i think my diff lock works in..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnRedNeck721, Aug 27, 2011.
  1. Aug 27, 2011 at 9:40 AM
    TnRedNeck721
    TnRedNeck721 [OP] Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    so i was just playing with diff lock on my ’07 DC SB TRD 4x4 off road. and from what i can tell. my diff lock works in 2wd 4wd and 4low. and i thought the JUST worked in 4low? so i took a video with my phone. and FYI i have done NO MODS to make it do this. i thinks it’s the yellow wire mod? not sure because i have not looked in to doing to much.
    ok hears video. http://youtu.be/NHvp4Vyf_NE
    so is it working in 2wd 4HI and 4low??
  2. Aug 27, 2011 at 9:42 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    If its flashing its not engaged. Anything 4wd is not fully engaged until the light is solid
  3. Aug 27, 2011 at 9:42 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Flashing just means the button was pushed. Not engaged.
  4. Aug 27, 2011 at 9:44 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    is the truck actually on? did you try driving in all those selections? if you just have the key on it might be different than actually having the truck on but im not sure, i have a Sport with LSD :(
  5. Aug 27, 2011 at 9:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    No. Blinking and the beeper means it's not engaged
  6. Aug 27, 2011 at 9:48 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok. and yes i drove it, i was just letting it move slow. (did not have foot on gas) and ok. thanks. maybe if i go farther? i only moved like 3 feet if that.
  7. Aug 27, 2011 at 9:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's still not going to work without the mod
  8. Aug 27, 2011 at 9:51 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok. thanks for info. i may do it i may not. how hard is it to do?
  9. Aug 27, 2011 at 9:56 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    In L4, there is no flashing or beeping when you are engaged... and as everyone above said... flashing diff. lock light mean it is NOT engaged.
    The locker anytime mod requires a relay, and not just cutting a grey wire like the 1st. gen tacos.
  10. Aug 27, 2011 at 9:57 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    oh ok. i just never looked anything up on it or played with it till now. and it’s my first truck. drove a scion XB before i got the taco.
  11. Aug 27, 2011 at 10:14 AM
    David K
    Between the owner's manual, the card in your sun visor pocket, and the sticker on your door... you can get a lot of how-to 4WD info. Naturally, you can just ask here, too... and get facts, fiction, and opinions on everything!
