I need more lift, but how?
Discussion in 'Suspension' started by Darkgoatracer, May 24, 2017.
  1. May 24, 2017 at 2:58 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    lets split it @boogie3478
    boogie3478 likes this.
  2. May 24, 2017 at 3:00 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I bet we could get a few more guys to go in on it. No I didn't say "go down on it" @Me. Projekt
  3. May 24, 2017 at 3:02 PM
    fatfurious2
    David
    Ashburn, VA
    my friend's paint shop in Winchester, is $1k per month, for 3,000 square feet
  4. May 24, 2017 at 3:11 PM
    Darkgoatracer
    Darkgoatracer [OP] Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    We've gotten way off topic. The issue with the shop is use is it's a company shop. Not sure how a ton of people in and out would go over. But anyyyyway. Can I run 5100's with my current springs and spacers to get what I'm looking for?
  5. May 24, 2017 at 3:16 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
  6. May 24, 2017 at 3:18 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Springs provide lift. Not shocks. New shocks are needed with taller springs though. To do a lift right requires both.
    DustStorm4x4 likes this.
  7. May 24, 2017 at 3:24 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    The way I understood it is the 5100s would provide some lift due to spring perch placement? Is that not the case?
  8. May 24, 2017 at 3:41 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    5100s can preload the spring and provide lift but they shouldn't be combined with a spacer.
    1) you'll be on a stiff as fuck ride
    2) you'll be out of wack alignment-wise and need UCA's
    3) people will make fun of you
    4) CVs will blow every 2 weeks
  9. May 24, 2017 at 3:42 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Thanks that was exactly what I was looking for! So what springs should I par with 5100s and on what setting.
  10. May 24, 2017 at 3:42 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    And will I still need uca's?
  11. May 24, 2017 at 3:45 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    If you're going 5100 route, you need to look into Eibach or OME springs. I think the Eibach springs set you at 2.5" and OME springs vary depending on which one you go with. If you go above 3" you most likely need UCA's but some trucks can do without. You just have to install everything and see how it goes.
    fatfurious2 likes this.
  12. May 24, 2017 at 3:55 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Jesus....why can it just be one of those 'buy this and put it on situations" for 12-1500$ I'll just leave it as is...
  13. May 24, 2017 at 4:01 PM
    fatfurious2
    David
    Ashburn, VA
    every truck is different
  14. May 24, 2017 at 4:02 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    if you're rubbing control arms already then yea you"ll need new UCA's
    nice looking truck btw
    most people will probably suggest 5100's paired with OME 886 coils since you have a plate bumper.
    your best bet is to call marie at headstrong offroad. she will have all the answers you are looking for
  15. May 24, 2017 at 4:14 PM
    #35
    Darkgoatracer
    Nick
    Northern VA
    Stock
    What issues will I run into doing a true 3" Lift? Will the tires rub the upper control arm worse? Do I have to worry about cv shaft angles?Will the front diff need to be lowered as Well? When will it stop? If I lower the front diff will the transfer case need to be dropped? I have soooo many questions.
    99TacoDriver likes this.
  16. May 24, 2017 at 4:17 PM
    #36
    99TacoDriver
    South Louisiana
    call headstrong, trust me
    DustStorm4x4 and fatfurious2 like this.
  17. May 24, 2017 at 4:21 PM
    #37
    fatfurious2
    David
    Ashburn, VA
    wheels/tires/backspacing play a part. I think most people dont recommend a diff drop.
    Welcome to TW, it will never stop!
  18. May 24, 2017 at 4:22 PM
    #38
    99TacoDriver
    South Louisiana
    you could even shoot marie a PM on here if youd rather that....@HeadStrong Off-Road
    HeadStrong Off-Road likes this.
  19. May 24, 2017 at 4:23 PM
    #39
    fatfurious2
    David
    Ashburn, VA
  20. May 24, 2017 at 4:24 PM
    #40
    99TacoDriver
    South Louisiana
    i wonder why it didnt work for me? thanks for the help
