Icon coilover question????
Discussion in 'Suspension' started by ETaco23, Mar 31, 2011.
  1. Mar 31, 2011 at 6:04 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I just Installed my Icon ext. travel coilovers, and was just adjusting them. And I noticed I had to go up to 2" of thread showing on the drivers side to get it to 3" of lift, and the passenger side only 1.5" of threads are showing......
    I know about the taco lean, But a .5" of thread difference is crazy!
    Are these coilovers a 2:1 ratio? (.5"=1" lift)
    Or not?
    Oh! and I did drive it around before re-measuring.:rolleyes:
    Thanks for any insight to this....
  2. Mar 31, 2011 at 6:07 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    0.5" doesnt really surprise me. Mine leaned by more then that before I put a top plate spacer on the driver side. Your coilovers are a "1:2" ratio as are all front end lifts for the tacoma
  3. Mar 31, 2011 at 6:11 PM
    ETaco23
    Evan
    PNW
    Could I do a 1/2" top plate spacer on the drivers side and a 1/4" one on the passenger?
    Or do one just on the drivers side?
  4. Mar 31, 2011 at 6:16 PM
    jandrews
    '09 FourDubDee TRD OR
    Mine needs about a 3/8ths difference from side to side to be levelish from the taco lean...in other words, driver has about 3/8ths more thread showing.
    The 2:1 ratio is a factor of the control arm articulation geometry, not the type of coilover.
    As long as both sides are within 1/4", call it good.
    I would NOT add a spacer. Dicks up the point of getting adjustable coilovers in the first place.
    Also: Pro Tip: LUBE THE ADJUSTMENT COLLAR AND THREADS. REGULARLY. You'll thank yourself next time you need to tweak them.
  5. Mar 31, 2011 at 6:18 PM
    ETaco23
    Evan
    PNW
    k. but thats a good idea to do a top plate spacer on the drivers side.. But is it safe or a good thing to do?
  6. Mar 31, 2011 at 6:19 PM
    jandrews
    Safe? Maybe. Good? No.
    Just adjust them offset and be happy. What's the issue here?
  7. Mar 31, 2011 at 6:23 PM
    ETaco23
    Evan
    PNW
    I just think it would be nice to have both side close to the same preload, instead of one side being stiffer then the other... But if its not that big of deal. Then im fine with how it is.
  8. Mar 31, 2011 at 6:25 PM
    jandrews
    I seriously doubt you're going to notice any difference that matters.
    May I recommend some aftermarket bumpstops to complete your cushy front-end ride?
  9. Mar 31, 2011 at 6:29 PM
    ETaco23
    Evan
    PNW
    Nah! I think I wil be fine with the stock ones for now....
    Are you running a sway bar Jandrews?
    I just put mine back on bc of the onroad body roll. But I noticed it felt better over bumps without it.
  10. Mar 31, 2011 at 6:31 PM
    jandrews
    God no. That thing came off, I went for one test drive in between suspension adjustments, and it hasn't been back near my truck since.
  11. Mar 31, 2011 at 6:34 PM
    ETaco23
    Evan
    PNW
    lol..... I think i may keep mine on, bc I dont do much off roading...
  12. Mar 31, 2011 at 6:59 PM
    ttbomb33
    ttbomb33 Active Member
    Georgia
    Procomp 3 inch lift, K&N intake, Flowmaster, 285/70/17 duratracs 17x8 procomps
    Yeah my coilovers where about a .5 inch different because of the lean.
  13. Mar 31, 2011 at 7:08 PM
    ETaco23
    Evan
    PNW
    ^Cool! thanks for the post, thats what I want to hear. :)
    How much thread do you have showing on the drivers side?
  14. Mar 31, 2011 at 10:26 PM
    ETaco23
    Evan
    PNW
    So who can tell me if its bad to put a top plate spacer on the Icons?
    Say 1/2" driver side 1/4" passenger....
    Is there any negative effects?
  15. Mar 31, 2011 at 10:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    just crank up the preload a little if you want the lift.
  16. Mar 31, 2011 at 10:31 PM
    ETaco23
    Evan
    PNW
    Im trying to decrease the preload on the springs to soften up the ride. But I dont want to do it if it could damage ball joints ect.
  17. Apr 1, 2011 at 2:21 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    What kinda lube you be talking bout?
  18. Apr 1, 2011 at 4:24 AM
    jandrews
    The teflon stuff for the uniballs works fine for that purpose too.
  19. Apr 1, 2011 at 5:11 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Cool thanks man! Ill do that, heck i cant see it hurting anything.
  20. Apr 1, 2011 at 7:18 AM
    ETaco23
    Evan
    PNW
    I ordered a 1/4" top plate spacer for the driver side. So that the coilover doesnt have so much preload.
