I want a 6" lift? Any suggestions??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07COMA801, Feb 18, 2013.
  1. Feb 19, 2013 at 11:53 AM
    #61
    fj40taz
    fj40taz Well-Known Member
    Carl
    Williamstown, NJ
    10 Toyota Tacoma
    Flowmaster Exhaust
    going thru the same exact decision process now..
    leaning ore towards the 4" lift..
  2. Feb 19, 2013 at 12:20 PM
    #62
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    Correct me if i am wrong but doesnt a 4 inch lift have a drop bracket and new spindles?
    sounds like a better idea would be to do a 3 inch suspension and 1 inch body and get away for far cheaper
  3. Feb 19, 2013 at 1:29 PM
    #63
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2012 Lifted Tacoma Doublecab (SOLD)
    4" zone offroad suspension lift modified with Rcd bilstein front shocks w 1/2 spacer for 5.75" front lift and allpro expo leap pack with 2" block for 6" rear lift, extended length stainless brake lines front and rear, beefed taco carrier bearing drop brkt, 1.25 alum driveshaft spacer, avid lightbar powdercoated w 2 9" led lights, , amp research power steps, anderson aluminum drop hitch, ss grill insert w color matched grill, color matched door handles, color matched rear bumper, color matched pop n lock tailgate handle, 2012 sport mirrors added, color matched mustang hood scoop, borla ss exhaust, extang full tilt tonneau cover, windows tinted darker,oem roof rack, 2014 touch screen radio w navigation, infinity kappa speakers front and rear, rockford fosgate amp, 2 10" kicker subs, 2tone katzkin leather, hydro dipped interior parts, inalfa 925 power moonroof, lexus F sport shift knob
    Yes bds and zone are basically the same lift with only a few minor differences. Zone is owned by bds and yes both are a great product
  4. Feb 19, 2013 at 1:35 PM
    #64
    BORNWILDGUY
    Rich
    Florida
    Yes a 4" comes with longer spindles to make up the difference in lowering the centersection of the truck down. The advantage is that your tierod angles, cv angles stay within factory specs. With a 3" lift that doesn't happen and that why you see people changing uca's etc. Just depends on what your going to use your truck for. Both have pros and cons but me personally I have never had any problems with any drop bracket lift but then again I also installed them myself
  5. Feb 19, 2013 at 1:37 PM
    #65
    blake5995
    Blake
    Truckee, CA
    Yea i have installed many myself the only thing i dont like is you dont gain any clearance so for a mall crawler they are bomb but if you do any serious off roading you are back with the stock guys.
  6. Feb 19, 2013 at 1:48 PM
    #66
    blake5995
    Blake
    Truckee, CA
    are you talking above the tire or in front of and behind?
  7. Feb 19, 2013 at 2:28 PM
    #67
    TRD 09
    TRD 09 Well-Known Member
    Alberta
    09 TRD sport
    The new Chevy/gm has the worst fender clearance of all, too much clearance of top and no where enough front and rear of the tire, the square fender shape make it a horrible truck for larger tires, where the round shape of the super duty will allow 35's with no lift, personally I like the taco fender, it adds to the trucks attitude
  8. Feb 19, 2013 at 2:44 PM
    #68
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    rightt... :rolleyes:
  9. Feb 19, 2013 at 2:47 PM
    #69
    07COMA801
    07COMA801 [OP] TOYOTA.. Because barbie drives a jeep..
    Kris
    salt lake city
    07 Indigo Ink DCSB TRD OR
    ARB/OME 3" lift kit- (886 coil/springs-Dakar leaf pack)- 265/75r16 Toyo open Country M/T's - Stock 16" Toyota Wheels painted black - Full Size Spare W/a steele rim- B.A.M.F Slider W/Kickout (Bolt on)- Tint all round including windshield - Tint headlights and taillights - Bed lined grill surround and rear bumper - Color matched Toyota emblem - OEM Mud Flaps cut in half- Ultragauge - Cobra Radar Detector - Cheap Front seat covers/steering wheel cover - Remote Engine Start - Diff Breather Mod - Tailgate lock mod
    I want CLEARENCE i dont want to have to drop the "under carrage" or anything of that sort..
  10. Feb 19, 2013 at 3:02 PM
    #70
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    Don't listen to all the DB kit haters. The truth is you get more clearance with a DB and 35's than any 3 inch lift with 33's. The DB kits are no less durable than any 3 inch lift kit. I have an RCD lift on mine and I am siting at about 5 inches over stock with Old man 886 springs in the front and a set of alcan leafs in the back.
    The performance off road there the same. However in the snow and mud the DB acts as a plow.. That's the down side to any DB kit. The upside, my CV angles are way better than on a 3 inch.
  11. Feb 19, 2013 at 3:29 PM
    #71
    blake5995
    Blake
    Truckee, CA
    But let me ask this do you get more clearance with db and 35's of 3 inch and 35's.
    you got to compare apples to apples it is like me saying db with 35's has less clearance than sas with 40's of course it does we talking two different suspensions setup and different tires. you have to keep one variable the same.
  12. Feb 19, 2013 at 3:29 PM
    #72
    blake5995
    Blake
    Truckee, CA
    Whats the problem?
  13. Feb 19, 2013 at 3:35 PM
    #73
    blake5995
    Blake
    Truckee, CA
    My opinion is going to be different than others so you will have to decide.
    But i would do a 3 inch lift kit with coilovers in the front and a new leaf pack in the rear. put 35 inch tires under there if that is what you want. you will have to regear front and rear. do your cab mount chop and cut all the shit under neath that you will need to cut in order to get the 35 under there. going 4 inch wouldnt change the amount of cutting drastically. many people on here are running 35 with 3 inch so look how they did it. this will give you max clearance with 35's and IFS
  14. Feb 19, 2013 at 3:43 PM
    #74
    07COMA801
    Kris
    salt lake city
    but going 4inch and up your going to have to drop the under carrage and inch or soo?
  15. Feb 19, 2013 at 5:35 PM
    #75
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    Sounds like a 3" lift is for you:thumbsup:
    I would say there is a handful of tacos with DB lifts who wheel.
    coming from a 3" lift to a DB with the same size tires you will lose a bit of clearance but its worth it to have some downtravel/no stress on cv's/extra room in the wheel wells.
    ill get my clarance back with new coils and some larger tires.
  16. Feb 19, 2013 at 6:05 PM
    #76
    blake5995
    Blake
    Truckee, CA
    I was talking about 6 inch DB lifts. they will have cv angle if not worse than with a 3inch
  17. Feb 19, 2013 at 6:06 PM
    #77
    blake5995
    Blake
    Truckee, CA
    yes 4 inch and up you will need to have a drop bracket. you can do a 4 inch with one inch body and 3 inch suspension but i dont recommend body lifts
  18. Feb 19, 2013 at 6:34 PM
    #78
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    I agree with this^
    What:confused:
    Ive had both 3" and now have a 6" lift
  19. Feb 19, 2013 at 6:43 PM
    #79
    Glueman
    Glueman Yersinia pestis
    Utah
    The Black Death
    6 inch PC Douche Bag lift...what else do I need?
    Word! :D
  20. Feb 19, 2013 at 7:01 PM
    #80
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    My CVs sit almost level. 2.5-3" higher than stock.
