I sprung a leak!!! Front Differential That Is and need help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Walt Corbin, Jan 9, 2009.
  1. Jan 9, 2009 at 9:35 AM
    Walt Corbin
    Walt Corbin [OP] Well-Known Member
    Charleston SC
    05 Dble Cab SR5 4x4
    Revtech Lift w 285's
    I need some advice and thoughts from the TW family. I don't know whether to take my truck into the dealer or DIY. I am not an idiot when it comes to trucks but I am certainly no mechanic. That being said here is my problem.
    Well after 48,000 miles on my 05' DC V6 I have my first problem. On Wednesday I noticed 2 spots of oil under the front of my truck. One was about 4 inches in diameter and the other was about twice that (8"). I must have moved my truck which caused the second spot. I moved the truck to make a new spot so I could get an idea of how fast the leak is. After 24 hrs it made a spot about 3" x 4".
    The wife and I commute/work together so the truck sits parked for the most part during the week. Meaning that the oil is cool which should be slowing the leak down. I am thinking the 8" spot is probably from me running it up to the store and heating up the oil.
    The oil appears to be coming from the front differential oil seal (drivers side).
    I briefly looked through the service manual yesterday and was going to see what was involved in DIY. And how much oil the diff holds to get an idea of what I may have left!!!
    I will call the dealer today and see if I can get an over the phone quote. That will partially make my decision.
    So here are my questions:
    1. Is it the oil seal? As I said I am no mechanic.
    2. How long will it hold?
    3. Should a novice attempt this? Not even sure if I have the tools.
    Thanks in advance for any replies.
  2. Jan 9, 2009 at 9:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes
    Once they start leaking they are done. It should not get much worse but you don't want to continue to drive it.
    If you don't have experience with oil seals, do not attempt it. They are tricky, press-fit, buggers. If you bend it, warp it, mar the seal, break the spring, it is toast. They are pretty mush a one-shot deal. If you don't get them in right the first time right, you mind as well buy a new one.
    Voice of experience and my .02
  3. Jan 9, 2009 at 9:45 AM
    Walt Corbin
    Charleston SC
    05 Dble Cab SR5 4x4
    You have any idea of what dealer install should run? I will call 2 to get quotes. Thanks!
  4. Jan 9, 2009 at 9:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    No clue. I avoid them at all costs.
  5. Jan 9, 2009 at 9:49 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    your truck has a 5yr/60000 powertrain warranty doesn't it? Shouldn't this be covered since you're within those?
  6. Jan 9, 2009 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. They are a covered part of the drive train.
  7. Jan 9, 2009 at 9:56 AM
    Walt Corbin
    Charleston SC
    05 Dble Cab SR5 4x4
    Yes thanks! I was just reading through my warrenty and came across powertrain, 5yr. 60,000 mile. I was thinking of the basic 3yr. 36,000. So it should be covered. I have a revtech lift that was installed by the dealer. I have a different dealer that is closer to me that I would like to use. Do y'all think they will give me any problems because of the aftermarket install?
  8. Jan 9, 2009 at 9:57 AM
    RelentlessFab
    Eric
    Sparks, NV
    I doubt it, wouldnt think that it would be an issue, especially if they installed it. If they say anything just make sure you say that they were the ones that did it. My dealer out here will even warranty a truck with a 6" lift if they or another shop they work with installed it.
  9. Jan 9, 2009 at 9:58 AM
    Walt Corbin
    Charleston SC
    05 Dble Cab SR5 4x4
    Thanks Guys!!! I appreciate the input.
  10. Jan 9, 2009 at 10:06 AM
    obxfishn
    obxfishn Well-Known Member
    Eastern Virginia
    2.5" ToyTec Lift, Smitty Built Nerf Bars, Scangauge unit,
    Just had a similar problem with a leak around the seal where the DS CV shaft goes into the front diff. I have 45K and it was covered under powertrain warranty which is 5yr/60,000. This repair should not cost you anything! Dont let them pull that #$%* on you. Tell them to pack sand and go to another stealership.
  11. Jan 9, 2009 at 10:15 AM
    Walt Corbin
    Charleston SC
    05 Dble Cab SR5 4x4
    Just called and will drop it off Monday for the warrenty work. For some reason I was thinking that the 3yr., 36,000 covered everything. I guess because this is my first problem with my truck.....I never really looked deeper.
  12. Feb 11, 2010 at 8:27 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I have this exact same problem... is this caused by the lift? I'm assuming so, if not I'm taking it to the dealer on tuesday. Any new info?
    I want to get this under warranty, but can anyone tell me if this is definitely caused by my lift?
    I have to drive to Reno this weekend... will this be a problem... the mech at the dealer said I'd be ok...
    oh I have 20,500 mi on the truck with a 3" lift
  13. Feb 12, 2010 at 2:58 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
  14. Feb 12, 2010 at 4:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    No, that seal failure shouldn't have been caused by the lift.
  15. Feb 12, 2010 at 11:17 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^good, would it be a big deal to drive on it... I have to goto Reno, 300mi from here.
  16. Feb 12, 2010 at 2:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    You should be fine. It doesn't look catastrophic. You can always check the level quick and top it off if need be.
  17. Feb 17, 2010 at 10:11 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    thanks... drove to reno, came back got it fixed under waranty... no problems
  18. Mar 15, 2010 at 3:28 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Ok, well I have this same problem, but the only problem is I have aftermaket CV's so I am going to assume warranty work is out of the question? Where aside from the dealer could I find these oil seals?
  19. Mar 15, 2010 at 9:37 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
  20. Mar 16, 2010 at 6:48 AM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    If you fellers are all having seal problems make sure you get them changed out or keep a real close eye on your diff fluid. Mine had two seals go at the same time on a long trip just before Christmas and the front diff overheated and they had to put a completely new front diff in. $2047 Canadian for the diff alone. Covered under warranty. Crisis averted!!
