icon CDC coilovers.
Discussion in 'Suspension' started by scotty225, Dec 21, 2012.
  1. Oct 10, 2013 at 8:18 AM
    #101
    cr500taco
    cr500taco Well-Known Member
    D
    Northridge
    4WD
    K&N intake.
    lol... I am n same boat!
  2. Oct 10, 2013 at 8:34 AM
    #102
    icallhertaco11
    icallhertaco11 Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    Ahaa I went mid in the back recently with Icons but now i'm regretting it and thinking I should have hopped on these before I did that aha.
  3. Dec 7, 2013 at 11:17 PM
    #103
    Rcc
    Rcc Member
    I read that Down South Motorsports offers a custom "low speed valve" job on Icons coilovers for more on-road drivers. Does the CDC valve do the same thing?
  4. Dec 9, 2013 at 7:24 AM
    #104
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    Icon's come valved more for Better On-road driving out of the box. Nothing custom. They use a Digressive valving over a progressive set up like fox/king
    The CDC valve let's you adjust your compression to soften of stiffen it up.
  5. Dec 9, 2013 at 7:59 AM
    #105
    Rcc
    Rcc Member
    I've read so many threads where people complained about Icon's being harsh at slower speeds and that's why DSM started offering the low speed valve tune so more on-road drivers will have a softer ride at lower speeds?
    I came across this post from this past January. The OP said that Icon started offering the same low speed valve tune. You said that Icon's come valved more for Better On-road driving out of the box, so is their low speed valving standard now?
    "Icon recently standardized a "low speed valving change" option that softens the feel of the shock. I am running these now and like them a lot. I have had the "regular" Icons on three vehicles prior, and like this softer valving much better for my relatively conservative use profile. The only drawback I have noticed is that they don't slow down the vehicle weight shifts as much, but the ride is great."
    In that same post, the OP said Icon's CDC valve is for high speed and not low speed? Is that true?
    "Most dealers probably are not aware of the option, so you are best served talking directly with Icon if you have questions. I was actually considering remote resi's with clickers just so I could soften the ride. Icon explained that the clickers on the resi's are for the high speed valving, and I would benefit more from a low speed change."
  6. Dec 9, 2013 at 8:46 AM
    #106
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    The way Digressive valving comes (standard Icon out of the box) is that it is a tad bit stiffer for the first few inches of travel, then steps back down get's progressivly stiffer after that. This is good and ideal for DD/ Weekend warrior applications. Where the limited travel needs to be used the best it can. You do not want to blow past those first few inches on every little bump or speed bump. A good valved 9" of travel works very well.
    With the CDC option, it does change the internal valving a little bit to work with the CDC valve better. So when you have it free flowing it's getting maximum dampening for hard hits. And when closed off it's softer.
    We have a lot of guys that we do installs on that their truck will most likely never see dirt. And we use the normal standard off the shelf valving Icon does per application and there has been 0 complaints. Everyone loves how it actually feels a bit firmer, especially in the cornering aspect.
  7. Dec 9, 2013 at 11:52 AM
    #107
    Rcc
    Rcc Member
    Thanks for the help!
    Icon also replied back to my questions and they said the CDC controls the low speed so the member above that said it controls the high speed apparently didn't understand what Icon was saying. Icon also said (like you said as well) that the CDC valve controls the compression so for now that's all I need to know.
    Again, I appreciate the help SDHQ!:cheers:
  8. Apr 10, 2014 at 3:54 PM
    #108
    YotaDan
    YotaDan Dan
    Dan
    Oregon
  9. Apr 17, 2014 at 4:43 PM
    #109
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, Toyo AT2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs URD 2.85" stealth pulley, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder.
  10. Apr 19, 2014 at 4:52 PM
    #110
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Whats the cost to add to a set of 2.5's with no current resi?
  11. Apr 25, 2014 at 8:53 AM
    #111
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    Navar,
    $845.00 would be the cost. That will include the Remote reservoir upgrade with CDCV and a basic rebuild of a pair of shocks.
  12. May 11, 2014 at 2:03 PM
    #112
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    Can you get the 2.0 rear shock resis with the cdc? I have a 97 4WD Tacoma.
  13. May 12, 2014 at 8:23 AM
    #113
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Currently only available in the 2.5" body shocks
  14. May 15, 2014 at 8:43 AM
    #114
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    What's the turn around time for the upgrade and rebuild?
  15. May 15, 2014 at 8:47 AM
    #115
    icon_rep
    Riverside, CA
    We do this on Tuesdays and usually get them done the same day. Sometimes there is a bunch to do and if so that could make it run over to Wednesday.
  16. May 15, 2014 at 9:02 AM
    #116
    ThomasMore66
    My stage 4 is going on as I type this. So excited!
  17. May 15, 2014 at 9:06 AM
    #117
    icon_rep
    Riverside, CA
    Nice!!!
    Post some photos when you can so we can check it out.
  18. May 15, 2014 at 9:11 AM
    #118
    ThomasMore66
    I didn't know CDC existed when I made the order. Seems like a great idea.
  19. May 15, 2014 at 6:07 PM
    #119
    ThomasMore66
    Rides great. Just wheels and tires now.
  20. May 15, 2014 at 6:47 PM
    #120
    ThomasMore66
    Maybe I'm inept. Couldn't get pics to load from my iPad.
