I think I bricked my ECU doing the B04 update..[OVTune Fixed it!!!]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Double Phister, Aug 18, 2018.
  1. Aug 18, 2018 at 4:25 PM
    Double Phister
    Double Phister [OP] Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    So ya. Techstream installed. Openport 2.0 purchased. CUW file downloaded. Start the process and it fails during the update. It initially showed me the current ECU version and what it would be after the update. Now it won't even connect.
    cheap scan tool can't connect either.
    Engine just cranks the starter.
    me sad.
    I thought I remember someone else in the same situation doing an OVTune update but I can't find that post.
    UPDATES
    Mat @ OVTune offered to repair it 47
    Shipped to him 114
    He fixed it on the bench 137
    ECU on it's way back to me 180
    ECU delivered. Will install after work. 187
    Zombie ECU is back from the dead. She runs! 193
    I took another stab at updating to B04 and it was successful. 219
  2. Aug 18, 2018 at 4:34 PM
    Double Phister
    Sacramento, CA
  3. Aug 18, 2018 at 4:46 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    Shhhhhiiiiiiitttttttt
  4. Aug 18, 2018 at 4:50 PM
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    Hopefully not and a simple fix..................good luck!
  5. Aug 18, 2018 at 4:52 PM
    Jchip
    Jchip Member
    FL
    2017 Cement TRD Pro
    Ugh, sorry to hear it. Following for details..
  6. Aug 18, 2018 at 4:53 PM
    Spackler
    Spackler Well-Known Member
    Why are you updating your own ECU?
    sierra141 and Running Board Man like this.
  7. Aug 18, 2018 at 4:54 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    Hey man if he has a MT then this is a thing, no worries.
    tonered, shakerhood and Maxcustody like this.
  8. Aug 18, 2018 at 4:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Does the check engine light come on with the key on?
    Can you do a CANBUS check to see if its talking?
    It's very likely that it needs an ECU. We have seen aftermarket mongoose cables and fake techstreams kill ECUs.
    The new ECU will need to be programmed to the set of keys. The vin will need to be written into the ECU as well.
    stealthmode likes this.
  9. Aug 18, 2018 at 4:58 PM
    Spackler
    It's a thing at the dealership. Not in your garage.
  10. Aug 18, 2018 at 5:07 PM
    Double Phister
    Sacramento, CA
    Check engine is on. Trac light is on. Center display gives me a low oil pressure and brake override malfunction.
    I did a check on CANBUS and it found of bunch of stuff. Anything in particular to look for?
  11. Aug 18, 2018 at 5:10 PM
    Double Phister
    Sacramento, CA
    I try to avoid dealerships. Sounds like I need to get to one now. I've done plenty of ECU reflashes. Just not on this particular vehicle.
    Pickeledpigsfeet likes this.
  12. Aug 18, 2018 at 5:10 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Thousands of people have flashed their ECUs in their driveway without any issue. Me included. Get off your high horse.
  13. Aug 18, 2018 at 5:19 PM
    Spackler
    Are you referring to ECU updates from Toyota or after market mods like OVTUNE?
  14. Aug 18, 2018 at 5:22 PM
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    Yeah, it does happen with techstream. Dealer bricked mine during an update for a TSB. They had to order a replacement ECU.
    0uTkAsT likes this.
  15. Aug 18, 2018 at 5:22 PM
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Both. I’m an OVTune user, and I flashed the latest TSB to my truck.
  16. Aug 18, 2018 at 9:23 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Wow that really sucks to hear, I would be afraid of doing something like that myself.
    Spare Parts, sierra141 and tcjacado like this.
  17. Aug 18, 2018 at 9:54 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I wouldn’t recommend people doing stuff like this themselves. However if you choose to do so always make sure you have a solid internet connection, laptop power, and the vehicle has a charger. Any of those fail and it’s pretty common to brick any control module
    sierra141 and shakerhood like this.
  18. Aug 19, 2018 at 5:29 AM
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    @OVTune says it's pretty much impossible to brick an ECU by user error. If the flash fails, it reverts to the previous version. I'd put money on the fact that this brick would have occurred had OP had it done at the dealer or in his garage.
  19. Aug 19, 2018 at 6:12 AM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Subbed. I was getting ready to update mine to the newest ecu update but am worried about doing this. Fingers crossed for a good outcome OP.
    shakerhood likes this.
  20. Aug 19, 2018 at 6:14 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Internet connection has absolutely nothing to do with it. No one ever bricked an ECU by not having an internet connection. But what you did forget is the most important thing, and the most common way to brick an ecu, and that’s the connection stability (hardware & serial to usb drivers) between ecu and laptop.
    MGMSangTaco and TFly like this.
