ian408's 2009 DCSB TRD Sport Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ian408, Dec 16, 2014.
  1. Jan 10, 2015 at 8:38 PM
    ian408
    ian408 [OP] Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Typically, you want a large steel area to function as the ground plane. The mounting location doesn't have that. So I figured I'd go for the no ground plane.
    I might be totally wrong but it seems to work :D
    Thank you!
  2. Jan 10, 2015 at 8:45 PM
    Softtacosupreme
    Softtacosupreme Well-Known Member
    Damn good photo! Truck looks awesome!
  3. Jan 10, 2015 at 8:46 PM
    Softtacosupreme
    Just curious, what length firestik is that?
  4. Jan 10, 2015 at 8:53 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    4' Antenna.
  5. Jan 10, 2015 at 8:54 PM
    Softtacosupreme
    Cool, thanks.
  6. Jan 10, 2015 at 8:54 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Thank you!
  7. Jan 10, 2015 at 10:20 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Isn't the hood a good enough ground plane? True, the cab is about half-way up the antenna, but as long as the antenna clears the cab by enough isn't it fine? I'm still shaky on the impacts of lower-quality ground planes. I've heard that right behind the cab is a bad spot, and that in the center on top of the cab is the best spot, but mixed reviews about in-betweens like the hood, bumper, and tailgate.
    We'll have to see with my mom's setup!
  8. Jan 11, 2015 at 8:17 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It'll work. It might require more tuning or maybe have less (and more directional) range. I forget what's "enough" clearance. Firestick has the answer somewhere on their website.
    I guess using the NGP antenna assures you get adequate ground plane in non-optimal locations-the corner of the hood seems suboptimal. Whether it's as good as traditional, center of roof or not? I don't know.
  9. Jan 11, 2015 at 8:47 AM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Makes sense. Well provided it doesn't rain much here today we'll be tuning and testing by the end of the day, so I'll let you know!
  10. Jan 11, 2015 at 1:50 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Don't forget to test/tune in an open area with the doors and windows closed.
  11. Jan 11, 2015 at 2:13 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    The open area part won't happen for a little bit. Best we can do here is the middle of the cul-de-sac. It's still 10m from any other vehicles or trees or houses, but it's not exactly an open area. Most of the other open areas that we have access to are right under power lines, which seems even less ideal than a tree 12 meters away.
    I figure we'll be close enough using the cul-de-sac and then next time we're out in the desert or somewhere open we'll re-tune. Thank goodness for the tunable-tip firesticks!
    And one more question, since it's been raining all day... :rolleyes: Where did you route your coax? In bensonX's write-up he plugged it through the firewall with all the other computer electrical cables, but some people in that thread told him that that was bad because the computer cables and the coax could interfere with each other, even though the coax is 95% shielded. I don't know if that issue is the same with NGP, but you never know. That is, however, the most convenient way to route it. Otherwise we might try routing it down under the truck and then up through the floor or something, I dunno. That's how I ran mine. We have an 18' coax cable, so we have the room to work with it. :notsure:
    Thanks for your help!
  12. Jan 11, 2015 at 4:36 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I ran mine through the firewall. But with the NGP antenna, you cannot change the length of the antenna cable.
    About the noise. Yes. The cable radiates as well as receives. The reality is, it probably doesn't matter (unless you're running 1000W amp)-it's not like you use the radio all the time either.
  13. Jan 11, 2015 at 4:49 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    That's kinda what I figured with the noise. It's not that strong of a signal in the coax.
    Thanks for the help! It's been rainy all day so we're holding off for a dry day later this week.
  14. Jan 13, 2015 at 5:22 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Finished up and tuned my mom's cb today and it tuned beautifully! 1.15 on both channels 1 and 40. Looks like it's grounded just fine!
    Maybe there's a difference in range, but who knows. It works and we tested range and it was about .8 miles over a big hill. Not the best but she's got my old uniden pro510 that even on flat ground only gets about 1.2 miles of tx.
  15. Jan 13, 2015 at 5:30 PM
    #35
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Finally!!! Nice build Ian ;)
  16. Jan 13, 2015 at 7:37 PM
    #36
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Sweet! Probably enough range for most things.
    I know, right?
  17. Jan 30, 2015 at 4:43 PM
    #37
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Hey Ian any rubbing issues with the 305s and the total chaos arms? 305s look good brother. Thinking about those exact tires you got. Just not sure how close they would be to the UCAS
  18. Jan 30, 2015 at 8:49 PM
    #38
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    So far, so good! I need to beat back the body seam some more though.
  19. Jan 31, 2015 at 7:45 PM
    #39
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    :thumbsup:
  20. May 1, 2015 at 1:21 PM
    #40
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Back to the ngp cb antenna because my setup just crapped out...you have an ngp coax to go with the antenna, right? That's what I'm seeing on right channel radios and the firestick website.
