I know I know, but someone please help me
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Poe, Apr 16, 2014.
  1. Apr 16, 2014 at 4:31 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    Ok so i order 4 of the XD Hoss rims 16x8 6 on 5.5. I need to know what lugs to get that will work with these. This I have no idea what im doing.. haha so will someone please link me and inform me on this. Is it shank Lugs or Acorn Lugs?
    Truck specs
    2014 4x4 base access cab
    Rim specs
    Wheel Size: 16x8
    6 on 5.5 Bolt Pattern
    Offset: 0
    Backspace: 4.5
    LINK TO THE RIMS http://www.4wheelparts.com/Wheels/X...=11&t_s=210&t_pt=100106&t_pn=W/PXD79568068300
    Like i said this is the last thing i need so i can put these on finally.
  2. Apr 16, 2014 at 4:47 PM
    moondeath
    moondeath The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If those wheels are not hub centric, then you'll need something like this. Mine weren't, so this is what I needed. My wheels have the same overall specs as your wheels.
    You would also need the lug spline key.
  3. Apr 16, 2014 at 4:55 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    Would it make a big difference if its Hub Centric or not? What does that really mean, and ok thanks so i would just need 24 of those and the tool correct. Did you have any problems with rubbing on your break caliber. Do you think i will need tire spacers
  4. Apr 16, 2014 at 5:07 PM
    moondeath
    Pa, Carlisle
    Ok, so the factory wheels are hub centric. This means that the center of the wheel mounts perfectly to the hub of the truck. The small hollow circle in the center of the wheel fits over the center circular hub in the center of the brake rotor or drum.
    A non hub centric wheel has a larger hole in the center of the wheel that does not match the factory hub.
    This means that the wheel could be mounted at an offset and not spin correctly. If you were to spin it, it would wobble up down and side to side.
    To make sure this doesn't happen, you use a specific lug nut, which is those lugs nuts in that link. They have a sleeve that fits into the stud holes of the wheel and align the wheel to the mounting surface. If you use the factory nuts you may not get a correct mount.
    My wheels fit fine over the calipers. Some 16" wheels don't.
  5. Apr 16, 2014 at 5:09 PM
    T-Rex266
    T-Rex266 Moderator Moderator
    Solid post ^^^
  6. Apr 16, 2014 at 5:11 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    Ok thank you very much that helped me with all my questions. I will be ordering the ones in the link you sent me
  7. Apr 16, 2014 at 5:16 PM
    moondeath
    Pa, Carlisle
    Glad I could help.
