I need a trans fluid change, whats the safest way?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumanityForPresident01, Sep 22, 2017.
  1. Sep 22, 2017 at 7:05 PM
    HumanityForPresident01 [OP] Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    I know i need a transmission change but I haven't done it myself yet because i'm not entirely sure what the best way is.
    I watched a video on youtube of a guy dropping his trans pan, measuring the amount that he drained, cleaned the magnets and put the pan back on. then he added the same amount of fluid he took out.
    I should mention my transmission is a stick which does not need a filter to what I understand.
    Another method I saw the guy was talking about there still being a lot of fluid that's still in circulation and he took his rad hose off red it into a bucked and i guess dumped in a gallon or so of trans fluid while the truck was running to pump all the old fluid out until it came out clean.
    that scares me, it seems like you could really fuck something up if you're not careful. I want to change all the fluid, I hear that only 30% of your total trans fluid sits in the pan, the other 70% is in circulation.
    What can anyone tell me about this, because there's no WAY i'm letting anyone else do this job. I am very skeptical of shops after trying to fuck me at toyota.
    I had my t.o. bearing and clutch disc/cover replaced and they took my exhaust apart obviously. they made a hairline crack in the y-pipe and did not own up to it. they were READY to sell me new exhaust. They said they don't weld there and they wont fix it.
    I talked to the manager and they tig welded it for free for me... scammers!
    thanks!
  2. Sep 22, 2017 at 7:08 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Take the drain bolt out... Then refill it at the fill plug till it runs out.:thumbsup:
    robssol likes this.
  3. Sep 22, 2017 at 7:09 PM
    Trevor
    there are still magnets in the pan that should be cleaned though right?
  4. Sep 22, 2017 at 7:13 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    https://youtu.be/j_ZEQcS0pg0
  5. Sep 22, 2017 at 7:15 PM
    Trevor
    yeah i watched that one
  6. Sep 22, 2017 at 7:17 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    I wouldn't sleep tonight till that fluid was changed...
  7. Sep 22, 2017 at 7:20 PM
    Trevor
    so to what i understood from my small amount of research is automatics have trans filters, and manuals have magnets. In the video i saw his magnets were full of metal particles, and he suggested cleaning them when changing fluid. Also is it true that only 30% of the total fluid is in the pan?
    So you recommend only pulling the plug?
  8. Sep 22, 2017 at 7:22 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Just clean the magnet... A manual trans doesn't have a pan like a auto.
  9. Sep 22, 2017 at 7:26 PM
    eon_blue
    Azusa, CA
    All you need to do with a manual trans is drain and fill, no need to do a major system "flush" like automatics require every now and then. It's one of the easiest maintenance requirements to do yourself, takes all of 20 minutes.
    Remember to always loosen the fill plug before loosening the drain plug. Don't want to drain out your oil only to discover that the fill plug is stuck on.
    Have new crush washers handy for both the fill and drain plugs...they're cheap and if you reuse the old ones, it could end up leaking.
    Drain the trans into a catch can for a few minutes until it's no longer running out of the drain hole, plug the drain hole, then fill her up with the appropriate gear oil (75w90 I believe...unless it's different for you 2nd gens) and keep filling it until the oil starts to run out of the fill hole. That's when you know it's full.
    Plug it up with a new crush washer on the plug and you're good to go.
  10. Sep 22, 2017 at 7:31 PM
    Trevor
    but theres still fluid in the pan if you just drain it from the drain plug right? the drain hole isnt flush with the bottom of the pan, which would leave some still in there. and no need to ever clean the magnets then? just let metal collect on them forever until the have so much gear metal on them they no longer work and let metal pass through the system and mess up things faster. see i'm a worrier, and i worry about my baby.
  11. Sep 22, 2017 at 7:34 PM
    Trevor
    do you get a lot of shit on this site for sporting a honda? it just looks funny on a tacoma web forum.lol
  12. Sep 22, 2017 at 7:36 PM
    eon_blue
    Azusa, CA
    Lol, you're overthinking it. Manual transmissions are very low maintenance compared to autos in the long run (minus having to replace the clutch every 150k or so). They're also far simpler by design and less temperamental than autos. No need to worry about any oil left behind after you drain it, the new oil will mix with whatever little amount of the old oil is still in there and as long as you're good about doing the drain and fill at the proper intervals (every 30k or so) you'll always have fresh gear oil in your transmission. Everyone I've known with a high mileage manual trans Tacoma has only ever done drain and fills...come to think of it, I don't even know if there is a process for 'flushing' a manual trans like you would an auto. Maybe there is but I've never heard of anyone doing it; manuals do just fine with regular drain and fills.
    As for the magnet, you're referring to the magnet on the drain plug yeah? Just wipe it off before you put it back in. Minor metal shavings/particles are a normal occurrence. As long as there aren't any big chunks or shavings you're fine.
  13. Sep 22, 2017 at 7:37 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Not really ... It will blow away a 3rd gen tacoma no problem
  14. Sep 22, 2017 at 7:41 PM
    eon_blue
    Azusa, CA
    Also I recommend using Redline gear oil for your manual trans, makes shifting feel noticeably smoother more-so than any other gear oil I've tried.
    JoefromPTC likes this.
  15. Sep 23, 2017 at 4:29 AM
    Trevor
    lol thats still funny though
  16. Sep 23, 2017 at 4:29 AM
    Trevor
    yup ive still got a few bottles of redline from when i did my t-case. good stuff.
  17. Sep 23, 2017 at 4:30 AM
    Trevor
    to my knowledge i was told there were two magnets in the trans pan since manuals don't have trans filters. or is the only magnet on the drain plug?
  18. Sep 23, 2017 at 4:48 AM
    gearcruncher
    Canadain bumper technician
  19. Sep 23, 2017 at 6:12 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    That's really not saying much though...'blow away" as in how?
  20. Oct 14, 2017 at 4:12 AM
    Trevor
    yeah i saw that when i was changing my fluid. My dad has a gen 2 automatic base model tacoma which has the trans pan, together with watching mislabled youtube videos and not looking close enough, i thought i had a pan. The fluid change was easy, i cleaned the magnet on the drain plug and filled it til it just started running out the fill hole.
    When i took the fill plug off a lot of fluid came out, when the stealership did my t.o. bearing job and shift lever they filled the trans from the shifter so there was a little bit more in there than i could get into the fill hole.
    Thanks for your help!
