I think my 2011 rear end was replaced with a LSD mechanical rear differential ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KJaikaran, Feb 10, 2013.
  1. Apr 14, 2013 at 5:14 PM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Mine spun the opposite way, but i supposedly have a LSD (being a trd sport)? does this sound wrong?
  2. Apr 14, 2013 at 5:35 PM
    cnew
    cnew Well-Known Member
    Goodyear AZ
    11 DC 4x4 Sport
    I was just looking at this the yesterday. It only shows a fluid change under the severe driving conditions @30,000 for the e-lsd like you said. Went through the entire service schedule 100,000 miles + and didn't see when they recommend a fluid change in the rear diff for the e-lsd. I'm at 30,000 now and may just change the front/rear diff, and the transfer case for peace of mind.
  3. Apr 14, 2013 at 5:45 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Yours is a 2010, meaning it has Auto-LSD, which is a open differential with a simulated LSD (the computer uses the brakes to limit wheel spin), as opposed to the actual mechanical LSD used in the pre-2009 2nd gens.
  4. Apr 14, 2013 at 5:49 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    X2
    Brett
  5. May 1, 2013 at 9:43 PM
    KJaikaran
    KJaikaran [OP] Well-Known Member
    Orlando FL
    2011 Tacoma DCSB TRD Sport
    URD intake/maf calibrator, Icon extended travel coilovers, Icon UCA, OME Dakar leaf packs, Bilstein extended rear shocks, 3 degree axle shims, Carrier bearing drop bracket, DS2 retro, 5k HID bulds top and bottom
    Are the gears in the 08 rear ends the same as the 11? Drove a friends 2012 stock 4.0 Tacoma the other day and it felt a lot different at certain speeds than mine does. His felt a lot more responsive, where mines feels a lot heavier :confused: . The only thing i could think of was my tire being a 32, but then i started wondering if it was a difference in the gearing since i no longer have my original 2011 rear end, but the 2008 LSD one. I'm not too familiar with the gearing and re-gearing, but i have a general idea.
  6. May 1, 2013 at 11:52 PM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    I have a '06 SR5 with Mechanical LSD you scored, my gear ratio is 3:727 w/6 speed manual. In other words a 3:73
    auto trans came with 3:583 2.7L or 3:727 4.0L 4x4
    2.7L 5 sp manual came with 3:307 4x2 4:100 4x4
    4.0L 6 sp manual came with 3:153 4x2 3:727 4x4
    This is according to Tacoma 2006 Specifications.
  7. May 2, 2013 at 12:01 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Yeah, like others have said: Huge Score
    I've been considering buying an LSD, and you just got one in a free upgrade
    Tires Spin in the same direction when you have it jacked + the LSD sticker = it's definately an LSD
    I'd keep it and count yourself blessed
  8. May 2, 2013 at 6:46 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    prerunner and 4wd v6 05+ have the 3.73s. 6spd man or 5spd auto also doesnt change that.
  9. May 2, 2013 at 6:51 AM
    KJaikaran
    Orlando FL
    Thanks. Guess it must be the bigger tires then. I did some looking around and it seems like 4:10 gears would be the way to go if i can find them, but would i loose on mpg ?
    Guess it worked out with getting the LSD rear end. Before it happened i had no idea it wasn't a mechanical LSD.
    Thanks.
  10. May 2, 2013 at 6:22 PM
    byrd
    byrd Unknown
    David
    Kansas
    Correct, I wrote what the spec sheet has. It shows a Tacoma X-Runner 4X2 6-speed with 3:153 gear ratio, only available option. Copy of spec sheet attached, where it shows it I highlighted yellow.
    My bad I did not specify between PreRunner or X-Runner.
  11. Oct 25, 2013 at 9:01 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    SHIT! Really? I traded in my 06 sport for a 13 sport and had no idea doesn't actually have a true LSD.
    This auto LSD sounds more like traction control than LSD. So if I disengage the traction control and go step on the gas... instead of the LSD kicking in and locking the rear diff, the Auto LSD is just going to apply the brake to my spinning wheel? That doesn't sound right. OR ETHICAL. I am not pleased. Not pleased at all.
  12. Oct 26, 2013 at 12:42 AM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    i wish i would have known, i scrapped an 8 inch lsd diff that was in my way awhile back. Could not figure out who spent the money to put it in the truck, and an E locker would be a nice add to my play truck.
  13. Oct 26, 2013 at 12:44 AM
    Konvict KROG
    Louisiana
    thats correct.
    i did some tests and it does actually work.. How well is someones guess but it is cool because i have a locker and "lsd" instead of one or the other.
  14. Oct 26, 2013 at 2:29 AM
    Konvict KROG
    Louisiana
    ^when i clicked your question was there, and when it refreshed to type... it says nevermind.
    But yes :) lol its 4:28 am its ok to be a little... off
  15. Oct 26, 2013 at 2:37 AM
    #35
    Konvict KROG
    Louisiana
    I believe so. I think all 2012 plus models have it as part of the federal VSC bs, but i could be wrong.
    somewhere there is a thread on here explaining all of the traction control modes on the new ones.
    im just glad its not horrible VSC like the 06 runner. that thing cuts all power when it slips
  16. Oct 26, 2013 at 4:26 AM
    #36
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    The easy way to check if you have a mechanical LSD (and looking at the pics you do - congratulations!):
    Take your bottle jack and place it under one side of your rear axle. Jack the truck up till the rear tire on that side is just barely off the ground. Get in your truck, start it. Deactivate the traction control by pressing and holding the VSC button for 3+ seconds - traction control off, not auto LSD.
    With traction control off, put it in gear and GENTLY give it a little gas and see if it will drive off the jack. You don't even have to actually drive completely off the jack (not that it will hurt anything). If it moves its got a LSD.
    David
  17. Oct 26, 2013 at 12:18 PM
    #37
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    wont the receipt list all the part numbers installed during the repair?
    if not ask. not effen way the service manager slaps his forehead and switchs it out. no way.
  18. Oct 26, 2013 at 3:05 PM
    #38
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it's an open diff the wheels will spin the other way they are spinning around the spider gears. Put it in park and try it with both wheels off the ground if it is limited slip you should not be able the turn the tire.
  19. Oct 26, 2013 at 3:24 PM
    #39
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    So question . When I hit my traction control button the auto lsd and the traction light come on. If I hold it then only traction button comes. Do I have an lsd rear?
  20. Oct 26, 2013 at 3:29 PM
    #40
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    You have a simulated LSD.
