I tow heavy with my first gen. How can I monitor trans temp?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Krugermeier, Apr 11, 2024.
  1. Apr 11, 2024 at 6:25 PM
    Krugermeier
    Krugermeier [OP] Active Member
    Will a scam gauge allow me to monitor transmission temperature?
    285/70/17 5VZFE
  2. Apr 11, 2024 at 6:51 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Assuming automatic... Yes- depending on year. I think around 98 and later will have the trans temp code.
    Here are my notes that work for my 2001 - for my SGII:
    Short term fuel trim:
    TXD: 686AF10106
    RFX: 044105060000
    RXD: 2808
    MTH: 00C80100FF9C
    NAM: ST%
    Long term fuel trim:
    TXD: 686AF10107
    RFX: 044105070000
    RXD: 2808
    MTH: 00C80100FF9C
    NAM: LT%
    Trans temp:
    TXD: 686AF101B4
    RXF: 044105B40000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TFT
    Obviously, if you don't already, get yourself an aux transmission cooler.
    Krugermeier[OP] likes this.
  3. Apr 11, 2024 at 8:38 PM
    Krugermeier
    can you teach me what an aux transimission collier is for a 2002 ext cab Prerunner taco?
  4. Apr 11, 2024 at 10:27 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    He was referring to an auxiliary transmission cooler, or in other words a standalone radiator just for cooling the transmission fluid.
    If your truck is an automatic transmission then it has an integrated transmission cooler inside of the main radiator that cools the engine. That stock cooler is inadequate for heavy towing applications
    Andy01DblCabTacoma likes this.
  5. Apr 12, 2024 at 6:54 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
  6. Apr 12, 2024 at 7:06 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  7. Apr 12, 2024 at 7:30 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Are those scan gauge or ultra gauge codes??
  8. Apr 12, 2024 at 7:46 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Scan Gauge II codes. I would have figured they would work for an Ultra Gauge, considering both are working with the ODBII protocol, but maybe I don't understand the underpinnings.
