I made a thing for switches because the thing I wanted didn't exist.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forty2, Feb 11, 2016.
  1. Dec 14, 2016 at 2:27 PM
    #341
    mrnoodley
    mrnoodley Well-Known Member
    Michael
    Toms River, NJ
    2017 Quicksand TRD OR
    Yeah. I just wanted to make sure I ordered the right ones and was getting confused. I figured you guys would know.
  2. Dec 14, 2016 at 2:28 PM
    #342
    mrnoodley
    Michael
    Toms River, NJ
    Are the cruiserheads switches nicer than the cheap $4 ones from Aliexpress or DHgate? I don't mind spending $20 a switch, as long as they're nicer.
  3. Dec 14, 2016 at 2:53 PM
    #343
    forty2
    forty2 [OP] Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    I've gotten a few from AliExpress and they were all shit. The plug on the back was identical to the other ones I've had but the switch action simply wasn't smooth and the compressor switch eventually just stopped working after only a few months worth of use. That happened in the middle of a big offroad trip so I spent the last couple days hot wiring the compressor every single time I wanted to air back up coming off the trail. YMMV
  4. Dec 18, 2016 at 11:04 PM
    #344
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Here's the latest: Using Hondo Garage vent mount as a start I printed a holder for my 440/2m radio.
    Also, I made a little stepped bushing for the back of my radio, didn't quite plan right so I had to modify it a little bit.
    Radio mounted, holds pretty tight and removes quickly and easily for stashing away. It's a pretty tight fit and hopefully it'll hold up well over time.
  5. Dec 18, 2016 at 11:42 PM
    #345
    Taco16Jessy
    Taco16Jessy Well-Known Member
    Jessica
    Damn Corn Desert/Missing MO
    2016 BBP 4x4 AT-OR-DCSB
    Now accepting monetary donations for mods!
    Has anyone developed or know if there's a way to add switches to the area below the temperature controls? I have an offroad so all I have down there is the ECT, QI, and usb ports. There's got to be room for at least 4-5 switches down there.
    I've got no clue on wiring so don't hound me if this is impossible. I just know when all is said and done I will want more than the 3 switches I can hide in that useless cubby this fills up.
  6. Dec 19, 2016 at 6:48 AM
    #346
    Cold_Toad
    Cold_Toad Well-Known Member
    Have a read through this thread, should have everything in it that you are looking for
    https://www.tacomaworld.com/threads...d-open-aux-switches-for-mounting-help.409697/
    Taco16Jessy[QUOTED] likes this.
  7. Dec 19, 2016 at 7:28 AM
    #347
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2012 DCSB TRD OR
    Does anyone make wiring harnesses for light bars and ditch lights that will plug directly into one of the Mictuning style push switches?
  8. Dec 19, 2016 at 7:31 AM
    #348
    Cold_Toad
    @CaliRaisedLed I believe is in the process of offering a wiring harness that comes with a Mictuning style of switch.
  9. Dec 19, 2016 at 7:35 AM
    #349
    I'mTheDude
    Hickory, NC
    2012 DCSB TRD OR
    I saw their production was pushed back so I was curious if there were any other makers out there. Thanks!
  10. Dec 19, 2016 at 3:31 PM
    #350
    Soccer Mom
    Soccer Mom Well Endowed Member
    2017 MGM SR5 DCSB
    METHOD | SOS | C4 | RIGID | PRINSU | OME | TC
    Just ordered a panel. Thanks
    forty2[OP] likes this.
  11. Dec 19, 2016 at 6:24 PM
    #351
    moser633
    moser633 2016 TRD OR AC
    2016 magnetic grey Tacoma TRD Offroad
    Aux Reverse Lights, tailgate inserts , TRD PRo Grill, Truxedo lo pro gt tonnaeu cover, Cali Raised led Apex stealth light bar Cali raised led Ditch Lights ARB on Board air Method NV Bronze 16 in with 265 75 16 Cooper STT Pro
    Just ordered a 3 switch panel. Thanks
  12. Dec 19, 2016 at 6:26 PM
    #352
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Mine shipped today...
    :thumbsup:
  13. Dec 21, 2016 at 6:25 AM
    #353
    forty2
    Cascadia
    2016 DCSB OR 6MT
    FYI - Shapeways has a 20% off coupon code running for strong & flexible plastics (which the black that almost every order has been so far is) through the end of the year. Code is FAREWELL2016
  14. Dec 21, 2016 at 6:38 AM
    #354
    Truggin
    Don
    Dam... and I missed it. Oh well.
  15. Dec 21, 2016 at 12:37 PM
    #355
    Soccer Mom
    2017 MGM SR5 DCSB
    What switches fit in the OEM slots? Your 400w and clutch start kit?
    The clutch start kit looks like the CH4x4 Push Switch (39mm x 21mm) but what size is the 400w button?
  16. Dec 21, 2016 at 1:13 PM
    #356
    PowerGuy
    PowerGuy Well-Known Member
    Mac
    Holden Beach, NC
    17 TRD OR Access Cab, 4x4
    FN FX Pro wheels/265/70/17 Nitto Terra Grapplers G2
    Discount put me over the edge.
  17. Dec 21, 2016 at 2:30 PM
    #357
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Clutch start cancel switch size:
    Inverter switch size:
    Soccer Mom[QUOTED] likes this.
  18. Dec 28, 2016 at 12:09 PM
    #358
    mmessier2
    mmessier2 Well-Known Member
    17 Sport DCMTSB
    Got mine installed and I love it:
    forty2[OP] and moser633 like this.
  19. Dec 30, 2016 at 11:15 AM
    #359
    2016 Tacoma 387
    2016 Tacoma 387 Active Member
    Terry
    Philadelphia, PA
    2016 Tacoma TRD Sport 4x4 DCLB / 2001 Reg Cab, 5 lug, 4 banger.
    Question: I wanna buy this, but for the install what has to be done? Does the little switch area pop out and I can access the little cubby that is currently there and remove it, or do I have to pull down the entire bottom dash board area?
  20. Dec 30, 2016 at 11:59 AM
    #360
    mmessier2
    17 Sport DCMTSB
    You have to pull the bottom dash, but its only 3 bolts and one plastic screw. It takes like 2 minutes... to install the plate just unscrew the 4 small screws from the factory and pop in the new one.
