I think I found some rims....
Discussion in '5 Lug' started by Rconectn, Feb 24, 2011.
  1. Feb 24, 2011 at 5:26 PM
    Rconectn
    Rconectn [OP] Well-Known Member
    Miami, FL
    '10 Regular Cab
    I'm about to fit my 5lug with a lift. I wanted 16x8 rims with as close to the original +40 offset from the factory rims, but I couldn't find any. Instead I did find some 16x7 with +40 offset. I wanted to know would I still be able to fit Good Year DuraTrac tires 245/75R16? Also would there be any difference in handling since I'm opting for the 7" instead of 8" wide rims?
  2. Feb 24, 2011 at 6:41 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
  3. Feb 24, 2011 at 8:00 PM
    Rconectn
    Miami, FL
    '10 Regular Cab
  4. Feb 25, 2011 at 11:30 AM
    113tac
    Stephen
    Northern Virginia
    No problem
  5. Feb 26, 2011 at 1:48 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    Stock prerunners have 245/75R16 on 7 inch wide rims. So should not be a problem. I'm still debating about new wheels but haven't found any that I really like. Don't want them to stick out much and no way am I going to grind the callipers or put on spacers so I think when the time comes I'll just throw on 235/75R15 and look into swapping the stock 3.31 gears for oem 3.58s.
