I need help! Squeaky noise problem!
Discussion in 'Technical Chat' started by CantCme, Mar 21, 2008.
  1. Mar 21, 2008 at 8:02 PM
    CantCme
    CantCme [OP] Member
    I have a 2001 Tacoma and i notice a squeaky sound every time i accelerate from a coast. Its a high pitched squeaky noise, annoying as hell! My friend told me i could be one of the pulleys. I could only hear it when i start to accelerate slightly from a coast then it goes away. As i shift in the next gear and accelerate slightly it comes on again. Any ideas? Thanks for the help.
  2. Mar 21, 2008 at 9:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely sounds like maybe a pulley,and belt too. if you cant afford the new belt/pulley(gas prices are crazy!!), maybe try some belt dressing for now.....may get rid of the squeal for a while.
  3. Mar 22, 2008 at 7:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Most likely one of your belts is loose.
    Open up the hood and check all your accessory belts. Find an open spot of belt (12" of so between pulley's) and grab the edges and twist. If you're able to twist the belt past perpendicular to its original position, then the belt it too loose.
  4. Mar 22, 2008 at 3:23 PM
    CantCme
    CantCme [OP] Member
    The noise is only when i press on the gas while coasting. I cant catch it while parked. I sprayed some wd40 on all the pulleys were the bearings are and it didn't do anything. I got the truck from my dad at 92k and he hadn't changed anything except the oil. its at 105k now. I recently drop a K&N intake, i had notice the same sound before but after the intake the sound got a little louder. I hope its nothing major.
  5. Mar 22, 2008 at 10:19 PM
    Janster
    Jandy
    Lancaster, PA
    Did you check the belts to see if they were loose? (as I mentioned earlier)
    If the belts are loose - they'll slip when you step on the gas causing a squeeling noise.
