Icon Coilover Lower Bearing Service Kit
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, Mar 6, 2018.
  1. Nov 27, 2022 at 7:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^You mean as an assembly lube? I just used cosmoline when I did mine last year. Make sure you wipe off the excess so it doesn't get into the bearing.
  2. Nov 27, 2022 at 8:12 AM
    dmd6x
    dmd6x New Member
    Davis
    Yes... as an assembly lube. I sent these shocks back to Icon for factory service, but apparently their new tech working them somehow didn't see the rust on the lower bearing. I contacted them, they sent me the new parts, and now I get to do it myself :rolleyes:
    Now I'm noticing in the tech info section of the install instructions they're saying to "NOT apply any type of lube to the upper and lower bearings". So maybe just a light sheen of 3 in 1 oil to help it slide in?
    God Bless the forums...
  3. Nov 27, 2022 at 10:31 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The instructions are for installing into the truck. There should be no oil or grease in the bearing as it's teflon-lined and designed to work "dry". Periodically you can spray teflon lube into the bearing if they squeak.
    Before pressing bearing into the shock, you can spray cosmoline or other lubricant into the bore of the fitting. You can also spray cosmoline on the bolt shank before putting the bolt through the LCA.
  4. Nov 27, 2022 at 10:37 AM
    dmd6x
    dmd6x New Member
    Davis
    Awesome, thanks! I didn't realize it's teflon-lined... that's good to know!
    I'm not familiar with cosmoline... I'll google it and do some research. Would it be comparable to 3 in 1 machine oil?
  5. Nov 27, 2022 at 10:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  6. Dec 4, 2022 at 7:44 AM
    dmd6x
    dmd6x New Member
    Davis
    For anyone who references this in the future, it turns out the Icon product 614551 comes with a little blister pack of anti-seize. I called them to ask what brand they use/source for their kits, and was told it was just generic. I ended up getting a small tube of Permatex anti-seize from the local auto parts store, and it worked great.
    @3JOH221A, thanks for taking the time to help me out!
    3JOH22A and 1slow4.0 like this.
  7. Sep 5, 2023 at 8:47 PM
    Tacomaadrian
    Tacomaadrian New Member
    Adrian
    2012 4 door tacoma
    Hi there looking for some help with replacing my lower bearings on my coil overs. I’m new to the 4x4 world so it’s taken me a while to find this post lol. I’ve got the Radflow 2.5” coil overs with stock lower control arms, would this kit fit? I’ve sourced other spacers and bearings I’m just not sure if the spacers are 1.5” or 1.25”. Any help would be greatly appreciated. Cheers
  8. Apr 18, 2024 at 6:08 AM
    rktman
    rktman Active Member
    MO
    2006 Tacoma 4x4 TRD Sport
    Unfortunately the heim joint squeak is back on my Tacoma. It sounds like Marcel Ledbetters truck again.
    To the folks at ICON, I think there needs to be a better long term solution.
  9. Apr 24, 2024 at 7:01 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I have upgraded bearings for all 2.5 Tacoma/4Runner shocks.
    These are the complete kit with spacers in Mild steel, Alloy steel and Stainless steel.
    Good: https://www.303shockservices.com/product-page/2-5-coilover-lower-mount-replacement-bearing-kit
    Better: https://www.303shockservices.com/pr...-coilover-lower-mount-replacement-bearing-kit
    Best: https://www.303shockservices.com/pr...-coilover-lower-mount-replacement-bearing-kit
    We also have upgraded lower bolts that are shanked and a constant diameter vs the stock bolts.
    https://www.303shockservices.com/product-page/toyota-lower-shock-bolt-set
    These are just the bearings and new C clips to upgrade over the spirolox that is standard.
    Best: https://www.303shockservices.com/product-page/fkss10t-bearing-kit
    Better: https://www.303shockservices.com/product-page/fks10t-bearing-kit
    Good: https://www.303shockservices.com/product-page/com10t-bearing-kit
    rktman[QUOTED] likes this.
