ICON coilovers TOO STIFF
Discussion in 'Suspension' started by Carl_z33, May 18, 2018.
  1. Mar 30, 2019 at 8:00 AM
    #201
    doorsidedown
    doorsidedown Well-Known Member
    follow the above advice... fixed it for you.
    also, please explain...
    Are you saying that a 600lb spring won’t ride a little nicer than a 650lb spring? and I recommend a 14” because if you’re replacing the spring anyway... why go with another 13”?
    I also explained that a 14” spring alone does not change your “preload” just because it’s not cranked as much.
  2. Mar 30, 2019 at 8:03 AM
    #202
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The lack of logic in this post is outstanding.
    @chrslefty please do not filling (listen to) the above advise
  3. Mar 30, 2019 at 8:12 AM
    #203
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    https://accutuneoffroad.com/articles/coilover-spring-rates-for-toyota-tacoma-4runner/
    So why do they suggest a longer spring if your adding more weight? Ie 14" 600 lbs spring?
    Spring Rate Recommendations for 2-2.5” lift:
    13” x 600 lb/in Spring:
    Standard on:
    -Fox Tacoma Coilovers
    -Mods: sliders, skid plates
    -Min installed length: 11-3/8” 1
    14” x 600 lb/in Spring:
    Standard on:
    -Fox 4Runner
    -King Tacoma & 4Runner
    -Mods: sliders, skid plates, light bumper, & light winch
  4. Mar 30, 2019 at 8:30 AM
    #204
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Longer spring will give you the extra lift a shorter spring can't if both are without preload.
    Therefore to get a specific lift height with a shorter vs longer spring of the same spring rate, the shorter will need more preload and will ride more poorly.
    In good sight, this may be why my mind ride better, not the progressive vs regressive valving. The kings have 14" springs.
    SC2SC and doorsidedown like this.
  5. Mar 30, 2019 at 8:48 AM
    #205
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    :rofl::fistbump: Okay, I deserved that.
    Havnt had my coffee yet. :pccoffee:
    No, just no.
  6. Mar 30, 2019 at 9:20 AM
    #206
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    Next thing- peeps will start saying not to buy OME 887 springs, when you can just use the shorter OME 885 spings, and raise the perch height...
    Or why not just buy 883 coils- and max out the 5100 perch height... :rofl:
  7. Mar 30, 2019 at 9:39 AM
    #207
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I'm going to need you to explain this one to me.
    SC2SC likes this.
  8. Mar 30, 2019 at 6:40 PM
    #208
    AZDirtyTaco
    AZDirtyTaco Active Member
    Ricky
    AZ
    TRD Offroad
    Stage 4 ICON 2.5 w/ remote resi front/rear - ICON AAL - Camburg UCA - 275R17 Nitto Trail Grappler's on ATX Artillary's
    ICON rebuild kit 252011 is what was recommended for a softer ride. Foddrill Motorsports in Glendale does nice work. They had mine done is less than a week. SDHQ is a solid shop, but that wait time is absurd.
    SC2SC and chrslefty[QUOTED] like this.
  9. Mar 30, 2019 at 7:41 PM
    #209
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    The month and 1/2 wait is pretty ruff.
    Do you have a link for there shop??
  10. Mar 30, 2019 at 8:20 PM
    #210
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    If you have a second vehicle and willing to go to Tucson, ADS Racing Shocks rebuilt 2 3 tube bypasses and 2 coilovers for me same-day. Took them like 6 hours. You'd have to bring them the parts and valve stack, but their turnaround time is impressive. Just a thought.
    SC2SC likes this.
  11. Mar 30, 2019 at 8:23 PM
    #211
    4WD FTW
    '08 DC LB 4x4
    I also agree with the icons riding rather stiff though. However it's my own fault. I had them valved for hardcore catching air and sh*t and now between work and school the most offroading I see is suburban roads
    SC2SC likes this.
  12. Oct 10, 2019 at 7:10 AM
    #212
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    So I am experiencing some of the issues with my icons as well. I had to adjust the shit out of the drivers side to compensate for the taco lean and now the front end is stiff as hell. I’m thinking of two simple options. 1) lower both sides until they are equal which means I lost approx 3/4-1” of lift up front or 2) add a 1/4” spaced on the drivers side to compensate for the taco lean and slightly adjust both sides to equal out only losing 1/2-3/4” lift.
    I would like to try these options out before going with new springs like the 14” 650lb.
    Has anyone used a 1/4” spacer on their icons?
  13. Oct 10, 2019 at 7:19 AM
    #213
    Carl_z33
    Carl_z33 [OP] Well-Known Member
    Carl
    2014 Toyota Tacoma TRD OR 4x4 DCSB
    I’ve used the 1/4” spacer & you can’t feel difference.
    If you keep icon, get a softer & taller spring like Kings 600lb
    Or just switch out your suspension & go to fox or king
    93yotasr5[QUOTED] and Coot83 like this.
  14. Oct 10, 2019 at 7:23 AM
    #214
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    To elaborate on this, many folks will swap in king 600# coils whether its icon or fox as the king spring coil generally has a plush, but effective feel.
    93yotasr5 likes this.
  15. Oct 10, 2019 at 7:24 AM
    #215
    93yotasr5
    Sacramento
    Was the 1/4” spacer enough to make a difference?
  16. Oct 10, 2019 at 7:26 AM
    #216
    Carl_z33
    Carl
    Yeah
  17. Oct 10, 2019 at 7:29 AM
    #217
    desertjunkie760
    Shane
    Check My Sig.
    What springs are you currently using?
  18. Oct 10, 2019 at 7:38 AM
    #218
    93yotasr5
    Sacramento
    The factory icons 13” 650lb I believe is what they are.
    no aftermarket bumper. Just sliders
  19. Oct 10, 2019 at 7:41 AM
    #219
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    It sounds like they may be adjusted too high.
    If they are the extended travel versions the distance from the top of the top hat to center of lower bolt should not exceed 21".
    We do not recommend that you install any spacers between the top hat and frame mount.
    The spacers let the shock extend too far and can damage the cv axles or other suspension parts.
    The spacers also push the shock down so you could be allowing the shock to bottom out, which can cause the seals to fail prematurely, among other things.
    larson627 and desertjunkie760 like this.
  20. Oct 10, 2019 at 7:45 AM
    #220
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Just a heads up...
    There's plenty of threads on here of people using Kings saying they ride harsh.
    Take everyone's review with a grain of salt. Some people's "harsh" may be another person's "butter"
    With that being said. There ARE some company fanboys out there. So beware of the users that will hype a product to the death simply because they have them. So dont be surprised if you get the kings they also aren't what you expected...
    whatstcp likes this.
