i will be having fun today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chugchug, Aug 21, 2010.
  1. Aug 21, 2010 at 10:02 AM
    chugchug
    chugchug [OP] Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    I am going to change all my gear oil. front and rear diff. transfer case and manual transmission. also my engine oil. If you all know anything I might need to know let me know.
  2. Aug 21, 2010 at 10:07 AM
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    if your gonna...put a girl in it
  3. Aug 21, 2010 at 10:09 AM
    SACTOWN
    SACTOWN ???????????????????????
    Greg
    '18 ZR2, 04 Rubicon, &19 lx570
    ^ make sure she is hot and in the nude and send pictures to UG
  4. Aug 21, 2010 at 10:09 AM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    make a write up :D
  5. Aug 21, 2010 at 2:32 PM
    chugchug
    Will
    Frederick MD
    2012 Toyota Tundra
    The first thing i did was the oil change here are some pics.
    Photo0045.jpg The first thing I did was take out the 14mm bolt and drained the oil
    Photo0047.jpg When I finished wiped it clean and put the drain plug back in tightened it up.
    Photo0049.jpg Went up top and attached a hose to the drain nipple and ran the hose to the oil pan. Then loosened the oil filter and let it drain down.
    Photo0052.jpg I wiped it clean and made sure that there was nothing left.
    Photo0055.jpg Made sure that there was oil on the gasket of the filter before I put it on, hand tight
    Photo0050.jpg Then filled up the oil
  6. Aug 21, 2010 at 2:52 PM
    chugchug
    Will
    Frederick MD
    2012 Toyota Tundra
    Then I did the rear diff. Here are some pics.
    Photo0057.jpg I took out the top bolt first.
    Photo0060.jpg Then I took out the bottom bolt out.
    Photo0061.jpg It was windy so I had to drop moving blanket from the doors to block the wind so it wouldn't spray the oil all over the place
    Photo0062.jpg When it was finished dripping i clean it up.
    Photo0064.jpg Clean off the nasty crap off the magnet
    Photo0065.jpg CLEAN and put back on nice and tight.
    Photo0066.jpg Then I pumped in the knew oil.
    Photo0067.jpg Then I put the top blot back in and clean it up.
    All done now to clean up and take a shower.
    P.S.
    I did not put 5w-30 motor oil in my rear diff. The stupid pump I bought was a little too big to fit in the mouth of the gear oil bottle. I left this part to tell you for last because I knew you all would have fun with it
  7. Aug 21, 2010 at 2:54 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    nice and clear write ups.
    are you changing the other oils as well?
  8. Aug 21, 2010 at 3:10 PM
    chugchug
    Will
    Frederick MD
    2012 Toyota Tundra
    Not today the wind is getting bad. Also not sure the plugs are at to do the rest (the front diff and the transmission and the transfer case). I looked up there for a little bit but then went in side for the day. Now anyone knew where i can find some pics. of them it would help.
