I think it's possible my transmission fluid was drained and oil overfilled.... 1000 miles ago
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cuttybrownbow420, Oct 29, 2020.
  1. Oct 30, 2020 at 5:45 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Same. Never been to Thailand.
    wilcam47, TailHook, $yoda$ and 2 others like this.
  2. Oct 30, 2020 at 5:52 AM
    mangosmoothie
    mangosmoothie Well-Known Member
    Casey
    Northern AZ
    '22 Pro
    The oil pan is pretty obvious on this truck. Seriously doubt someone drained the trans instead.
    But ya never know I guess.
  3. Oct 30, 2020 at 6:02 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    not on a new-er vehicle... unless you have some serious issues.... when it turns BLACK, its clutch material... and the trans is likely toast at that point...
    Skydvrr likes this.
  4. Oct 30, 2020 at 1:47 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Old Fords with vacuum modulator controlled transmissions would blow white smoke from the exhaust when the diaphragm failed, transmission fluid would be sucked in to the engine and burned. Worthless automotive trivia for the day.
  5. Oct 30, 2020 at 2:12 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Automotive trivia is never worthless
  6. Oct 30, 2020 at 2:16 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It’s amazing someone drives around $32k with issues and writes it off as “probably normal” before bothering with a simple fluid check before possibly blowing an engine or trans.
    .. and no, it shouldn’t be warrantied if you grenade an engine or trans because driver just drives and doesn’t know how to drive it to a shop.
    oconnor, wilcam47, Chew and 1 other person like this.
  7. Oct 30, 2020 at 2:22 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    See this is what I think also. Is this even an actual problem? I mean who would drive a truck 1000 miles suspecting something like that?
  8. Oct 30, 2020 at 3:39 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    My vote is overly concerned about nothing. OP, was it worse when it was colder? My guess having gotten this in June you are not accustomed to how much steam comes from the exhaust on a cold start and cold weather.
    Skydvrr, wilcam47 and Scott17818 like this.
  9. Oct 31, 2020 at 4:26 AM
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    already tried to explain this to him earlier in my post. but I dont think he understands. and expects mercedes ride, in a tacoma...
    mattleg[QUOTED] and zoo truck like this.
  10. Oct 31, 2020 at 5:10 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Nothing on any vehicle these days is cheap.
    With all the bells and whistles on todays vehicles when the warranty runs out people will be paying $$$.
    Blowing smoke on startup is not a tranny issue.
    shakerhood and zoo truck like this.
  11. Oct 31, 2020 at 5:53 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'll tell you i was a bit surprised how these trucks rode when i did a test ride at a dealer after coming from a gen1 tundra. I had several toyota compact 4x4 pickups in the past that rode better. Dealer assured me they will ride better once fully broken in. To some extent its true. My 2020 sr5 was really ox cart stiff when i first got it...after 4500 miles it is getting better, but its no tundra like i had.
  12. Oct 31, 2020 at 6:09 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I wish my SR had a talking dipstick.
    Gatordog and T4RFTMFW like this.
  13. Oct 31, 2020 at 6:17 AM
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    I'm coming from a 2013 mazda cx-5 AWD 2.0 auto, and my previous truck experience was my fathers 2000 GMC 3500 duelly (gas), anything was an improvement for me.. did notice the TRD OR was a bit bouncy in the front end before I added my sliders, and winch bumper. the weight helped.. but the newer suspension with stiffer springs helped a LOT.
  14. Oct 31, 2020 at 6:24 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Refill the trans drain the excess oil from the engine drive more worry less.
  15. Oct 31, 2020 at 7:40 AM
    #35
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Well, if that damned search function wasn’t so difficult to use you would know. Luckily, I have a PhD in using the search function....my Saturday morning gift to you is a peek into the scary under belly of the third gen sub forum.
    I present to you, a small sample of your fellow third gen owners (and two 2nd gen owners who are third gen owners at heart) who couldn’t tell the oil pan from the tranny:
    https://www.tacomaworld.com/threads/accidentally-drained-trans-fluid.622770/
    https://www.tacomaworld.com/threads/help-accidentally-drained-trans-fluid.652235/
    https://www.tacomaworld.com/threads/drained-tranny-fluid-versus-oil.443381/
    https://www.tacomaworld.com/threads/drained-atf-instead-of-oil.560883/
    ...and if you ever do accidentally drain the tranny, for God’s sake don’t do this:
    https://www.tacomaworld.com/threads/halp.33318/
    ...and keep in mind, this isn’t all of them.
  16. Oct 31, 2020 at 7:46 AM
    #36
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Grasshopper, the universe is talking to you.
  17. Oct 31, 2020 at 7:51 AM
    #37
    rnish
    Tacoma 2nd gen
    The accused transmission drainer was a dealership mechanic. These are noob’s.
  18. Oct 31, 2020 at 7:56 AM
    #38
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    T4RFTMFW[QUOTED] likes this.
  19. Oct 31, 2020 at 7:58 AM
    #39
    skiploder
    FZJ80/XJ LS swap
    My money is squarely on that the previous owner was a TW member. There is probably ATF in the coolant and wiper fluid as well.
    Vlady likes this.
  20. Oct 31, 2020 at 8:08 AM
    #40
    Cuttybrownbow420
    Cuttybrownbow420 [OP] Member
    2018 SR V6
    So I had my friend take a look last night, he's not a mechanic but he's pretty damn knowledgeable. He didn't really see anything out of ordinary, other than coolant being a bit low. Confirmed no smell in the smoke. Visible exhaust wasn't that bad yesterday, so I might've just been surprised by how much exhaust you see in these trucks in the cold.
    I'm having surgery Monday and my friend agreed to drive me down in my truck to give it an on the road test just to make sure. Leaning towards paying the local toyota only mechanic to run a diagnostic next week once I've healed up a bit, and maybe just getting the transmission fluid and oil both changed out just for peace of mind.
    Had two jeeps before my truck that were mechanical moneypits, so in all honesty, to call myself a bit of a car hypochondriac is putting it mildly. Hoping for the best, probably won't have a real update until mid next week.
    mattleg and wilcam47 like this.
