ICON coilovers TOO STIFF
Discussion in 'Suspension' started by Carl_z33, May 18, 2018.
  1. Nov 4, 2020 at 12:27 PM
    #241
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Icon CDCV reservoir shocks have a softer compression stack than the non adjustable version. I'm sure you can call Icon and order that stack separately for your non adjuster style shocks.
  2. Nov 9, 2020 at 8:05 PM
    #242
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    I had them send me a custom stack.
    Rebuilt my shocks and it has been 4 months or so.
    Can’t tell a difference between the stock stack but I have only driven on the Highway honestly. The 700lb coils might have something to do with it but I don’t have much preload at all on them.
  3. Nov 10, 2020 at 3:52 AM
    #243
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Max preload for 14" 700# coils is 1.13" of exposed thread. Mine ride smooth AF on the road. I do have an ARB bumper with steel cable winch and full skids to weigh it down.
    DoulosXP likes this.
  4. Nov 11, 2020 at 6:42 PM
    #244
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    After I rebuilt them I don’t even think I have 1” of preload. Tried to see if it got any softer but it didn’t.
    I have a full bumper with hoops but it’s aluminum and I figured that was the problem.
    I Have a winch, full skids front to back-steel, sliders-steel to help weigh it down too.
    it’s not bad as i am used to it and don’t notice it. Just figured I would try to see if they would get any softer by making adjustments since I was rebuilding them anyway.
    I was just shocked at how much stiffer they road when compared to my OME kit back in the day but that one also had lighter springs not nearly as stiff as these 700lb ones
    eljedi68 likes this.
  5. Nov 11, 2020 at 7:41 PM
    #245
    eljedi68
    eljedi68 Well-Known Member
    David
    Kalaheo, HI
    2010 Tacoma Ext Cab 4x4
    complete Long Travel Suspension built by DMZ: 3+ Control Arms by TC, Bed Cage, Denver Under Springs, Fox all around (Coilover & Bypass up Frt, 3.0 Bypass Rr). Full Glass front fenders and bedsides. Engine so far: TRD CAI, DT Headers, URD Y Pipe, Gibson Muffler. And a Sprint Booster. Sits on Toyo OC 35x12.5 on 17’s. Nitro Rear end and re-geared for 35’s (4.56). Goals: Flowed Heads, Cams, and Boost (SC) ! So far, so good
    Yep, gotta love the rabbit hole:
    Once ya Mod it never stops
    I’m running Fox DSC C/O’s and Bypasses for the last 9 months (switched from King blue). Bought them from Accutune and had them custom valve them to my liking. (Great guys, service and company).
    long story short: I’ve been spending a lot of time, tricks and adjustments trying to make mine have better manners on the street (blasting off road their great),, it’s them little bumps and potholes that are a pain in the ass literally.
    anyways, I tried all kinds of various adjustments on my Comp and Reb, even tire psi and even D rated tires... all helped but no where near perfect.
    My Fox C/O’s have 650 coils running 200 psi,, and from the get go, the only thing I hadn’t readjusted/attacked since my install was ride height/preload: because- everyone, including Fox, suggested an Ideal Preload of “1” inch. (Kings and Icons too).
    and out of pure frustration I reached out to Accutune (actually they reached out to me by way of one of my grrrr vents), and I’m so thankful they did.
    yes, 1 inch of preload is a great place to start, check your ride height and clearances, etc etc.
    but... once I spent some time talking with Ryan at Accutune and giving him all my shock measurements and settings: turns out, my One inch of preload was too much for my Taco; basically my ride height/preload was right at the very end of the sweet spot and at the beginning of Big Hit valving; so soon as I would hit any small bumps or a pothole, it simply wouldn’t be enough of a big hit to cycle my suspension.
    Basically solid.
    the answer: set ride height in the soft part of the shocks performance!!! I am one big happy smiling guy now.
    hit Accutune up or Icon and find out the sweet spot of your shock (I’d tell ya the whole answer, but it’s a secret lol).
    note: most likely you’ll have to mount your shocks at around 1 inch of preload to find out where your ride sits, measure and then change once ya know the answers
    or... sadly, you might need lighter springs
    hope that long winded reply helps ya out
    aloha
    Island Cruiser and lorsteez like this.
  6. Nov 12, 2020 at 6:10 PM
    #246
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    Nice
    I have 1in on the driver and .5in on the passenger.
    I had way more before but I can’t really tell a difference. I really think it’s the 700lb coils and that the skids and winch (maybe sliders too) just don’t have enough weight to compress the coils “smoothly”
    The aluminum bumper might weigh 40lbs lol I can curl it with one hand holding a center hoop.
    I don’t get the lift I want this way so I might just crank it back since it doesn’t change the ride anyway haha
    eljedi68[QUOTED] likes this.
