I need help diagnosing my passenger side window...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OCTaco, May 4, 2010.
  1. May 4, 2010 at 9:43 AM
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    So the passenger side window on my truck will only go down if you press the switch on the driverside, it wont work with the swith on the passenger side. Is this common? Does anyone know how to diagnose or fix this?
  2. May 4, 2010 at 10:01 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    That was the first thing i checked, also all the other windows work.
  3. May 4, 2010 at 10:08 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Did you spill anything on it? might just have to take it apart and inspect it
  4. May 4, 2010 at 10:14 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    No i dont think anything was spilt on it. what do i look for when i take the door apart?
  5. May 4, 2010 at 12:05 PM
    ProRacerNorm
    ProRacerNorm Member
    Norm
    Salem County NJ
    07 TRD Off-Road Lifted
    URD MKII Stage 3, Borla Cat-back, Doug Thorley Headers, ICPW Tail and Third Brake Lights, ToyTec Ultimate Lift Kit 3", GrillCraft MX Series Upper and Lower, Kenwood Double-Din, 18" RBP 94R with 285/65/18 tires.
    I was having the same problem for a while but ended up just going away. It was probably moisture.
  6. May 4, 2010 at 3:33 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Weird... I'll take the switch off and go over it with a blow drier to see if that will fix it.
  7. May 4, 2010 at 3:41 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Weird.. I had the same thing happen to me, but just once. The passenger side switch wouldn't work at all to raise or lower the window. The next time I started the truck (after stopping at a convenience store) it worked again. I've been trying that switch on just about every trip now but it won't fail again.. :confused:
