I wasn't planning on changing oil today...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcayce, Dec 6, 2009.
  1. Dec 6, 2009 at 1:24 PM
    jcayce
    jcayce [OP] Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    ...I tend to overthink things and after reading several posts I knew that it was going to be difficult to take off the first oil filter but I never planned on what happened today. I bought a case of JP 90915-20004, a Fumoto Valve, and a pair of rubber strapped ratchet wrenches (from Lowes) in preparation for my first oil change. I was going to wait until 2,000 miles but I bought the truck in June and just hit 1,700 so I planned on doing it soon due to the amount of time that had passed.
    This morning I thought that I would loosen the filter thinking that there would be no pressure holding the filter down, tighten it back down a little, then change the oil tomorrow after running errands. I put the strap wrench on the oil filter and ended up crushing one corner of it. I then proceeded to try every filter cap I had, filter caps with sandpaper wedged into them, and finally brute force with a pair of rubber gloves. No dice.
    At this point I was afraid to drive the truck in case the internals of the oil filter were damaged. On top of that, even if I did get the filter off I knew that I would never get all of the oil out of the truck when it was cold. I took the wife's Jeep to Auto Zone and grabbed a different size filter cap (wishful thinking) and a $3.00 Purolator filter. I then stopped at Home Depot and grabbed a set of oil filter pliers.
    Long story short: New filter cap did not fit, oil filter pliers did, put on cheap Purolator filter, ran the engine for 15 minutes, drained the oil, installed the Fumoto valve, took off the Purolator filter, installed the JP 90915-20004, dumped in 5.5 quarts of Mobil 1.
    Murphy's law wins.
  2. Dec 6, 2009 at 1:48 PM
    GT150
    GT150 Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    I have had oil filters become very hard to remove if they are left on for extended periods. Also could have been put on too tight. I have had my 2010 for 30 days and hit 1600 miles this morning, I was surprized how many miles I have put on, and I'm retired. All pleasure driving........
  3. Dec 6, 2009 at 2:02 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    The filter that came from the factory on mine took some serious force to break loose. I dinted the crap out of it in the process. I've done a few since and they are normal so I think it is a "feature" from the factory.
  4. Dec 6, 2009 at 2:15 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Most filters on a brand new car are that way. On mine I ended up stabbing the filter with a screwdriver and twisted it off.
  5. Dec 6, 2009 at 2:18 PM
    jandrews
    '09 FourDubDee TRD OR
    The factory filters are put on by Thor. You need 4 fat women and a team of Clydesdales to break them loose.
    After that though, it's one of the easiest vehicles I've ever changed the oil on.
    Which reminds me, I gotta do my Matrix soon...
  6. Dec 6, 2009 at 2:21 PM
    Taco John
    Illinois
    4X4
    With my 4X4, the biggest problem is getting a catch pan that will fit under the truck and keep the oil from splashing EVERYWHERE when it hits the bottom of the pan. [​IMG]
  7. Dec 6, 2009 at 3:13 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    great story! those oil filter pliers are cool. i will never buy one tho. i just use a monster pair of channel locks. i have to many cars with different sized filters, and channel locks are a multi-tasker.
    why stress out on dumping oil from a cold truck? sure the viscosity may hang up a few spoonfuls, but in a waste water engineering class, we learned; the best solution to pollution is dilution. it applys to an oil change too.
    again, great story!!;)
  8. Dec 6, 2009 at 5:46 PM
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    I took a storage tote and cut it to fit under the front end. Works great. No splash or spillage. From there, I transfer to 5 gal tank.
  9. Dec 6, 2009 at 5:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I was planning on doing my oil this morning...In my scion....and thank god it didn't suck any where near as much as your did.
    Sorry it was such an event for you....Better luck next time!!
  10. Dec 6, 2009 at 5:53 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Original filters are put on via machine, hence them being so hard to get off.
  11. Dec 6, 2009 at 6:03 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Any chance of the Fumoto Valve getting hit by a rock while wheeling and draining your oil?
  12. Dec 6, 2009 at 6:11 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I think I will go ahead and ask a question on this one and I'm not trying to be an @ss or anything jcayce, just curious.
    Why did you loosen the filter up, then tighten it up again? Then change the oil the next day and take off the filter?
    Were you trying to see how tight the oil filter was, couldn't you find that out the day you were going to change the oil? :confused:
  13. Dec 6, 2009 at 6:16 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    git some monster daddy channel locks,they work good.
  14. Dec 6, 2009 at 6:34 PM
    trdhrdr
    trdhrdr Member
    Chicago
    2010 Taco TRD 4X4
    Did my first oil change today, 700 miles. Went to Penzoil Platinum 5W-30. 12" pipe wrench is what it took to get my filter off!!!
  15. Dec 6, 2009 at 6:46 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Same here. I'm pretty strong but holy crap, they must've had a Sumo wrestler putting that shit on. I tore the crap out of the filter getting it off. Since then, no problem since I don't tighten it that damn tight.
  16. Dec 6, 2009 at 7:03 PM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I found these filter wrenches at PepBoys. They're more expensive than most but they are the best wrench I've used. I've tried just about all of them while working on bikes. They come in 3 sizes. The middle one fits the most common applications. The teeth bite into the filter and put more pressure on the case since there aren't many contact points.. The head is also offset (like the box end of a combo wrench).
    IMO the strap wrenches and the metal band wrenches are pretty useless, especially if the filter has any oil on it. This jaw type wrench is the most worthless of all. There are too many dull contact points and the thing just slides around.
    The best thing is a monkey wrench but you'll probably never have the space luxury to use one.
    Driving a screwdriver through the filter and twisting it off with the handle works well but its messy. Remember to pierce through the filter high enough that you don't damage the spigot that the filter screws onto. If you have trouble with it, try driving a thin screwdriver in first, then tap in a thick screwdriver into the same hole. The thicker driver will help keep you from shearing the filter case.
    Finally, for the most stubborn of filters, taking a wide flat chisel and tapping gently tangent to the base of the filter will work. You'll pierce the case first and then tap with the chisel held at an angle towards the base. A dull chisel works better.
    Cap wrenches are okay but they don't work well on filters that are on too tight.
    I haven't tried a spider wrench yet but I'm curious about it. I don't think it will work but its too neat a concept to leave alone.
    For the first change on my Taco I had to drive a screwdriver through the filter. I still couldn't get enough leverage on it from the ground so I crawled up into the engine compartment and put my weight on the driver. The filter finally broke loose. I had one foot on the fender in front of the intake. I think my other kneewas on the metal brace above the radiator.
  17. Dec 6, 2009 at 7:19 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Really, out of all the different kinds of car and truck filters I have changed after running to temp., I have not once ran into that problem? What kind of tool are you using to get it off?
  18. Dec 6, 2009 at 7:23 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I think he was trying to warm up the engine before he drained the oil. This is actually recommended so you get more of the used oil out--As opposed to draining it cold. :)
  19. Dec 6, 2009 at 7:29 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    :rolleyes:...I know about that, about warming the oil up!
    This is what he typed: "This morning I thought that I would loosen the filter thinking that there would be no pressure holding the filter down, tighten it back down a little, then change the oil tomorrow after running errands"
    EDIT: Maybe I read it wrong. But it sounds like he tried to loosen the filter, then wanted to tighten it back on. Then drive around and change it the next day? I'm just curious.
  20. Dec 6, 2009 at 7:43 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    Two reasons, one, like heshup said, heat expansion and two, I thought there might be some intial vaccuum from the engine that would be working against me. I knew it was going to be a bitch no matter what, I was just trying to make it a little easier.
    I did want to loosen it (when cold)then snug it back down. Knowing that I 'could' loosen it was alleviating any worries of problems later and later the oil would be hot.
