I loaded up my truck with dirt and wood
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hotdog, Feb 18, 2008.
  1. Feb 18, 2008 at 2:03 PM
    Hotdog
    Hotdog [OP] My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    After I got the suspension TSB done, I wanted to test it out. I went down to the Bonnet Caire Spillway and loaded it up with some dirt and then I decided that I could use some more weight. I stopped by Lowe's and bought some wood for shelves in my shop.
    Everything loaded up
    Getting close to the bump stops
    This is after I took out the wood
    This is with the empty bed
    I almost got stuck, but I managed to escape
  2. Feb 18, 2008 at 2:32 PM
    khfactor
    khfactor Well-Known Member
    Philadelphia, PA
    07 White TRD Sport
    Pop N Lock + Hose Clamp. DTRL, AFE drop-In Dry filter, 6-1/2" Replacement Speakers, JVC HD Radio, Sam's club variety Floor mats (cheap but effective), Chrome Exhaust tip, Bed Mat from ol' Ford Ranger. As of 3/25/2020, the Odometer just turned 70K.
    Glad to see the Leaf Spring TSB is paying dividends.
    How many lbs would you have guesstimated were in the bed including wood?
    Judging by the pics (not seeing loaded up bed photos did not help), in excess of 500 lbs or more ????
  3. Feb 18, 2008 at 2:49 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm not sure about the weight. I bet the mud alone weighed at least 650 lbs.
  4. Feb 18, 2008 at 2:54 PM
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    Great photos.... Now I have a comfort knowing that I can safely transport some decent weights in the bed without worrying about the bed bottoming out.
    Cheers for the TSB !!;)
  5. Feb 18, 2008 at 4:10 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Good for you, glad to see all is well !
  6. Feb 18, 2008 at 11:22 PM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    That looks more like 500lbs of shit. :)
  7. Feb 19, 2008 at 3:36 AM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    it's doo-doo baby!
  8. Feb 19, 2008 at 6:42 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'd rather shovel shit than this stuff. The clay just sticks to everything it touches. It took about one scoop to coat the shovel and then that weighed 25 lbs.
    But this is the stuff you want under your house, which is where I put it.
  9. Feb 19, 2008 at 7:46 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i'm not sure if you realize this, but there should already be dirt under your house. You dont need to add it yourself....
    Unless you have one of those fancy houses with the concrete crawl space, then i recomend putting as much dirt as possible under there
  10. Feb 19, 2008 at 7:51 AM
    wshsbears
    wshsbears Member
    central FL
    07 RR X-Runner
    C2C drop, BHLM, FL mod, Brembo drilled/slotted rotors, tailgate spoiler, CAI, TBS, rearview camera, bed net, Pioneer AVH-P5700 DVD, Cadence amp, xtreme creations with 10's and eclipse components, eclipse 4 chan, TTC dual traction bars, C2C eyelids, 8K HIDS, PA, Train horn, red gauge cluster LED's
    i've had 40 bags of mulch in my bed (filled it over the top) and im lowered 2" in the back and i was sitting about as far away from bump stops as u were fully loaded. thats a pretty good amount of payload u had there!
  11. Feb 19, 2008 at 8:27 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I have a raised house but there are some low areas under my house that collect water. I'm trying to eliminate that by throwing some clay under there.
    How much does a bag of mulch weigh? How much clearance do you normally have on between your bump stops?
  12. Feb 19, 2008 at 3:02 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    After calling the Toyota 800 number to complain about my initial attempt at the leaf spring TSB, I got a call back today. They said they don't the the TSB will help my situation (bottoming out with 500lb load) since it's for an unloaded condition, but as a courtesy they offered the TSB to me if I wanted it. I said "sign me up" Even if they don't think it will help, how can an extra spring not help. Now this thread is picture proof. Thanks, lsocoee, you're a good guy no matter what ndcouch says about you.
  13. Feb 20, 2008 at 6:21 AM
    nd
    Nate
    Greenville, SC
    I wouldn't have to say bad things about him if the little bastard would go ahead and join my Alliance
  14. Feb 20, 2008 at 6:46 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    FREEDOM!!
    I'd rather drink warm flat beer before joining the alliance.
