Icon RXT leaf spring help???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EricTRD4x4, Jan 19, 2019.
  1. Feb 17, 2023 at 7:02 PM
    #121
    Arcticdc5
    Arcticdc5 Well-Known Member
    The pins that set in the axle bracket won't allow it to become askew. Besides, you try torqueing down those U-bolts with wheels/tires in the way - no fun at all.
  2. Feb 17, 2023 at 9:28 PM
    #122
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I know the pin will get the packs to sit on the axle right, what I was wondering if it'd be possible for the packs to not be fully flush on that face of the axle, if that makes sense. Almost like there's a small shim in there. I may be fretting over nothing.
    You're definitely right about torquing those bolts with the tires on. Especially with a flip kit. Walk away with tire dust on my cheeks everytime.
  3. Feb 19, 2023 at 5:12 PM
    #123
    Arcticdc5
    Not if you torque those bolts in increments in an X-pattern - doubt having the truck weight sitting on them would have any affect on the packs being seated on the axle platforms.
  4. Feb 20, 2023 at 2:54 AM
    #124
    CAG Gonzo
    2018 OR DCLB BarRed
    That's the pattern I use. In the past, I'll get them decently tight but then put the wheels back on and let things settle. I'm mostly concerned about the ubolts not seating/gripping perfectly and end up squeaking. Pretty sure I had that happen last time. Loosened that side up and redid it slower and it went away. Could definitely be anectdotal and/or placebo.
  5. Feb 20, 2023 at 4:45 AM
    #125
    Burpnbill
    Burpnbill Well-Known Member
    2016 Tacoma SR5 DCSB
    Procomp rockwell wheels with Nitto ridgegrapplers
    doing my leafs today. planning on having to cut bolts out of shackles 110k on it. is 14mm the bolt size? will 9/16 work? heading to tractor supply ahead of time.
  6. Feb 20, 2023 at 4:55 AM
    #126
    trl1990561
    trl1990561 Well-Known Member
    Tyler
    Jupiter, FL
    2021 Lunar Rock Tacoma TRD Pro
    Prinsu Rack, 265/70/R17 KO2,RRW R7-H RCI Rock Sliders,RCI 18" Bed Rack, Decked System,Baja 40" Amber Roof Light bar, Baja Amber Ditch Lights,Baja Amber Fogs, ARB Twin Compressor, Switch Pro, Blaze Offroad Wiring
    I went with option (3) and I regret it feels like I’m driving down hill. I currently have a roof rack,sliders,decked system load (tools,camping gear etc), steel bed rack (RotoPax,maxtrax). It rides really nice but hate the rack forward. Last weekend I had 600lbs of play sand in bags and it didn’t make a difference.
  7. Feb 21, 2023 at 7:57 PM
    #127
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Bilstein 6112/5160 at 2.5” lift with SPC upper control arms, leaf set at stage 2
