I think I made up my mind.....
Discussion in 'Suspension' started by muliefever, Oct 21, 2008.
  1. Oct 21, 2008 at 9:29 AM
    muliefever
    muliefever [OP] Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    So after reading all about the suspension upgrades for my truck I think i have decided what to do..
    Bilstein 5100's in front. Stock coils set at ruffly 2-2.5"
    Bilstein N140S shocks in the rear
    rear AAL
    Keeping stock wheels
    265/70/17 BFG AT's or 255/75/17 BFG MT KM's
    I don't want a big lift. Just something to make it my own. And to be able to run a little bigger tire to boot. What do you think?
  2. Oct 21, 2008 at 9:38 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    That will work good and look good specially if you go with the mud terrains
  3. Oct 21, 2008 at 9:57 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Will look good. Just to clear any confusion when you go to order product, the N140S shocks are made by Old man Emu (OME)
  4. Oct 21, 2008 at 10:22 AM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    Oh okay, thanks... Maybe I will get the 5125 for the rear instead. I would like to keep it all the same you know. I won't have to replace the uca's will I?
  5. Oct 21, 2008 at 10:25 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Well.. Here's what I understand about the UCA's - you don't HAVE to replace the UCA's, but you may have alignment issues after the lift. Getting new UCA's will correct the alignment & prolong tire life, and give your truck a more stable ride on the highways...someone correct me if i'm wrong here..
  6. Oct 21, 2008 at 10:31 AM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    That makes sense... After reading all about the lifts. I came to the conclusion that as long as I stayed below the 2.5" mark I would Not need or have to replace the UCA's.. At least that is what I got out of it.. Anyone?
  7. Oct 21, 2008 at 10:34 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I just lifted mine 3", and i plan on getting new UCA's. I can feel the tires vibrating on the outer edge of the tread...and + the TC's look badass :D
  8. Oct 21, 2008 at 10:34 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    alot of people have used the 5100's set at the top notch and havent had any real issues. now, if you went to a 3 inch or higher lift, then uca's would probably be better to have. you can always get uca's later on if you decide you need them, but i dont think you'll have a problem with the bilsteins set at 2 or 2.5.
  9. Oct 21, 2008 at 10:36 AM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    Great! Come on Tax return!!!!!!
