I made a thing for switches because the thing I wanted didn't exist.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forty2, Feb 11, 2016.
  1. Jul 6, 2016 at 10:07 AM
    #201
    TXTRDSport
    TXTRDSport Member
    Justin
    2016 DCLB TRD Sport Blazing Blue
    Ordered! Thanks OP!
    forty2[OP] likes this.
  2. Jul 6, 2016 at 1:03 PM
    #202
    forty2
    forty2 [OP] Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Good idea, I'll update the first post later today.
    jkcashin[QUOTED] likes this.
  3. Jul 6, 2016 at 1:08 PM
    #203
    '16TacomaTRD
    '16TacomaTRD Well-Known Member
    2016 White Tacoma TRD Sport w/ premium tech & JBL package
    Where do you get the buttons?
  4. Jul 6, 2016 at 4:04 PM
    #204
    opentang
    opentang you're doing a good job
    Brandon
    2020 T4R TRD PRO
    What is the best way to tie in four new air on board switches to the truck's native illumination when ignition is on? I was hoping someone may have a quick write-up or diagram showing how it was accomplished.
    3 new switches in the 3 panel option + 1 new switch for the blank to the left of steering wheel.
    MoQS likes this.
  5. Jul 13, 2016 at 3:54 PM
    #205
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    Looking for a switch that will fit the 3 hole unit that is backlit blue, and says "Bed Lights" or something to that effect. Any recommendations?
    MoQS likes this.
  6. Jul 13, 2016 at 4:14 PM
    #206
    opentang
    Brandon
    2020 T4R TRD PRO
  7. Jul 13, 2016 at 4:15 PM
    #207
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
  8. Jul 13, 2016 at 6:18 PM
    #208
    TXTRDSport
    TXTRDSport Member
    Justin
    I ordered mictuning off Amazon.
  9. Jul 13, 2016 at 7:34 PM
    #209
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    Should be one on eBay
  10. Jul 20, 2016 at 7:48 AM
    #210
    WILDPEAK
    WILDPEAK Well-Known Member
    Drew
    Rancho Cucamonga, CA
    '16 TRD OFF-ROAD
    LT265/75R16 WILDPEAK AT3W
  11. Jul 20, 2016 at 2:54 PM
    #211
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
    I don't have the pic u want. But have seen it on another members truck and it looks good. The only thing that does not match is the color of the back lighting. I'll look for the thread.
    Here's that thread.
    https://www.tacomaworld.com/threads...le-how-to-access-behind.407870/#post-11545579
  12. Jul 23, 2016 at 8:52 PM
    #212
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Maybe I missed it in the thread but did anyone do a write up on how to install this? What do I have to pull apart to get the little cubby out and get the panel in?
    2016Tacoman likes this.
  13. Jul 23, 2016 at 9:12 PM
    #213
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Same her, I really don't see how this is fitting in that cubby.
    Toynado[QUOTED] likes this.
  14. Jul 23, 2016 at 9:17 PM
    #214
    Toynado
    SF Bay Area
    I know the cubby comes out and this goes in, I just want to make sure I don't mess anything up doing it.
  15. Jul 24, 2016 at 1:02 AM
    #215
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    I'm sure it's in the thread somewhere, but I just pulled it today for another reason, so I'll fill you in.
    The whole assembly with the cubby and the stock switches below comes out as a unit. It is just held in with clips, so I gently pried it out with a trim tool, but you could use a small flat screwdriver (carefully).
    Once the assembly is out, you remove the cubby from the back of the assembly. I didn't do it, but it looks like it's held on with 4 Philips screws.
    Looks to be a quick and easy job.
    Toynado[QUOTED] and schmack b like this.
  16. Jul 24, 2016 at 3:07 AM
    #216
    opentang
    Brandon
    2020 T4R TRD PRO
    This is correct and takes less than 5 minutes to swap out
    Toynado likes this.
  17. Jul 24, 2016 at 11:20 AM
    #217
    caribe makaira
    Caribbean, Puerto Rico
    https://www.tacomaworld.com/threads...-cab-cargo-light-switch.436440/#post-12744533
    glider_guider[QUOTED] likes this.
  18. Jul 24, 2016 at 11:38 AM
    #218
    caribe makaira
  19. Jul 25, 2016 at 6:16 AM
    #219
    glider_guider
    glider_guider Well-Known Member
    2016 Red Tacoma TRD OR 4x4
    Awesome! Thanks!
  20. Aug 4, 2016 at 10:49 AM
    #220
    TALON
    TALON Well-Known Member
    Las Vegas, NV
    2016 WHITE TACOMA TRD OFF-ROAD
    HID headlighs, LED fog, tint, LED interior, Caliraised stealth lightbar, k&n filter, Flagpole mount,
    Installed mine last night. Great fit and easy to install.
    Totally worth the money!
    vinkon235 likes this.
