Icon rears paired with Dakar leafs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZ2013, Nov 18, 2015.
  1. Nov 20, 2015 at 2:37 PM
    #81
    bzzr2
    bzzr2 Well-Known Member
    these sound right to me. i will say that you will notice a massive difference in perfomance with a 26.8 inch shock over a 24 inch shock, that down travel may make the difference in those rocky off camber tough spots.
    OP, go with these, but be sure to confirm if a bump stop extension is needed with them or not, it will be getting very close..
  2. Nov 20, 2015 at 2:39 PM
    #82
    AZ2013
    AZ2013 [OP] Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    I appreciate yours and everyone else's tios, suggestions and advice. It's all been very helpful. I plan on doing the u bolt flip kit with longer bump stops as well. Also the extended brake lines.
    I'm researching till my eyes fall out so that I only have to do all this one time. I'd be pissed if I rushed into it and wasted a bunch of money on shit that didn't work. My money tree died the day I became a cop so re doing everything is not an option! :thumbsup:
  3. Nov 20, 2015 at 2:41 PM
    #83
    bzzr2
    agreed on doing it right the 1st time. i've done it the wrong way a bunch of times and had to do it over.
    i must have missed that you were doing the u-bolt flip and bumps, perfect plan :) you will enjoy the extra down travel from the 26.8 long icons! you're gonna have a fantastic setup!
    AZ2013[QUOTED][OP] likes this.
  4. Nov 25, 2015 at 11:10 AM
    #84
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    On these extended icon rears are the eyelet mounts extended? Is that how they achieve the extended length?
  5. Nov 25, 2015 at 11:28 AM
    #85
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I'm not sure, I'd have to look into it further. I do know that they are longer than then OME shocks that I replaced.
  6. Nov 25, 2015 at 11:32 AM
    #86
    303tacoma
    Rebecca
    Ya I already have the regular length with my Dakars looking for more travel..according to numbers posted on wheelers they are more travel
  7. Nov 25, 2015 at 11:36 AM
    #87
    RogueTRD
    Cade
    So. Oregon
    The ones I have are 26.8" long, as compared to 23.25" for the standard 2.0.
  8. Nov 25, 2015 at 11:47 AM
    #88
    303tacoma
    Rebecca
    Yeah I just wanted to make sure they didn't achieve the longer extension with a longer eyelet mount,before I spend my cash on them would be a waste of money :D
  9. Nov 25, 2015 at 12:01 PM
    #89
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I am working this issue right now. I have the extended travel ICON kit which requires aftermarket Upper Control arms up front (I have Camburg UCA's, but they all do same thing), my rear shocks in the Icon set are p/n 56503R which are rated by Icon for 0 to 1.5" lift. There will not allow full droop when you have the OME Dakar springs, but several folks here use them anyway. For full flex capability (full droop) you will need custom built shocks with a longer stroke. Problem is this entails a longer shock and to keep your upper position (suspension bottomed out, wheel all the way up) I beleive you would need to relocate the shock top mount. Alternately you can use a taller bump stop to limit travel, but this kind of defeats some of the purpose of longer wheel travel as you are at this point just moving the same travel to a higher position. Ground clearance is improved in any case. I need the additional load capacity but have not decided if I want to replace my Icon RR rear shocks or not....
    Edit to add: per the Icon specs my 56503R are 24" extended, 14.25 colapsed.
  10. Nov 25, 2015 at 12:06 PM
    #90
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    You might need extended front brake lines and possibly a limiting strap
  11. Nov 25, 2015 at 12:12 PM
    #91
    303tacoma
    Rebecca
    My thinking with the extended rears was to get more droop out of my Dakars and take care of the collapsed length with a taller bump stop
  12. Nov 25, 2015 at 12:20 PM
    #92
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    That should work. And is probably the way I will go for now. Shock relocation requires hoops welded to the frame and the cost and time involved with that plus the longer shocks. The next step beyond that is a true long travel rear with shocks coming up inside the bed to a cage like a race truck. Not going there.
    303tacoma[QUOTED] likes this.
  13. Nov 25, 2015 at 12:23 PM
    #93
    Tacoma SS
    Denver
    Do you go wheeling?
  14. Nov 25, 2015 at 12:24 PM
    #94
    AZ2013
    Blake
    I ordered extended travel front coil overs and custom built extended travel rears from @JDEMELLO and his crew. They have been awesome answering all my questions. I'm also going with a U Bolt flip kit with longer bump stops and extended brake lines all around. Rears I believe are 16 collapsed and a little over 26 extended.
  15. Nov 25, 2015 at 12:35 PM
    #95
    RogueTRD
    Cade
    So. Oregon
    Yes I do. Why do you ask?
  16. Nov 25, 2015 at 12:52 PM
    #96
    Tacoma SS
    Denver
    Just wondering if those shocks are working out alright for you when you're flexing
  17. Nov 25, 2015 at 1:05 PM
    #97
    303tacoma
    Rebecca
    The rears are the same as wheelers offers 15.9 collapsed 26.8 extended ...did you by chance ask if they are using longer eyelet shock mounts? And how long are the bump stops you are getting?
    Edit: just to avoid confusion I'm talking about the non rr extended 2.0 vs
  18. Nov 25, 2015 at 1:07 PM
    #98
    AZ2013
    Blake
    I didn't ask about the eyelet mounts but if @JDEMELLO reads this maybe he can chime in. I'll get the part number for the bump stops in a few.
  19. Nov 25, 2015 at 1:07 PM
    #99
    303tacoma
    Rebecca
    So I'm wondering if demello and wheelers are offering the same extended length rears is Icon actually building them???
  20. Nov 25, 2015 at 1:12 PM
    #100
    RogueTRD
    Cade
    So. Oregon
    I have a few pics of my truck flexing in my build thread. They definitely droop more than when I had the OME shocks in the rear. I still need to install my rear super bumps and u bolt flip. I doubt I will do extended shackles at this point but down the road I might do a shock relocate.
