icon extended travel coilover help (thread measurements)
Discussion in 'Suspension' started by Alfred, Feb 26, 2015.
  1. Mar 2, 2015 at 11:10 AM
    #41
    ThomasMore66
    Dallas/Fort Worth & Durango
    Just found this on the Icon site:
    Icon Vehicle Dynamics Suspension Question: How high can I adjust my coil-over shocks on my 4WD Tacoma?
    On 4WD Tacoma's you don't want to adjust Icon Vehicle Dynamics coil-overs to more than 2.5" of lift. Any more than that puts excessive wear and stress on CV's and boots. The use of a differential spacer will allow you to go slightly higher.
    I'm running the diff drop and the billet UCA's.
    Also, see item 15 on this: http://www.socalsupertrucks.com/InstallationInstructions/IconVehicleDynamics/IVD58730.pdf
  2. Mar 2, 2015 at 11:28 AM
    #42
    TacoXtreme
    TacoXtreme North Georgia Member
    Adam
    Mt. Airy GA
    11 TRD TX DC.
    Bull Bar, Borla Exhaust, Pro Comp Emplorer 55's, Daystar 2 1/2" leveling kit, UWS Toolbox, Bed Extender, Anytime Fog Light mod.
    I have the 1" different drop and mine are slightly over 2" especially on driver side. My cv angle doesn't look terrible. It is a little stiff but far better than the bilsteins setup
  3. Mar 2, 2015 at 11:53 AM
    #43
    ThomasMore66
    I've had zero issues and I've got more or less 10k on mine. I had been toying around with lowering the front a bit because I think the Dakars have settled just a bit and I do want a little bit of rake. I've also added about 60-70 lbs to the bed with a Relentless Tailgate protector and a KBVoodoo basket. The ride improved and I don't have as many squeaks from the Dak's. I've got a front skid coming that will add a little more weight.
  4. Mar 2, 2015 at 6:12 PM
    #44
    TacoXtreme
    Adam
    Mt. Airy GA
    11 TRD TX DC.
    So I lowered my icons just now. Sitting right at 23 3/4 hub to fender. 2 3/8 showing on driver side and 1 7/8 on passenger. Rides alot better. Was a total of 4 full turns down per side.
  5. Apr 25, 2015 at 7:26 AM
    #45
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    I finally installed my 2.0 ET's yesterday, set at 2" on both sides.
    CH to fender measurements:
    Front right = 23"
    Front Left = 23"
    Rear has a 1" block and 2" AAL
    Right rear = 25"
    Left rear = 24 1/2" (Full tank of gas)
    Love the ride!
  6. Apr 25, 2015 at 7:38 AM
    #46
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    LOL, I should have read this first I just commented on my thread "ICON going on". Nice looking truck!!!
  7. Apr 25, 2015 at 9:58 AM
    #47
    taczilla
    Marc
    2016 RAM Rebel
  8. Oct 20, 2015 at 11:06 AM
    #48
    44357
    44357 Whithersoever...
    Eric
    Desert RATS
    2017 T4R ORP MF
    Great thread!
    Newly installed Icon 2.5 Coilovers #58635 as delivered measurements:
    Driver: 1 5/16" of thread = 22" HC to Fender = 2" lift
    Passenger: 1 1/4" of thread = 22" HC to Fender = 2" lift
    How it sits with new shoes:
    Update #1: Dakar Leafs (CS047R) installed and measured as 23" HC to fender = 3" lift.
    Leer DCC w/rear full doors and weatherguard pack rat 308-3 in back, so constant 500lb unloaded weight back there...Update #2: Will keep 1" Rake and measure after alignment and 100mi then 500mi torque checkpoints.
    Depending on how the leaf springs settle/sag down, looking for 2"-2.5" lift with a rake <1".
    This thread has helped alot in potential settings for level!
    Parts: DSM UCA - Icon 2.5 Ext.Travel - Dakar Leafs - ProComp 5001 16x8 - Grabber LT265/75/16E 123/120Q
    Alfred[OP] and YotaDan like this.
  9. Nov 9, 2015 at 1:09 PM
    #49
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Just found this thread, just to be sure, the fewer threads at the top, the higher the lift?
    Want to make sure im rotating these the right direction :anonymous:
  10. Nov 9, 2015 at 1:15 PM
    #50
    Justinlhc
    Justinlhc Not looking for a relationship
    More threads showing=more lift.
    Alfred[OP] likes this.
  11. Nov 9, 2015 at 1:17 PM
    #51
    ramonortiz55
    Ramon
    Texas
    stock
    Thanks!