  7. Nov 12, 2020 at 6:26 PM
    #247
    eljedi68
    David
    Kalaheo, HI
    Yep... just not heavy enough
    ya should look into maybe 600 lbs or even lighter springs
  8. Nov 12, 2020 at 6:38 PM
    #248
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Accutune has some great articles on coils
    https://accutuneoffroad.com/articles/coilover-spring-rates-for-toyota-tacoma-4runner/
    From Accutune.
    Some people associate preload (loosely related to threads showing above spring nut) with a harsh ride because they are “cranking down” the spring. Increasing preload only raises ride height, it does not compress the spring more, and it does not make the ride rougher. The only time too much preload causes a rough ride is if you lift it too high and don’t have any down travel, or if the spring runs out of travel before the suspension bottoms out.
    crhsharks12, 4WD FTW and eljedi68 like this.
  9. Nov 12, 2020 at 9:12 PM
    #249
    eljedi68
    David
    Kalaheo, HI
    That’s two more for Accutune!
    and seriously, there’s still a chance your 700’s could work.
    literally on my set up I dropped Preload only 1/2 inch and it’s night and day (more so with our independent front ends).
    it’s all about putting your preload in the soft sweet spot. Too much preload and your basically riding on the beginning of big hit valving aka a Brick
  10. Nov 15, 2020 at 6:36 PM
    #250
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    Just got the CDCV added to my Icon's and the street handling is 100x better now. Before, I was on the line of throwing them away because they were so rough. 650lb coils with a lot of preload (2-2.5" of threads showing) with a taco lean spacer on the driver side and steel bumper, winch, and skid. Obviously that's a ton of preload but still night and day difference and the only thing changed was adding CDCV valving and setting it to soft. 700lb spring just sounds like a lot for these trucks.
    When adding preload I just imagine all the threads showing act like an adjustable strut spacer and the suspension just sits in further droop at ride height, but the coils don't get compressed in doing so.
    crhsharks12 and eljedi68 like this.
  11. Nov 16, 2020 at 8:34 AM
    #251
    eljedi68
    David
    Kalaheo, HI
    Nailed It ! Stoked for ya
  12. Nov 19, 2020 at 9:11 AM
    #252
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    What about for 13 inch 600 lb ones?
  13. Nov 19, 2020 at 9:45 AM
    #253
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    On an Icon shock, 2.13"
    crhsharks12[QUOTED] likes this.
  14. Nov 30, 2020 at 10:43 PM
    #254
    Dansly56
    Dansly56 Well-Known Member
    Dan
    Valencia, California
    2013 Toyota Tacoma Baja Edition 4WD
    Light bars, electronic side steps, bed cover, light bars, grills, roof rack, falken tires, method racing rims
    Can anyone help me dial in my icons coilovers? The preload is close to 2” and they run rough on my new 650lb springs. I don’t have the tool to adjust or the jack for a truck. I’m in SoCal near magic mountain.
  15. Dec 1, 2020 at 12:07 AM
    #255
    crhsharks12
    Denver, CO
    I placed 600 lb coil overs on mine and I do like them. Are yours actually rough? There’s a difference between rough, and smooth but stiff. Spring rate and valving are what would cause the ride to be less smooth, and more stiff.
  16. Dec 1, 2020 at 12:12 AM
    #256
    crhsharks12
    Denver, CO
    Also you don’t need the tool. I used a drill bit that was wide/Thick and carefully turned the spring that way after loosening the nut
  17. Dec 1, 2020 at 12:17 AM
    #257
    Dansly56
    Dan
    mine feel stiff but harsh like no softness to them at all but I’ve heard they’re like this over fox and kings.
  18. Dec 1, 2020 at 12:45 AM
    #258
    crhsharks12
    Denver, CO
    Man idk what to tell you. Mine were (and are not) never that way. And I don’t even have weight up front. Mine ride like butter, especially after I put on some 600 lb springs. But a lot more goes into feel/ride quality than the shocks my guy. Your tire pressure might be on the higher end. You might simply just have nothing/no weight in your car. Your sway bar can affect the suspension and how much is cycles/flexes. Type of tire on the car
    Are you sure you Didnt crank it past the 2.15” preload limit icon sets?
  19. Dec 1, 2020 at 12:51 AM
    #259
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    This is from a blog on lifting your Tacoma.... Not sure if this is whats happening to you.
    "lets say your vehicle has 8” of IFS travel. At your stock ride height, you are sitting close to the middle, giving you 4” of up travel, and 4” of down travel. That's a great ride height for good suspension performance over bumpy terrain with equal parts up and down travel. Say you install a suspension lift that lifts your vehicle 2 inches. Now, out of your 8” of total travel, you have 6” of up travel, but only 2” of down travel."
    https://overlandoutfitters.ca/blogs/news/the-myths-of-lifting-an-ifs-vehicle
  20. Dec 1, 2020 at 3:47 AM
    #260
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    2" of down travel is the minimum recommended from most places.
