I made a thing for switches because the thing I wanted didn't exist.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forty2, Feb 11, 2016.
  1. Apr 1, 2016 at 2:16 PM
    #121
    FtApache
    FtApache Well-Known Member
    2019 Raptor
    I received two boxes from Shapeway today with the same order number. Each box has a different part. Anybody know what the other thing is?
  2. Apr 1, 2016 at 2:35 PM
    #122
    forty2
    forty2 [OP] Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    No idea. Not one of mine...
  3. Apr 1, 2016 at 2:36 PM
    #123
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Shape reminds me of an old light meter I had.
  4. Apr 1, 2016 at 2:39 PM
    #124
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    The machines have become sentient and are attempting to emulate us. Run
  5. Apr 2, 2016 at 7:50 PM
    #125
    beenjammin
    beenjammin Well-Known Member
    Auburn, AL
    2016 TRD 4x4 ORDCSB
    Tagging this thread. Anyone know if the katskin heater buttons will fit this? I would love to utilize the 3 button for my heaters and lightbar.
  6. Apr 6, 2016 at 11:55 AM
    #126
    TacoinMD
    TacoinMD Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    Picture heavy post coming...
    Using the Shapeways narrow switch plate, 18 separate 5mm blue LEDs, 2 Mictuning switches and 3 long days I made the interior of my ruck look as close as I could to the flight deck of a commercial aircraft.
    While the door panels were off, I installed a product called, "GT Mat" an 8mm thick adhesive sound installation. Extremely quite ride now.
    Pics:
    #1 Before the narrow switch plate was installed.
    #2 Driver's side lower kick panel removed to install new switch plate.
    #3 Mictuning 3amp push switch installed as well as the digital AMP gauge.
    #4 Same as above, different view.
    #5 Amp gauge.
    #6 Dash lights on, only the bottom of the light switch is illuminated. To illuminate with dash lights on, tap into the green wire in the harness that services the bed light rocker switch.
    #7 Switch activated with power going to the LED lights which were installed in the center console and all 4 doors. In the doors the LEDs were installed at the top of the exit handle, the door pull pockets and cup holder pockets.
    #8 Night view of two cup holders behind the center console armrest.
    #9 Night view of front passenger's door.
    #10 Night view of center console.
    #11 Night view of driver's door. ** The rear doors are illuminated exactly as the front doors **
    #12 Not the best pic, night view of the inside of the center console storage box. The LED is dead center in the rear of the box.
    The switch that operates the LEDs is rated at a max load of 3amps. All 18 5mm LEDs have a total combined amp draw of less than 1amp, no need to install a relay. The LED switch was wired using an add a fuse kit with the smallest fuse I could buy, a 2 amp fuse. The add a fuse kit is installed in power outlet fuse #1 under the dash.
    The AMP gauge is powered by the power outlet fuse #2 and an add a fuse kit with a 2 amp fuse.
    For safety purposes all of the line used was 18 gauge sealed in 1/4" black plastic split loom. Also gives that factory appearance too.
    smikels, DVS1, AngryOscar and 5 others like this.
  7. Apr 12, 2016 at 5:56 AM
    #127
    usmcguy78
    usmcguy78 Well-Known Member
    Digger
    Fayetteville, AR
    2018 Cement TRD Off Road 4x4
    LED, WeatherTech Floor Mats, Console CC gun holster, AMP Research Bed Extender, Under Hood LED lights, Pop&Lock, OPT7 LED Hi-Lo-Fog
    Ordered one yesterday.
    forty2[OP] likes this.
  8. Apr 12, 2016 at 9:11 AM
    #128
    RHelton10
    RHelton10 Well-Known Member
    Atlanta, GA
    '16 DCLB MGM TRD Sport 4x4
    Predator bars, Revolver X2 tonneau cover, SwingCase tool box, Husky mats, HID conversion Fuel vapor 17” wheels, 2” front /1” rear lift with Bilstein 5100’s, 285/70R17 Nitto grappler 2’s
    For those of you buying these switches for the 3rd gen's, do you feel the white or blue backlighting matches the OEM switches the best?
  9. Apr 12, 2016 at 10:49 AM
    #129
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I haven't tried white yet, but all the blue aftermarket switches I've tried are too blue and too bright. I'm kind of OCD about interior stuff (hence the thing for switches existing in the first place) so my gripes should probably be taken with a grain of salt.
    Tolip likes this.
  10. Apr 12, 2016 at 10:52 AM
    #130
    RHelton10
    Atlanta, GA
    That actually helps a lot. I would rather it be too white than to be too blue. Thanks for the info!
  11. Apr 12, 2016 at 6:01 PM
    #131
    ToyoTay
    ToyoTay Member
    Taylor
    2015 Tacoma DCSB Black
  12. Apr 12, 2016 at 6:49 PM
    #132
    RHelton10
    Atlanta, GA
  13. Apr 12, 2016 at 6:56 PM
    #133
    ToyoTay
    ToyoTay Member
    Taylor
    RHelton10 likes this.
  14. Apr 12, 2016 at 8:11 PM
    #134
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    How about some Nightshade over the switches to dim them
  15. Apr 12, 2016 at 9:27 PM
    #135
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I'm actually thinking about switching to the three switch plate and will likely get a handful of switches to screw around with until I come up with a situation that I can live with.
  16. Apr 12, 2016 at 11:05 PM
    #136
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Any plans to squeeze more switches in anywhere else? What about that phone charger cubby that I'm not going to use.
  17. Apr 13, 2016 at 6:22 AM
    #137
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I'll be taking a close look at the overhead possibilities whenever it is that I get around to mounting my 2m/440, but other than that there's nothing I'm really considering at the moment.
    friendlywithbears likes this.
  18. Apr 14, 2016 at 9:49 AM
    #138
    beenjammin
    Auburn, AL
    2016 TRD 4x4 ORDCSB
    Anyone put heated seat switches in the three hole panel? which ones did you use?
  19. Apr 25, 2016 at 11:34 PM
    #139
    forty2
    Cascadia
    2016 DCSB OR 6MT
    At some point I was asked if I would make a blank fill plate for end user customization. This is it. The business part of the plate is 4mm thick which should be enough to support some generic toggle switches. Please note, I normally don't offer items for sale until I've tried them out myself. This part is simply a modified version of the existing parts and I decided to forgo that step in this case. I don't think you'd have anything to worry about with the part, but FYI and all that.
    MoQS likes this.
  20. Apr 26, 2016 at 3:51 AM
    #140
    hamiltonuh60
    hamiltonuh60 Well-Known Member
    Texas
    2016 DCSB TRD OR 4WD
    Frontrunner, CVT RTT, Foxwing, Switch Pros, OGE, Fox, ADS, TC UCA, Dakar, Superbumps, U bolt flip, blah blah blah
    Link isn't working for me? Might be on my end so I'll try later on another device, thanks.
