I want to power wash my seats.
Discussion in 'Detailing' started by TucsonAZ, Apr 30, 2017.
  1. May 2, 2017 at 9:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Dirt doesn't need much moisture to turn to mildew. Even if you do get them dry, your ass sweating is going to make that deep, driven dirt turn to mildew.
    Look up some YT vids on removal of seat fabric. It does take some work, but having those super clean, almost new looking seats would make it worth it.
    It sounds like you have your mind up. Please report back.
  2. May 2, 2017 at 10:01 PM
    TucsonAZ
    TucsonAZ [OP] Well-Known Member
    2006 Crew Cab TRD
    ARB Bumper
    I'm going to try to remove the seat fabric and see how that goes. That will allow me to address a hole in one of them while I'm at it so that's just fine.
    koditten likes this.
  3. May 3, 2017 at 4:18 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    If you can't get the covers off I'm sure an upholstery shop could. Sometimes they can be difficult if there's lots of plastic trim and hog rings involved. When you get them off, I'd use the gentle cycle on your washing manchine, dry on low heat, you don't want to risk shrinkage.
  4. May 3, 2017 at 4:40 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    this little machine is great. My original reason to buy one was when we first got a puppy, worth every penny, works well
  5. May 3, 2017 at 4:54 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm glad I read this post. Green Machine ordered!!
    Benzdriver81 likes this.
  6. May 3, 2017 at 4:56 AM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    I was happy with mine for small jobs but had to fill and empty it endlessly so I now use a 2 gallon garden sprayer, scrub brush and a shop vac. The results are the same just a huge time savings now but if I were just doing little things here and there I would only use the Green Machine.
  7. May 3, 2017 at 5:26 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Don't feed the trolls!!
    Come on people, #1 rule.
    Kyitty likes this.
  8. May 3, 2017 at 5:48 AM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    I'm not sure if you're talking about me but I don't think that word means what you think it means. I see it used a lot but very few people take the time to actually read what it is and how it applies to the person using it.
    That said, I was serious if you were thinking my post was trolling, I'm old school man, Lincoln lockers old school from way back before you could just toss a handful of money at a problem buy something without having to fabricate it yourself or look up the solution on Youtube. There's very little you can't do with a power washer, some duct tape, and a little hook and loop tape.
  9. May 3, 2017 at 5:55 AM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    Getting them off is pretty simple, your going to have to cut about 30 hog rings out on each seat and buy new ones when you reinstall.
    Its a learning experience but with a little bit of patience you can knock it out.
  10. May 3, 2017 at 5:59 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    If the seats are that bad then the carpet is probably worse. Sounds like your only option is just leave the seats inside and just pressure wash the shit out of the cab, in that Arizona heat and low humidity should be dry allmost instantly!
  11. May 3, 2017 at 3:36 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    I will buy a set on Amazon, I kind of suck at detail stuff but hopefully they will come out alright. My mom is super good with sewing and said once I have them off it would be easy for her to make a template for making covers. I was un the impression from the link I found it was like 12 hog rings but whatever. Do you know if I can swap covers and put the drivers side on the passengers side, they look the same other than maybe a hole for the lumbar.
    That's a horrible idea! As I said, I'm not worried about the drying or mold but I am worried about the electronics and there are a lot of those in the car which could get damaged with your idea. I could take the carpet out and power wash it but that would be a huge job! Plus, I already cleaned the carpet.
  12. May 3, 2017 at 3:44 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Pressure washing the interior shouldn't have been brought up in the first place...
    Benzdriver81 and Midnighttaco08 like this.
  13. May 3, 2017 at 4:00 PM
    THROTTLE231
    THROTTLE231 Well-Known Member
    Shane
    High Dez,Comifornia
    2011MGMDCSB6MT With Not So So Cool Shit...
    I LIKE BEER....
    OP :worthless: Would love to see before and After:cheers:
  14. May 3, 2017 at 4:02 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Does 05 have air bags in the seat sides? I know 08 does...
  15. May 3, 2017 at 4:05 PM
    #35
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    What about using laundry detergent in an upholstry/carpet cleaner instead of conventional cleaning chemicals?
  16. May 3, 2017 at 4:07 PM
    #36
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Take the upholstrey off and run it through the wash and put it back on
    03f5sp likes this.
  17. May 3, 2017 at 4:10 PM
    #37
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Do you or a buddy have a bass boat or ski boat?
    If so, take the seats out and tie them to a ski rope and pull them behind the boat for at least 20 minutes, also let them sink periodically.. After, throw them in the back of your buddy's truck and pressure wash and vacuum them on the way home.. Then air dry in sun for one week.. Good as new.
    Video and post here.
  18. May 3, 2017 at 4:20 PM
    #38
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    Step 1: Line truck bed with tarp
    Step 2: pour economy size bottle of laundry detergent into truck bed. Use Gain, it's got Febreze. Tide has Downy, that works too. Just go full banana sandwich with it.
    Step 3: fill truck bed with water. Do this around 10 A.M. in your 100 degree weather, and wait a few hours so the water is warm. Warm cycles work best.
    Step 4: put seats in truck bed.
    Step 5: CAREFULLY (since your seats are out) drive the truck ERRATICALLY to simulate a spin cycle/agitator in the wash
    Step 6: drain bed. Refill with water.
    Step 7: Repeat step 5, to simulate a rinse cycle. Then repeats step 6 and 7 again, two rinses is best.
    Step 8: Leave in truck bed to dry.
    Step 9: Enjoy your new, fresh, Febreze'd seats!
    Or, you know, remove the covers and/or steam clean. I'd do the steam method.
    vssman, Kyitty and Guerrilla like this.
  19. May 3, 2017 at 4:20 PM
    #39
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Water evaporates great in Tucson. I lived there eight years. Lived in Phx about 15 years.
    However, foam does not dry like pavement.
    Good luck cleaning nasty fabric and foam without some kind of detergent/solvent.
  20. May 3, 2017 at 4:23 PM
    #40
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    This works even better if you have a camper shell/cap...
