I made a thing for switches because the thing I wanted didn't exist.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forty2, Feb 11, 2016.
  1. Apr 7, 2017 at 6:51 AM
    #501
    forty2
    forty2 [OP] Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    ARB switches are Carling style and are simply to big for the location without cutting into the surrounding panel so none of the switch panel are designed to for them. I know there's one person somewhere in this thread that modified a panel for Carling switches but it took some butchery to get there.
    RIDERED67[QUOTED] likes this.
  2. Apr 7, 2017 at 7:04 AM
    #502
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Thank you
  3. Apr 7, 2017 at 7:55 AM
    #503
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    Toyota push button switches are the only way to get 3 switches into the cubby. You might get 3 rockers in there but it's going to be jammed and probably won't work well or look that great.
  4. Apr 7, 2017 at 8:38 AM
    #504
    Rhubarb
    Rhubarb Well-Known Member
    Big D (TX)
    2016 OR, Manual Trans
    Can someone please take a simple picture of where you place the pry tool to remove the cubby hole on the '16 OR manual transmission? I don't want to beat the hell out of the panel by prying the wrong part. I just received the three-switch panel and am eager to get going.
  5. Apr 7, 2017 at 9:11 AM
    #505
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
  6. Apr 8, 2017 at 7:35 AM
    #506
    Rhubarb
    Big D (TX)
    Bump for picture of where to place the pry tool to remove the cubby compartment from dash.
  7. Apr 8, 2017 at 8:07 AM
    #507
    gorram
    gorram Well-Known Member
    2016 Limited
    I pulled that off two different times and it seemed like the second time it didn't want to pop off as easy because the tabs are pretty strong. Stealing the image from the OP:
    The bottom left tab is right below where "off" is on the switch above. The top one would be about that same place. You should be able to scoop a curved pry tool on the side or bottom middle of it to get it hooked, and start working it to pop loose. This is the kind of panel where a couple of pry tools may help as you can keep one jammed in bottom preventing a tab from locking itself back in place as you work another pry tool around the rest of the edges.
    In the end when you really just need to give it a pull as the tabs are pretty resilient and wont want to just pop off easy like a lot of the other trim like the radio bezel or window switches.
  8. Apr 8, 2017 at 9:52 AM
    #508
    Rhubarb
    Big D (TX)
    Many thanks, gorram, for the explanation. If I get time today, I will try. If it works, will snap a picture.
  9. Apr 11, 2017 at 9:43 AM
    #509
    Teknicl
    Teknicl Northern California
    2017 Tacoma TRD Pro
    Nothing yet - just got it two days ago!
    Where to pry....
    The best place is from the top. The center of the top doesn't have any attachment clips. The clips are to the right and left.
    Place your pry tool in the blue circled area. The clips are located at the sides (blue arrows):
    Here is a view of the top. You can see that there are no clips. Insert your pry tool there, get your fingers in (eventually!) and pull out + down.
    POP.
    Out it comes.
    I hope that helps.
  10. Apr 11, 2017 at 2:36 PM
    #510
    Rhubarb
    Big D (TX)
    Excellent! Thanks, Teknici!
  11. Apr 15, 2017 at 10:17 AM
    #511
    2003 4x4
    2003 4x4 Well-Known Member
    2003 taco 4x4 & 2017 TRD OFFROAD
    If the replacement switches are brighter than the factory switches, couldn't you wire the switch led's in series? Wouldnt 3 in series be 1/3 as bright? Can someone with electrical expertise verify this?
    sierra.grit likes this.
  12. Apr 17, 2017 at 3:34 PM
    #512
    Metonymy
    Metonymy Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
    Three questions:
    1) Where's the best place to buy the smaller push-button style switches for the 3-switch panel (which I just ordered)
    2) Do the push-button style switches illuminate when the dash lights are on (presuming you wire it to a key-on source)?
    3) Will the push-button switches still operate the attached accessory (lights, etc.) even when the keys are off presuming the other pin is wired to a constant-hot source?
    (I'm not an electrical expert, thus the rookie questions. Want to do this the right way obviously!)
  13. Apr 17, 2017 at 3:49 PM
    #513
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
    1. CH 4x4 or Mictunning
    2. Yes, if u buy those switchs
    3. Yes
  14. Apr 19, 2017 at 9:40 PM
    #514
    hellaflushca
    hellaflushca @truck_norriz
    So the panel came with the bezel behind it? Everything online doesnt really show.
  15. Apr 20, 2017 at 5:50 AM
    #515
    Blktre
    Land of Oz....
    Seems you pop the OEM bezel off the dash and this panel goes in behind it then pop the OEM bezel back into the dash.
  16. Apr 20, 2017 at 11:55 AM
    #516
    oilslick
    oilslick Slicker than shnot!!!
    Big John
    northeast Pa.
    2017 DC 4x4 Sport
    Light Bar w/4 KC Off Road lights,
  17. May 14, 2017 at 6:40 AM
    #517
    hellaflushca
    It's super easy. Whichever one you guys get from shapeways (2 or 3) panel for the left hand side cubby replacement.
    1. Stick a small flat head on the panel corners and pop it out
    2. 4 screws hold the cubby in (Phillips)
    3. Unscrew and put shapeways Bezel in, fits like a glove.
    Panel come off extremely easily just be gentle lol.
    Pic on next reply
  18. May 14, 2017 at 6:41 AM
    #518
    hellaflushca
  19. May 14, 2017 at 10:45 AM
    #519
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Really liked the FC Truggy Video.
  20. May 18, 2017 at 3:47 PM
    #520
    THATCH11B
    THATCH11B Well-Known Member
    Limerick Pennsylvania
    2017 Tacoma TRD Pro - SOLD
    Mobtown sliders, bed extender, Extang Encore tonneau cover, Husky x-act fit mats, 3M FX Premium 25 tint, Bedrug mat, 255/85r16 ST MAXX’s, Rok Blokz, Rigid Industries 30 inch bumper mount and ditch lights, Subaru tweeter upgrade, MESO LED turn signal upgrade, TRD CAI, MESO LED map/dome, VLED’s exterior LED’s, Weathertech window vents, Redline struts, engine bay LED’s, seat spacer mod, 3x remote start, Mobtown CMC, Mobtown locking storage doors, Prinsu Cabrac, SPC UCA’s, ADS 2.5 remote reservoirs w/adjusters front /rear, 700 # springs, OME Dakar HD leafs, extended brake lines, u bolt flip, bump stops front(Plastic guy’s)/rear(Timbren), ECGS bushing, sway bar delete. Yotaled’s raptor light kit, Method Racing MR701’s, Rondo radio knobs
    Don't know how I missed this but I did. I ordered but luckily did not install the 3 switch metal plate. I'd rather not put 4 drill holes in the dash when I don't need to. Just ordered this plate. Excited but now my lighting project must wait until this plate comes.
