 2013 tacoma. The code is p2445. So my secondary air injection is stuck off. Is there fuse I can check 1st before I take take the pump apart?
  2. Sep 30, 2019 at 9:52 PM
    Bishop84
    Bishop84 Well-Known Member
    Rarely fuses, usually is due to moisture in the system causing the valves to stick open or closed.
    The pump is probably fine, its the valves that need to be disassembled and inspected for water.
  3. Sep 30, 2019 at 10:00 PM
    chueflee
    Chue
    yeah it was 90 degrees today and then quickly dropped to 60 degree. Weird wisconsin weather.
  4. Sep 30, 2019 at 10:19 PM
    chueflee
    Chue
  5. Oct 1, 2019 at 7:43 PM
    chueflee
    Chue
    I reset the code today. It has not come back yet
  6. Oct 1, 2019 at 9:07 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  7. Oct 1, 2019 at 9:08 PM
    BassAckwards
  8. Oct 1, 2019 at 10:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Markcal likes this.
  9. Oct 1, 2019 at 10:56 PM
    chueflee
    Chue
    Yeah I can ask if the check engine light pops up again. But.. the stealership is hard to get them to fix anything... even if it's cover under warranty. I rather just delete the sencondary air injection system. It does nothing.
  10. Oct 2, 2019 at 12:12 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Go to another dealer...
    Do what you desire it is your truck.
    Markcal, Sugar Silva and super_white like this.
  11. Oct 2, 2019 at 2:39 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    HPTuners is the way to go, then...
    I plead the 5th on having any first hand knowledge on this working for a 2013... :anonymous:
    BassAckwards likes this.
  12. Dec 9, 2019 at 9:38 AM
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    Hewitt makes a 13-15 kit now. Plug and play. Works great on mine!
    hewitt-tech likes this.
  13. Oct 12, 2022 at 12:08 PM
    hewitt-tech
    hewitt-tech Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @Nachomama2001 We appreciate you recommending the HT SAIS Bypass Kit. Wanted to provide some additional resources for anyone comes across this thread in the future.
    What Does the Secondary Air Injection System Do?
    https://www.tacomaworld.com/threads/what-does-the-secondary-air-injection-system-do.780847/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tacomaworld.com/threads/what-do-my-secondary-air-injection-error-codes-mean.780848/
    How to Fix Secondary Air Injection System?
    https://www.tacomaworld.com/threads/how-do-you-fix-the-secondary-air-injection-system.780849/
