Icom F121 2meter Radio / Repeater Use?
Discussion in 'Technical Chat' started by rzimm001, Sep 26, 2010.
  1. Sep 26, 2010 at 12:45 AM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I just purchased an Icom f-121 race radio along with the software and cable to program it. I am trying to get on a couple local repeaters and haven't been having any luck. The software allows you to do tone control and I entered in the tones that were listed on the Socal Repeater List. Still can't get a response from the repeater. Any ideas? This radio is suppose to have tone control so it should be able to get on a repeater right? I entered in the rx #, the tx # (offset -0.600), and the tone. Help:confused:
  2. Sep 26, 2010 at 8:19 AM
    rzimm001
    Bobby
    Wildomar
  3. Sep 26, 2010 at 3:43 PM
    rzimm001
    Bobby
    Wildomar
  4. Sep 30, 2010 at 1:12 PM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    what is the call sign ?
  5. Sep 30, 2010 at 5:33 PM
    rzimm001
    Bobby
    Wildomar
    145.220 pl 103.5
    I finally managed to get on the repeater. Possibly a low battery or high swr was contributing to my difficulties. Now the radio works flawlessly and I'm very happy with the addition.
  6. Dec 29, 2011 at 8:39 AM
    thebrendanimal
    thebrendanimal New Member
    Brendan
    Centreville, VA
    I'm about to install my Yaesu 2 meter radio, hopefully below the new Pioneer single deck stereo I just got. How did you get faceplate with the two separate boxes to make that installation? Did you have to cut it yourself?
  7. Dec 29, 2011 at 8:43 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    That's a single DIN adapter and it comes with the two compartments. I have my yaesu installed exactly the same way. There was no cutting necessary for my install..
  8. Dec 29, 2011 at 8:58 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  9. Dec 29, 2011 at 9:04 AM
    rzimm001
    Bobby
    Wildomar
  10. Dec 29, 2011 at 9:17 AM
    rzimm001
    Bobby
    Wildomar
  11. Dec 29, 2011 at 7:45 PM
    thebrendanimal
    Brendan
    Centreville, VA
    Thanks, I just looked up the single DIN adapter. I'll order it once I shop it a bit, and get the install going. I'm excited about this, thanks again.
  12. Dec 29, 2011 at 10:16 PM
    rzimm001
    Bobby
    Wildomar
    You'll love it. Best mod I've done to my truck yet. Post some pics when you finish.
  13. Dec 29, 2011 at 10:24 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I would like to learn how to use repeaters. Haven't put any effort into learning it. How hard is it?
  14. Dec 29, 2011 at 10:34 PM
    rzimm001
    Bobby
    Wildomar
    Most repeaters have what's called a tone. More or less it's like a password that you transmit when your on the frequency used by a repeater. Without the tone, the repeater will not re-transmit your signal. With the tone, your effective range is nearly quadrupled by the repeater. Pretty awesome. I have Santiago peak, palomar, wildomar and the ridgeline repeater programmed into my radio. It's not something you can just use at your leisure though. Some repeaters are private. Others are open but you don't want to hog the frequency because other people may want to use it.
  15. Dec 29, 2011 at 10:39 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    My owners manual should explain it right?
  16. Dec 29, 2011 at 11:08 PM
    rzimm001
    Bobby
    Wildomar
    Yes. The manual should lay it all out for you. My radio was not really intended to be adjusted without the aid of a computer program so my directions didn't discuss repeaters or tones. Fortunately the computer software I bought later did.
  17. Dec 29, 2011 at 11:15 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I will look into it. Thanks man. And that's a clean install. I like the look.
  18. Dec 29, 2011 at 11:20 PM
    rzimm001
    Bobby
    Wildomar
    I had to make a few behind the scenes modifications though. I had to cut out out a portion of the din (back side) to allow room for the heat sink. Second mod is a 12v cooling fan (from radioshack) that kicks on when the radio is turned on. I had some problems with the radio getting super hot due to poor ventilation in the dash. Now with the fan it never overheats.
  19. Dec 29, 2011 at 11:25 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Nice. I put mine in that change tray behind the two main cup holders. I have a double din radio so no room there.
  20. Dec 29, 2011 at 11:29 PM
    MonkeyProof
    SoCal- SGV
    programming a repeater pair by hand is a pain..doesnt matter what radio you have. but programming a radio with good software can be done in minutes with no effort!!!
    repeaters expand coverage immensely..we all grasp that concept. but heres a good example. with just my 5watt handheld with the stock antenna im able to talk to peeps in big bear on the big bear lake repeater..and that's hitting it from Monrovia. i can also hit the Catalina Island repeater from my house with my handhelds. gets better then that, get on the right linked repeater system and you can talk to any where in the US
